Web Services - Handling complex type response
Aug 16, 2006 Aug 16, 2006
I have to consume a web service that returns an array of a complex type.
The wsdl looks as below:
Request: POST /UserManager/usermanager.asmx HTTP/1.1
<soap:Body>
<GetMargins xmlns=" http://tempuri.org/" />
</soap:Body>
Response: HTTP/1.1 200 OK
<soap:Body>
<GetMarginsResponse xmlns=" http://tempuri.org/">
<GetMarginsResult>
<string>string</string>
</GetMarginsResult>
</GetMarginsResponse>
</soap:Body>
The service is currently in my LAN. If I call the service with the code below:
<cfinvoke
webservice = " http://oecdevel/usermanager/usermanager.asmx?wsdl"
method = "GetMargins"
returnVariable = "stGetMarginsResponse">
<cfscript>
I get response: org.tempuri.ArrayOfString@465545dd
I have been trying to create a struct, etc but I have had not luck at all.
How can I read the response? Please help. Thanks in advance.
Advanced techniques
658
Enthusiast , Aug 17, 2006 Aug 17, 2006
The response is an instance of a java object - ArrayOfString. I would suggest starting by using cfdump on it. That will list the properties and methods of your response object. I suspect you will see 2 methods, getString() and getString(int i). So, if you call stGetMarginsResponse.getString() you should have a simple string array returned that you can loop thru. Or you can call stGetMarginsResponse.getString(i), where i is 0 thru arraylen to get a specific item out of the array.
Let us know you...
Enthusiast ,
Let us know your results. Also, if you post the WSDL I will look into it further if needed.
Aug 18, 2006 Aug 18, 2006
Ken, thank you so much.
You are right, I do get the array length with: #ArrayLen(Result.getString())# and I get an array item with: # stGetMarginsResponse.getString(1)#.
But how do I specify a variable within the parenthesis getString(x)?
<cfloop index="x" from=1 to=12>
<!--- Try 1: Displays error --->
#stGetMarginsRespons.getString(x)#<br /> - #x#
<!--- Try 2: Concatenating displays the variable stGetMarginsRespons.getString(1) --->
<cfset xVar="stGetMarginsRespons.getString(#x#)">
#xVar#<br />
</cfloop>
THANK YOU
Enthusiast ,
Your code looks basically correct:
</cfloop>
Is it cause you dropped the 'e' on stGetMarginsRespons? Appears you are missing the last letter of the variable name.
If that is not it, post the actual error message. That is always useful.
Ken,
I have it working just fine with the code below:
<cfinvoke
webservice = " http://sim.openecry.com/usermanager/usermanager.asmx?wsdl"
returnVariable = "Result">
<cfdump var="#Result#">
<cfoutput>
<cfset xArrayItems=#Result.getString()#>
<cfset xLen=ArrayLen(Result.getString())>
<cfloop index="x" from=1 to="#xLen#">
#x# - #xArrayItems#<br />
</cfloop>
</cfoutput>
I can refer to the array item by first assigning the array from property method to a regular variable. I am not sure this is the proper way to do it but it works.
Thanks a lot for you help I appreciate it very much.
Davide Formica
Enthusiast ,
It look fine. If your previous error was an undefined variable it was due to the mispelling of your previous return variable.
Your current code looks, OK but not very 'nice'. You do not need most of your pound signs. See attached:
Documentation
