7 Replies Latest reply on Jul 27, 2011 10:08 PM by Bhatt, Manish
    Help!!! Style name check
    Bhatt, Manish
      Hello
      Indesign  paragraph style and character style name should be lowercase.
      For Example:
      001_Head_Body_list
      it should change by:
      001_head_body_list
      Please support me and write a javascript and send as
        • 1. Re: Help!!! Style name check
          oblakoid
          if  (app.documents.length>0){
              for (var i=1; i<app.activeDocument.characterStyles.length;i++){
                  app.activeDocument.characterStyles[i].name=app.activeDocument.characterStyles[i].name.toL owerCase();
              for (var j=2; j<app.activeDocument.paragraphStyles.length;j++){
                  app.activeDocument.paragraphStyles[j].name=app.activeDocument.paragraphStyles[j].name.toL owerCase();
          Simple script which should change names of  paragraph and character styles in active document to lower case.
          • 2. Re: Help!!! Style name check
            Bhatt, Manish Level 1
            Hi it not working there are error can you check again
            Error Number:25
            Error string: Expected:;
            Line: 3
            source: app.activeDocument.characterStyles[i].name=app.activeDocument.charact erStyles[i].name.toLowerCase();
            offending text: erStyles
            please check and correct js send me
            • 3. Re: Help!!! Style name check
              Mac_06 Level 2
              Could be eaisly figured out one unexpected space breaking your code:
              Replace with:
              app.activeDocument.characterStyles[i].name=app.activeDocument.characterStyles[i].name.toLowerCase();
              Mac
              • 4. Re: Help!!! Style name check
                thanks a lot
                can you again help me if my folder name and my indesign file name is mismatch then how we correct then. this type any JS
                example folder name: 006-008_Co-ordination
                and indesign name is : 006_008-Co-ordination
                please send me
                • 5. Re: Help!!! Style name check
                  Mac_06 Level 2
                  simple stuff:
                  var Doc = app.activeDocument;
                  var myDocName = Doc.name.split(".")[0];
                  var parentFolderName = String(Doc.filePath).split("/").pop()
                  if(myDocName==parentFolderName)
                  alert ("Yes, your file name and folder name are same")
                  else
                  alert ("No, your file name and folder name are different")
                  Mac
                  • 6. Re: Help!!! Style name check
                    HI
                    else
                    I can run the script on batch and generated a error log on text file which file name not match and folder name also not match
                    can you help me?
                    • 7. Re: Help!!! Style name check
                      please you can also help me on this script
                      if my file name is US_001-002_opener
                      and my folder name is 001-002_opener
                      i can only check a page number range and hyphen
                      please suggest
