I am using FMS 3.5 it is runnnig fine but some time i am facing problem,
Some time streaming is working fine and even in Admin console i see the bandwidth Grapgh is growing up due to no. of connected users
but automatically it happen streaming is stop and bandwidth graph is going down till zero then i restart to FMS then streaming goes smoothly and working fine.
before restart i check FMS services it is started and also encoder is connected when i restart it goes smoothly.
What happen to FMS i don't know and i don't find any error in FMS log how to stop streaming even FMS is connected and started
Please help me abiut this issue coz i am stuck on this stage some time after 10 -12 hours it stopand some time it stop 30 minutes.
Thanks for using FMS. It is strange to note that the connections and the stream bandwidth coming down for no reason. Are you using the default live sample application that comes on FMS or do you have your own application ?
Also, there are updates for 3.5 release that you can probably give a try to. Can you please take a look at the latest (3.5.6 I guess) FMS and see if you are still facing the disconnections ?
Thank you !
Thanks for your reply,
I am using my own application and i already installed the update 3.5.6 but no solution.
Also I noticed that these days FMS usage is high as compare to previous days (shows in FMS admin console)
My website url is http://live.samaa.tv
Please gudie me really its very urgent.
Thanks for the information.
Did you make sure that the connection management is well handled in your application server scripts ? There were other issues that we observed where the handling of connections on the server would be of very high significance.
Did you also change the server configuration, especially the autoclose idle connections ? I forgot whether you already mentioned but did you take a look at all the FMS logs ?
Thanks for your co-operation
I have checked the FMS log when streaming stoped i found the error in core.00.log file :
------------------------------------------------------------core.00.log---------------------------------------------------------------------------------------------
2011-08-02 07:13:36 8816 (w)2611173 TSorensonVideoSmartQueue would have dropped H264 sequence ender -
2011-08-02 07:13:38 8816 (w)2611173 TSorensonVideoSmartQueue would have dropped H264 sequence ender -
2011-08-02 07:13:43 8816 (w)2611173 TSorensonVideoSmartQueue would have dropped H264 sequence ender -
2011-08-02 07:13:46 8816 (w)2611173 TSorensonVideoSmartQueue would have dropped H264 sequence ender -
2011-08-02 07:13:50 8816 (w)2611173 TSorensonVideoSmartQueue would have dropped H264 sequence ender -
2011-08-02 11:49:20 8816 (i)2581247 Core (8816) disconnected from edge. -
#Date: 2011-08-02
#Fields: date time x-pid x-status x-ctx x-comment
2011-08-02 11:49:20 4816 (i)2581247 Core (4816) disconnected from edge. -
#Date: 2011-08-02
2011-08-02 11:49:20 2444 (i)2581247 Core (2444) disconnected from edge. -
2011-08-02 11:49:22 8816 (i)2581233 Core (8816) disconnecting from admin: 200. -
2011-08-02 11:49:22 4816 (i)2581233 Core (4816) disconnecting from admin: 200. -
#Date: 2011-08-02
2011-08-02 11:49:36 1632 (i)2581237 Starting admin app on core (1632). -
2011-08-02 11:49:36 1632 (i)2581238 Core (1632) connecting to admin. -
2011-08-02 11:49:36 1632 (i)2581231 Core (1632) connected to admin. -
2011-08-02 11:49:36 1632 (i)2581234 Core (1632) connection to admin accepted. -
2011-08-02 11:49:36 1632 (i)2581246 Core (1632) sending register cmd to edge. -
------------------------------------------------------------edge.00.log---------------------------------------------------------------------------------------------
2011-08-02 06:51:59 8316 (e)2581279 Assert failed in ..\FlashPlayer6_02_FlashCom\shared_tcserver\tcparser.cpp line 129 -
2011-08-02 07:13:23 8316 (e)2581279 Assert failed in ..\FlashPlayer6_02_FlashCom\shared_tcserver\tcparser.cpp line 129 -
2011-08-02 08:38:02 8316 (e)2581279 Assert failed in ..\FlashPlayer6_02_FlashCom\shared_tcserver\tcparser.cpp line 129 -
2011-08-02 08:50:55 8316 (e)2581279 Assert failed in ..\FlashPlayer6_02_FlashCom\shared_tcserver\tcparser.cpp line 129 -
2011-08-02 10:49:45 8316 (e)2581279 Assert failed in ..\FlashPlayer6_02_FlashCom\shared_tcserver\tcparser.cpp line 129 -
2011-08-02 10:52:06 8316 (e)2581279 Assert failed in ..\FlashPlayer6_02_FlashCom\shared_tcserver\tcparser.cpp line 129 -
2011-08-02 11:32:35 8316 (e)2581279 Assert failed in ..\FlashPlayer6_02_FlashCom\shared_tcserver\tcparser.cpp line 129 -
2011-08-02 11:49:20 8316 (i)2581250 Edge disconnected from core (2444). -
2011-08-02 11:49:20 8316 (i)2581250 Edge disconnected from core (8816). -
2011-08-02 11:49:20 8316 (i)2581250 Edge disconnected from core (4816). -
#Date: 2011-08-02
2011-08-02 11:49:33 1584 (i)2581173 FMS detected IPv6 protocol stack! -
2011-08-02 11:49:33 1584 (i)2581173 FMS config <NetworkingIPv6 enable=false> -
2011-08-02 11:49:33 1584 (i)2581173 FMS running in IPv4 protocol stack mode! -
2011-08-02 11:49:33 1584 (i)2581173 Host: SATV IPv4: 38.96.148.98 -
2011-08-02 11:49:34 1584 (i)2631174 Listener started ( _defaultRoot__edge1 ) : localhost:19350/v4 -
2011-08-02 11:49:34 1584 (i)2581252 Registering core (6616). -
2011-08-02 11:49:35 1584 (i)2631174 Listener started ( _defaultRoot__edge1 ) : 1935/v4 -
2011-08-02 11:49:36 1584 (i)2581252 Registering core (1632). -
2011-08-02 11:49:40 1584 (i)2581252 Registering core (2100). -
2011-08-02 11:57:31 1584 (i)2581250 Edge disconnected from core (2100). -
2011-08-02 11:57:31 1584 (i)2581250 Edge disconnected from core (1632). -
2011-08-02 11:57:31 1584 (i)2581250 Edge disconnected from core (6616). -
These are the log files now please guide me about these logs what thses logs says,
The logs errors look like there is an issue with the live content that you are receiving on the server. What encoder are you using ? Is it FMLE ?
Can you also please let us know other Video details ?
Earlier I am using FMLE but our company purchased a new third party encoder which is Digital Rapid Encoder.
Please below are the video setting in snap form.
Please let me know your online timing for chat coz i have some other issues.
Nikhil Pavan Kalyan,
Please guide me about this urgent issue.
Thanks in advance.
Can you try using on any other non-staging server with FMLE to see if you can reproduce the same issue ? I guess the encoder is sending sequence headers in an unexpected format. I am not sure if we can quickly reproduce it in house , depends on the availability of the DR encoder.
Thank you
I have switch my live stream from Digital Rapid encoder to FMLE but there is same log errors and same FMS condition after 1.5 hour stream is stop but FMS services is started which is showing is windows services.
After this encoder switching what do you think problem at FMS end or encoder end?
Thanks for trying with FMLE, that definitely removes encoder out of the problem.
Did you make any changes to the configuraiton of FMS after it is installed ? Please make sure the autoclose idle connections is set to false.
Is there any bandwidth limit that is set either in the xml files or on any server side script ? Probably that is hit and soon FMS disconnects the users to come down the limit ?
When the bandwidth comes down in the admin console , does the encoder disconnects ? (Either DR or FMLE ) , if not , FMS is still good and can take connections.
No i didn't make any changes in FMS configuration and there is no bandwidth limit set in XML files.
When bandwidht comes down and stream is disconnect from all users, FMLE and DR encoder is still connected with FMS.
can i reinstall the FMS? or even i give you the teamviewer acces of my server machine to see the FMS configuration.
Yes, i can take a look. Please send me the details @ npkalyan@adobe.com
Thank you !
I have sent the details on your email.
Nikhil, Please take a look of my server.
