Hi.
I've upgraded my dev env to flash Builder 4.5.
The IDE keeps crashing, even after increasing the jvm params to:
jvm_args: -Xms512m -Xmx512m -XX:MaxPermSize=512m -XX:PermSize=128m
The IDE can crash when I try to go to a class/method definition (F3), when I want to stop at a breakpoint, when navigating back to FB4.5 after using another application...
It can happen every few minutes, not very productive!!!
Can anyone offer any help?
Thanks, Eloise.
Did you make the jvm changes to eclipse.ini? Here is my eclipse.ini file and I do not have any real memory or crashing issues. (win7,64bit)
-startup plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
--launcher.library plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.2.R36x_v20101222
-product org.eclipse.epp.package.jee.product
--launcher.defaultAction openFile
--launcher.XXMaxPermSize 256M
-showsplash org.eclipse.platform
-vmargs
-XX:MaxPermSize=256m
-XX:PermSize=64m
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
Thanks for your answer.
do you use FB as a stand alone application or as eclipse plug-ins?
I modified the FlashBuilder.ini file residing under "C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.5", do you suggesst that I also modify the eclipse.ini file residing under "C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.5\eclipse"?
Thanks, Eloise.
This is the content of ym eclipse.ini:
-clean
-startup
plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.1.R36x_v20100810
-nl
en_US
-vmargs
-Xms256m
-Xmx512m
-XX:PermSize=64m
-Djava.net.preferIPv4Stack=true
-Dorg.eclipse.equinox.p2.reconciler.dropins.directory=dropins
-Declipse.application=com.adobe.flexbuilder.standalone.FlashBuilderApplication
I use the plug-in for eclipse. I expect that you modified the proper file for your environment (FlashBuilder.ini). Are you having any better luck with that configuration?
Yes, I modified the FlashBuilder.ini, to much higher values, and no luck :-(.
I think I will have to contact Adobe support, I can't work when the IDE crashes every few minutes...
Can you post the contents of your log file? (workspacedir/.metadata/.log)
-Anirudh
This is part of the log, if it doesn't help I can paste the entire content:
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:52.024
!MESSAGE Problems occurred refreshing resources
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:52.024
!MESSAGE Problem occurred in auto-refresh native code: 5.
!SESSION 2011-08-16 11:15:04.486 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 2 10035 2011-08-16 11:15:05.685
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ui 2 0 2011-08-16 11:15:08.147
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2011-08-16 11:15:08.147
!MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
!ENTRY org.eclipse.jface 2 0 2011-08-16 11:15:22.389
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2011-08-16 11:15:22.389
!MESSAGE A conflict occurred for CTRL+G:
Binding(CTRL+G,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.declarations.in.workspace,Declaration in Workspace,
Search for declarations of the selected element in the workspace,
Category(org.eclipse.search.ui.category.search,Search,Search command category,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+G,
ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace,
Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true),
LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.acti
This always appears after the IDE crashes: Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui',
Thanks, Eloise.
That looks normal. Can you post the rest?
-Anirudh
I hope I can paste such a long log...
!SESSION 2011-08-16 10:38:44.758 -----------------------------------------------
This is a continuation of log file C:\dev\replication\ui\workspace\.metadata\.bak_0.log
Created Time: 2011-08-16 10:53:06.235
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:06.236
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:06.236
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:07.287
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:07.287
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:08.338
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:08.338
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:09.346
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:09.346
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:10.397
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:10.397
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:11.449
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:11.449
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:12.501
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:12.501
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:13.552
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:13.552
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:14.603
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:14.603
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:15.655
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:15.655
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:16.706
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:16.706
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:17.758
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:17.758
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:18.810
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:18.810
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:19.861
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:19.861
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:20.913
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:20.913
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:21.964
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:21.964
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:23.015
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:23.015
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:24.066
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:24.066
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:25.118
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:25.118
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:26.170
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:26.170
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:27.222
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:27.222
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:28.274
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:28.274
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:29.326
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:29.326
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:30.378
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:30.378
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:31.432
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:31.432
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:32.484
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:32.484
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:33.816
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:33.816
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:34.868
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:34.868
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:35.925
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:35.925
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:36.977
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:36.977
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:38.030
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:38.030
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:39.081
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:39.081
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:40.133
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:40.133
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:41.186
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:41.186
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:42.237
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:42.237
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:43.289
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:43.289
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:44.341
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:44.341
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:45.393
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:45.393
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:46.444
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:46.444
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:47.496
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:47.496
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:48.548
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:48.548
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:49.601
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:49.601
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:50.653
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:50.653
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:51.704
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:51.704
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:52.755
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:52.755
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:53.797
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:53.797
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:54.806
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:54.806
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:55.821
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:55.821
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:56.859
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:56.859
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:57.908
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:57.908
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:58.960
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:58.960
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:00.011
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:00.011
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:01.062
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:01.062
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:02.114
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:02.114
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:03.166
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:03.166
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:04.218
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:04.218
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:05.269
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:05.269
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:06.321
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:06.321
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:07.376
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:07.376
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:08.428
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:08.428
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:09.480
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:09.480
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:10.532
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:10.532
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:11.583
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:11.583
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:12.635
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:12.635
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:13.687
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:13.687
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:14.738
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:14.738
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:15.790
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:15.790
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:16.842
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:16.842
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:17.894
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:17.894
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:18.946
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:18.946
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:19.997
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:19.997
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:21.049
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:21.049
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:22.101
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:22.101
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:23.153
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:23.153
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:24.204
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:24.204
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:25.256
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:25.256
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:26.261
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:26.261
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:27.313
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:27.313
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:28.365
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:28.365
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:29.420
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:29.420
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:30.472
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:30.472
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:31.527
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:31.527
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:32.579
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:32.579
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:33.947
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:33.947
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:34.999
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:34.999
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:36.051
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:36.051
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:37.103
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:37.103
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:38.155
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:38.155
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:39.206
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:39.206
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:40.258
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:40.258
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:41.310
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:41.310
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:42.361
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:42.361
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:43.413
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:43.413
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:44.465
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:44.465
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:45.517
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:45.517
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:46.569
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:46.569
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:47.621
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:47.621
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:48.673
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:48.673
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:49.725
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:49.725
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:50.777
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:50.777
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:51.829
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:51.829
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:52.881
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:52.881
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:53.933
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:53.933
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:54.985
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:54.985
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:56.037
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:56.037
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:57.088
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:57.088
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:58.140
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:58.140
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:59.154
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:59.154
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:00.206
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:00.206
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:01.258
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:01.258
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:02.309
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:02.309
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:03.368
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:03.368
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:04.420
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:04.420
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:05.471
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:05.471
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:06.523
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:06.523
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:07.574
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:07.574
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:08.626
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:08.626
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:09.678
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:09.678
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:10.730
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:10.730
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:11.781
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:11.781
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:12.833
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:12.833
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:13.885
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:13.885
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:14.936
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:14.936
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:15.987
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:15.987
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:17.039
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:17.039
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:18.093
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:18.093
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:19.096
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:19.096
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:20.148
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:20.148
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:21.199
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:21.199
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:22.250
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:22.250
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:23.302
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:23.302
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:24.332
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:24.332
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:25.359
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:25.359
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:30.011
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:30.011
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:31.063
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:31.063
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:32.115
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:32.115
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:33.167
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:33.167
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:34.219
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:34.219
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:35.223
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:35.223
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:36.275
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:36.275
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:37.327
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:37.327
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:38.379
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:38.379
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:39.432
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:39.432
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:40.487
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:40.487
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:41.538
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:41.538
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:42.590
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:42.590
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:43.642
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:43.642
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:44.694
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:44.694
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:45.767
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:45.767
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:46.819
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:46.819
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:47.871
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:47.871
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:48.923
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:48.923
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:49.974
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:49.974
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:51.026
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:51.026
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:52.040
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:52.040
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:53.061
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:53.061
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:54.113
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:54.113
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:55.165
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:55.165
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:56.209
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:56.209
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:57.261
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:57.261
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:58.281
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:58.282
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:59.333
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:59.333
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:00.381
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:00.381
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:02.631
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:02.631
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:03.683
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:03.683
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:04.734
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:04.734
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:05.786
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:05.786
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:06.837
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:06.837
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:07.888
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:07.888
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:08.940
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:08.940
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:09.992
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:09.992
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:11.044
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:11.044
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:12.095
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:12.095
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:13.147
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:13.147
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:14.198
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:14.198
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:15.249
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:15.249
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:16.301
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:16.301
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:17.310
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:17.310
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:20.762
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:20.762
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:21.795
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:21.795
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:22.847
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:22.847
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:23.898
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:23.898
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:24.903
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:24.903
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:25.954
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:25.954
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:27.106
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:27.106
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:28.158
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:28.158
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:29.200
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:29.200
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:30.252
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:30.252
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:31.303
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:31.303
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:32.354
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:32.354
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:33.405
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:33.405
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:34.456
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:34.456
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:35.507
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:35.507
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:36.558
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:36.558
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:37.609
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:37.609
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:38.660
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:38.660
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:39.712
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:39.712
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:40.764
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:40.764
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:41.816
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:41.816
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:42.867
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:42.867
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:43.919
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:43.919
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:44.971
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:44.971
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:46.064
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:46.064
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:47.115
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:47.115
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:48.167
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:48.167
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:49.219
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:49.219
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:50.260
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:50.260
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:51.801
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:51.801
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:52.853
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:52.853
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:53.907
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:53.907
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:54.959
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:54.959
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:56.010
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:56.010
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:57.062
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:57.062
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:58.114
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:58.114
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:59.165
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:59.165
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:00.181
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:00.181
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:01.191
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:01.191
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:05.342
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:05.342
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:06.374
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:06.374
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:07.426
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:07.426
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:08.478
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:08.478
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:09.529
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:09.529
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:10.581
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:10.581
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:11.633
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:11.633
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:12.684
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:12.684
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:13.740
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:13.740
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:14.792
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:14.792
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:15.910
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:15.910
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:16.961
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:16.961
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:18.013
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:18.013
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:19.065
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:19.065
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:20.117
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:20.117
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:21.169
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:21.169
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:22.221
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:22.221
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:23.272
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:23.272
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:24.324
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:24.324
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:25.381
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:25.381
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:26.386
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:26.386
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:27.438
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:27.438
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:28.490
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:28.490
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:29.532
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:29.532
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:30.583
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:30.583
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:31.610
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:31.610
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:32.662
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:32.662
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:33.713
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:33.713
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:34.765
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:34.765
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:35.817
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:35.817
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:36.869
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:36.869
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:37.921
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:37.921
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:38.973
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:38.973
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:39.979
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:39.979
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:41.030
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:41.030
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:42.071
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:42.071
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:43.725
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:43.725
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:44.748
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:44.748
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:45.804
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:45.804
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:46.855
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:46.855
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:47.924
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:47.924
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:18.317
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:18.317
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:19.372
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:19.372
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:21.443
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:21.443
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:22.495
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:22.495
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:23.546
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:23.546
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:24.597
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:24.597
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:25.623
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:25.623
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:26.674
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:26.674
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:27.729
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:27.729
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:28.781
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:28.781
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:29.850
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:29.850
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:30.904
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:30.904
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:31.956
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:31.956
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:33.007
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:33.007
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:34.058
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:34.058
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:35.110
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:35.110
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:36.161
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:36.161
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:37.213
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:37.213
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:38.264
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:38.264
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:39.316
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:39.316
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:40.368
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:40.368
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:41.373
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:41.373
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:42.425
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:42.425
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:43.476
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:43.476
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:44.528
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:44.528
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:45.580
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:45.580
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:46.632
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:46.632
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:47.683
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:47.683
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:48.685
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:48.685
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:49.736
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:49.736
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:50.788
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:50.788
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:51.839
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:51.839
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:52.841
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:52.841
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:53.892
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:53.892
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:54.943
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:54.943
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:55.994
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:55.994
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:57.046
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:57.046
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:58.097
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:58.097
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:59.148
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:59.148
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:00.199
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:00.199
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:01.252
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:01.252
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:02.304
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:02.304
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:03.359
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:03.359
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:04.373
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:04.373
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:05.440
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:05.440
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:06.491
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:06.491
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:07.542
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:07.542
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:08.594
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:08.594
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:09.645
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:09.645
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:10.647
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:10.647
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:11.698
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:11.698
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:12.750
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:12.750
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:13.801
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:13.801
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:14.852
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:14.852
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:15.903
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:15.903
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:16.955
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:16.955
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:18.006
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:18.006
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:19.057
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:19.057
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:20.109
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:20.109
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:21.161
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:21.161
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:22.212
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:22.212
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:23.264
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:23.264
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:24.315
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:24.315
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:25.371
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:25.371
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:26.389
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:26.389
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:27.452
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:27.452
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:28.504
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:28.504
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:29.558
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:29.558
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:30.609
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:30.609
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:31.684
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:31.684
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:32.736
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:32.736
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:33.803
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:33.803
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:34.854
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:34.854
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:35.905
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:35.905
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:36.956
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:36.956
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:38.008
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:38.008
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:39.087
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:39.087
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:40.139
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:40.139
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:41.190
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:41.190
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:42.227
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:42.227
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:43.278
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:43.278
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:44.329
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:44.329
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:45.527
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:45.527
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:46.579
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:46.579
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:47.630
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:47.630
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:48.682
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:48.682
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:49.708
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:49.708
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:50.760
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:50.760
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:51.811
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:51.811
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:52.862
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:52.862
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:53.913
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:53.913
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:54.965
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:54.965
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:56.016
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:56.016
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:57.067
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:57.067
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:58.118
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:58.118
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:59.153
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:59.153
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:00.204
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:00.204
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:01.255
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:01.255
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:02.306
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:02.306
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:03.346
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:03.346
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:04.367
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:04.367
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:05.422
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:05.422
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:06.443
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:06.444
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:07.498
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:07.498
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:08.549
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:08.549
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:09.619
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:09.619
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:10.634
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:10.634
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:11.689
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:11.689
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:12.741
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:12.741
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:13.796
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:13.796
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:14.847
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:14.847
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:15.899
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:15.899
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:16.950
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:16.950
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:18.002
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:18.002
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:19.053
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:19.053
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:20.104
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:20.104
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:21.155
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:21.155
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:22.207
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:22.207
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:23.258
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:23.258
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:24.312
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:24.312
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:25.364
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:25.364
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:26.416
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:26.416
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:27.468
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:27.468
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:28.520
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:28.520
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:29.571
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:29.571
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:30.623
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:30.623
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:31.636
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:31.636
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:32.688
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:32.688
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:33.693
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:33.693
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:34.745
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:34.745
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:35.796
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:35.796
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:36.848
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:36.848
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:37.900
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:37.900
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:38.951
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:38.951
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:40.002
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:40.002
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:41.053
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:41.053
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:42.086
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:42.086
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:43.138
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:43.138
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:44.189
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:44.189
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:45.241
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:45.241
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:46.292
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:46.292
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:47.346
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:47.346
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:48.349
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:48.349
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:49.404
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:49.404
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:50.455
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:50.455
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:51.510
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:51.510
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:52.562
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:52.562
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:53.617
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:53.617
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:54.669
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:54.669
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:55.724
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:55.724
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:56.776
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:56.776
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:57.867
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:57.867
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:58.919
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:58.919
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:59.970
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:59.970
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:01.021
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:01.021
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:02.072
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:02.072
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:03.123
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:03.123
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:04.174
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:04.174
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:05.225
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:05.225
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:06.277
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:06.277
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:07.333
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:07.333
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:08.377
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:08.377
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:09.429
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:09.429
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:10.480
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:10.480
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:11.496
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:11.496
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:12.548
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:12.548
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:13.599
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:13.599
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:14.650
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:14.650
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:15.701
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:15.701
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:16.752
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:16.752
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:17.803
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:17.803
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:18.854
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:18.854
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:19.863
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:19.863
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:20.877
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:20.877
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:21.928
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:21.928
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:22.979
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:22.979
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:24.031
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:24.031
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:25.082
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:25.082
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:26.133
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:26.133
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:27.185
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:27.185
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:28.236
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:28.236
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:29.288
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:29.288
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:30.346
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:30.346
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:31.399
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:31.399
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:32.448
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:32.448
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:33.515
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:33.515
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:34.622
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:34.622
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:36.408
!MESSAGE Problems occurred refreshing resources
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:36.408
!MESSAGE Problem occurred in auto-refresh native code: 5.
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:38.049
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:38.049
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:39.101
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:39.101
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:40.167
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:40.167
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:41.231
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:41.231
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:42.296
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:42.296
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:43.389
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:43.389
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:44.457
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:44.457
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:45.524
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:45.524
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:46.576
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:46.576
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:47.628
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:47.628
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:48.693
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:48.693
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:49.759
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:49.759
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:50.811
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:50.811
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:51.863
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:51.863
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:52.870
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:52.870
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:53.922
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:53.922
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:54.974
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:54.974
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:56.026
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:56.026
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:57.381
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:57.381
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:06.743
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:06.743
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:16.095
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:16.095
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:25.691
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:25.691
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:35.059
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:35.059
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:44.362
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:44.362
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:53.713
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:53.713
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:02.892
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:02.892
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:04.534
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:04.534
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:05.592
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:05.592
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:06.658
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:06.658
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:07.737
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:07.737
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:08.798
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:08.798
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:09.873
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:09.873
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:10.980
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:10.980
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:12.651
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:12.651
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:13.719
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:13.719
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:14.731
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:14.731
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:15.797
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:15.798
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:17.149
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:17.149
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:26.500
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:26.500
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:35.852
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:35.852
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:45.219
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:45.219
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:54.571
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:54.571
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:03.922
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:03.922
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:13.242
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:13.242
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:22.307
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:22.307
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:23.658
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:23.658
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:32.773
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:32.773
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:33.825
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:33.825
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:34.891
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:34.891
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:35.956
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:35.956
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:37.058
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:37.058
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:38.609
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:38.609
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:39.678
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:39.678
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:41.029
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:41.029
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:50.380
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:50.380
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:59.732
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:59.732
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:09.102
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:09.102
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:18.460
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:18.460
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:27.812
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:27.812
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:37.184
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:37.184
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:46.535
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:46.535
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:55.886
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:55.886
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:05.249
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:05.249
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:14.600
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:14.600
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:33.301
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:33.301
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:42.673
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:42.673
!ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:52.024
!SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:52.024
!SESSION 2011-08-16 11:15:04.486 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 2 10035 2011-08-16 11:15:05.685
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ui 2 0 2011-08-16 11:15:08.147
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2011-08-16 11:15:08.147
!MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
!ENTRY org.eclipse.jface 2 0 2011-08-16 11:15:22.389
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2011-08-16 11:15:22.389
!MESSAGE A conflict occurred for CTRL+G:
Binding(CTRL+G,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.declarations.in.workspace,Declaration in Workspace,
Search for declarations of the selected element in the workspace,
Category(org.eclipse.search.ui.category.search,Search,Search command category,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+G,
ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace,
Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true),
LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@12d6d82)),
,,true),null),
com.adobe.flexide.editorcore.flexEditorScope,,,system)
Binding(CTRL+G,
,,true),null),
com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system)
!MESSAGE A conflict occurred for CTRL+SHIFT+G:
Binding(CTRL+SHIFT+G,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.references.in.workspace,References in Workspace,
Search for references to the selected element in the workspace,
,,true),null),
ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.workspace,Find All References In Workspace,
LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@170736f)),
,,true),null),
,,true),null),
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:25.455
!MESSAGE Unsupported design description file libs/tink_flex4_spark.swc
root tag: expected = design, actual = design
version: expected = 2, actual =
!STACK 0
java.lang.Exception
at com.adobe.flexbuilder.project.internal.FlexProjectCore.createErrorStatus(FlexProjectCore.java:1010)
at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:66)
at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:52)
at com.adobe.flexide.designitems.types.DesignExtensions.buildTree(DesignExtensions.java:106)
at com.adobe.flexide.designitems.types.DesignExtensions.<init>(DesignExtensions.java:74)
at com.adobe.flexide.designitems.types.DesignTypeRegistry.<init>(DesignTypeRegistry.java:61)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.<init>(MXMLDesignView4Controller.java:216)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignViewFactory.createController(MXMLDesignViewFactory.java:42)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.initDesignView(MXMLDesignEditor.java:1793)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.initializeDesignView(MXMLDesignEditor.java:1713)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.initializeDesignView(MXMLDesignEditor.java:1730)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.embeddedAssetCompilationOver(MXMLDesignEditor.java:2736)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.assetCompilationCompleted(MXMLDesignEditor.java:4002)
at com.adobe.flexide.editorcore.dvswfbuilder.EmbeddedAssetsSWFBuilder$3.run(EmbeddedAssetsSWFBuilder.java:1126)
at org.eclipse.swt.widgets.Display.runTimer(Display.java:4167)
at org.eclipse.swt.widgets.Display.messageProc(Display.java:3256)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2459)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3655)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
!ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 11:15:29.541
!MESSAGE Design view: Failed to load library.swf from C:\dev\replication\ui\attunity.replication.views\libs\visualizer.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:29.779
!STACK 0
java.lang.Exception
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$LoaderListener$1.run(MXMLDesignView4Controller.java:1105)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$6.run(MXMLDesignView4Controller.java:2774)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
!ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 11:15:33.202
!MESSAGE Design view: Failed to load library.swf from C:\dev\replication\ui\attunity.replication.views\libs\diagrammer.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:33.439
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 11:15:37.867
!MESSAGE Design view: Failed to load library.swf from C:\dev\replication\ui\attunity.replication.views\libs\visualizerMultitouch.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:38.093
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:39.678
!MESSAGE Error loading ClassReference for attunity.replication.views.skins.DefaultTitleWindowSkin
!STACK 0
java.lang.Exception
at com.adobe.flexbuilder.project.internal.FlexProjectCore.log(FlexProjectCore.java:858)
at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:56)
at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:41)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$DesignViewCallbacks.reportInternalError(MXMLDesignView4Controller.java:603)
at com.adobe.flexide.playerview.DesignCall.invoke(DesignCall.java:96)
at com.adobe.flexide.playerview.PlayerListenerHost.notifyDesignCall(PlayerListenerHost.java:173)
at com.adobe.flexide.playerview.PlayerListenerHost.callFunction(PlayerListenerHost.java:47)
at com.adobe.flexide.embeddedplayer.PlayerNativeCallbacks.CallJavaFunction(PlayerNativeCallbacks.java:48)
at com.adobe.flexide.embeddedplayer.PlayerNatives.CallActionScript(Native Method)
at com.adobe.flexide.embeddedplayer.ExternalPlayer.callFunction2(ExternalPlayer.java:94)
at com.adobe.flexide.playerview.PlayerCaller.callFunction(PlayerCaller.java:73)
at com.adobe.flexide.playerview.PlayerCaller.callFunctionNoResult(PlayerCaller.java:44)
at com.adobe.flexide.designitems.styles.DesignStylist.applyStyles(DesignStylist.java:267)
at com.adobe.flexide.designitems.styles.DesignStylist.refreshStyles(DesignStylist.java:226)
at com.adobe.flexide.designitems.styles.DesignStylist.updateStyles(DesignStylist.java:196)
at com.adobe.flexide.designitems.surface.DesignSurface.visitModel(DesignSurface.java:1014)
at com.adobe.flexide.designitems.surface.DesignSurface.install(DesignSurface.java:236)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.finishDesignSurfaceInstall(MXMLDesignView4Controller.java:437)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.access$21(MXMLDesignView4Controller.java:433)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$1.notifyAllSwfsLoaded(MXMLDesignView4Controller.java:416)
at com.adobe.flexide.designitems.surface.FXGComponentManager.notifyAllSwfsLoaded(FXGComponentManager.java:570)
at com.adobe.flexide.designitems.surface.FXGComponentManager.loadAllSWFs(FXGComponentManager.java:557)
at com.adobe.flexide.designitems.surface.FXGComponentManager.scanModel(FXGComponentManager.java:505)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.installDesignSurface(MXMLDesignView4Controller.java:421)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.runtimeStylesLoaded(MXMLDesignView4Controller.java:1781)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.loadRuntimeStyleDeclarations(MXMLDesignView4Controller.java:1204)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.embeddedAssetsSwfLoaded(MXMLDesignView4Controller.java:1762)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.continueWithEmbeddedAssetLoading(MXMLDesignView4Controller.java:1740)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.libraryPathSwfsLoaded(MXMLDesignView4Controller.java:1643)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$LoaderListener.loadComplete(MXMLDesignView4Controller.java:1084)
at com.adobe.flexide.designitems.loaders.LibrarySWCLoader.loadNextSWF(LibrarySWCLoader.java:93)
at com.adobe.flexide.designitems.loaders.LibrarySWCLoader.access$5(LibrarySWCLoader.java:89)
at com.adobe.flexide.designitems.loaders.LibrarySWCLoader$SwcLoaderCallbacks.SWFLoaded(LibrarySWCLoader.java:156)
at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source)
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:39.681
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:39.709
!MESSAGE Error loading ClassReference for attunity.replication.views.skins.DefaultListSkin
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:20:05.216
!STACK 0
java.lang.Exception
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.initializeDesignViewFromCodeView(MXMLDesignEditor.java:3900)
at com.adobe.flexbuilder.mxml.editor.MXMLEditor$6.run(MXMLEditor.java:1366)
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:20:06.826
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:20:06.830
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:20:06.858
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:27:23.208
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:27:24.868
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:27:24.871
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:27:24.898
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:13.624
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.201
!STACK 0
java.lang.Exception
at sun.reflect.GeneratedMethodAccessor55.invoke(Unknown Source)
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.204
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.231
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.942
!MESSAGE StyleModelManager.setDocumentModel called when document model already set
!STACK 0
java.lang.Exception
at com.adobe.flexide.designitems.styles.StyleModelManager.setDocumentModel(StyleModelManager.java:102)
at com.adobe.flexide.designitems.styles.DesignStylist.setDocumentModel(DesignStylist.java:107)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.createDesignSurface(MXMLDesignView4Controller.java:384)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.installDesignSurface(MXMLDesignView4Controller.java:404)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.assetCompilationOver(MXMLDesignView4Controller.java:1669)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.sendAssetCompilationCompletedInfoToController(MXMLDesignEditor.java:4031)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.sendCompilationSatausToController(MXMLDesignEditor.java:4046)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.createEmbeddedAssetBuilder(MXMLDesignEditor.java:1962)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.access$19(MXMLDesignEditor.java:1945)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor$4.run(MXMLDesignEditor.java:2661)
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.961
!MESSAGE StyleModelManager.setBaseDocumentModel called when base document model already set
!STACK 0
java.lang.Exception
at com.adobe.flexide.designitems.styles.StyleModelManager.setBaseDocumentModel(StyleModelManager.java:84)
at com.adobe.flexide.designitems.styles.DesignStylist.setBaseDocumentModel(DesignStylist.java:115)
at com.adobe.flexide.designitems.surface.DesignSurface.applyMainAppStyles(DesignSurface.java:1028)
at com.adobe.flexide.designitems.surface.DesignSurface.visitModel(DesignSurface.java:1012)
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:16.467
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:18.136
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:18.139
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:18.167
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:21.608
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:23.265
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:23.268
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:23.295
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:30.688
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:32.291
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:32.293
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:32.321
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:33.174
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:33.194
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:33.732
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:35.275
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:35.278
!STACK 0
java.lang.Exception
at sun.reflect.GeneratedMethodAccessor57.invoke(Unknown Source)
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:35.305
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:43:23.270
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:43:24.824
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:43:24.827
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:43:24.855
!STACK 0
java.lang.Exception
!SESSION 2011-08-16 12:09:27.189 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2011-08-16 12:09:28.399
!ENTRY org.eclipse.ui 2 0 2011-08-16 12:09:30.993
!SUBENTRY 1 org.eclipse.ui 2 0 2011-08-16 12:09:30.993
!ENTRY org.eclipse.jface 2 0 2011-08-16 12:09:45.710
!SUBENTRY 1 org.eclipse.jface 2 0 2011-08-16 12:09:45.710
Binding(CTRL+G,
,,true),null),
Binding(CTRL+G,
LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@149e05d)),
,,true),null),
Binding(CTRL+G,
,,true),null),
,,true),null),
LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@ddf639)),
,,true),null),
,,true),null),
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:09:46.980
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 12:09:51.238
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:09:51.472
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 12:09:54.852
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:09:55.080
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 12:09:58.611
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:09:58.843
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:10:00.423
!STACK 0
java.lang.Exception
at sun.reflect.GeneratedMethodAccessor40.invoke(Unknown Source)
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:10:00.427
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:10:00.455
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:23.388
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:25.079
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:25.085
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:25.112
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:26.130
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:26.159
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:26.744
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:28.339
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:28.342
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:28.370
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:13:13.423
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:13:15.005
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:13:15.008
!STACK 0
java.lang.Exception
!ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:13:15.037
!STACK 0
java.lang.Exception
Thanks, Eloise.
Okay, the log indicates that design view has trouble loading your skins.
Can you try disabling design view to see if it crashes? (Uncheck Window menu -> Enable Design mode)
-Anirudh
I unchecked the option, and will update you in a few hours if the editor is more stable.
Thanks, Eloise.
This seems to have solved the problem, thanks, Eloise.
