I have no trace output when I Debug an AIR desktop application. Was working in FB 4.5, prior to FB 4.5.1 update
What happened to my trace output / how do I restore proper functionality for debugging?
Everything appears functional -- just no traces..
i had the exact same pb (i'm on MacOSX btw)
solved it by adding -compiler.debug option to amxmlc command line so to force debug information to be included
ex: amxmlc Test2.as -compiler.debug
i have no idea why it doesn't take the (correct) default values which is set in frameworks/air-config.xml
but anyway forcing it worked
Thanks !!
