Hi
I'm trying to debug PHP services with ZendDebugger
I install correctly the ZendDebugger with Appserv with this code in php.ini
[Zend]
zend_extension_ts=C:/AppServ/php5/ext/ZendDebugger.dll
zend_debugger.allow_hosts=192.168.0.2, 127.0.0.1
zend_debugger.expose_remotely=always
with phpinfo() function I can see that the debugger is installed
Setup my project firstable creating a PHP project in Flash Builder and then Change/Add Project type to Flex Project
Inside Debug Configurations Add a PHP Web Page and setup to my PHP Class
Connect the services and works fine but if set breakpoints inside my php file the debugger doesn't work
Anybody can help me
I can debug a simple php file
But if use a php class with my services and debug, the debugger does not stop on my php file
I am having a similar problem. I can't even debug a simple php file. Breakpoints did work correctly for a little while. But one day they just seemed to stop working. Did you ever figure this one out?
