1. Re: Lion, Quicktime Screen-capture, and Photoshop
Chris Cox Aug 2, 2011 9:51 AM (in response to bsnyder175)Sounds like Apple changed something in their screen capture code.
2. Re: Lion, Quicktime Screen-capture, and Photoshop
bsnyder175 Aug 3, 2011 5:41 AM (in response to Chris Cox)Were you able to test this out, Chris? And if so, did you see the same issue I ran into?
3. Re: Lion, Quicktime Screen-capture, and Photoshop
Metryq Aug 6, 2011 10:51 AM (in response to bsnyder175)Under OS X "Lion," every screen capture tool I have (Snapz Pro X, Screenflow, Layers, iShowU HD Pro) will no longer capture a DVD frame—if the DVD is being played by Apple's DVD Player. The resulting screen cap shows a "transparent" window. VLC still works in that regard. I've also noticed that the iTunes app no longer has a free-floating video window, which was always my preference. Videos now show within the boundaries of the iTunes window, or full-frame. One more note on Apple DVD Player is that invoking full-frame playback will slide in a new "space" with a background similar to that seen on iPads or behind the Desktop Widgets.
I realize capturing DVDs is not what you're trying to do, but all of the above indicates a complete change to the way OS X handles any streamed video. I have yet to make a test, but I suspect that output-to-NTSC through monitor ports may also be inhibited for certain things; Apple may be plugging the "analog hole" with software. My guess is that whatever background routines are responsible for this may be sufficient to slow the frame rate of your tutorial captures—in the same way that heightened security at airports now significantly slows boarding procedures.
