This is regarding the issue "CHW file created", following is problem statement, review the same and provide your inputs. Thanks in advance.
create a product with an installer, etc, that includes not only the product binaries but also a Help file (.chm) as well. The customer installs the product into the default location. The product -- and its associated .chm Help file too! -- all get installed into the C:\Program Files\FooBarCo\ProdName directory. So far so good.
The customer decides to uninstall the product. The uninstaller removes everything it added to that directory. Since it did not add the .chw file, it doesn't get deleted.
Now the customer sees a .chw file that still exists in our product's directory and calls us asking why our product failed to properly uninstall itself: "
We could easily re-design our uninstaller to always delete all/any .chw files it finds in the product directory, but is that the correct solution? It seems risky to me.
Colum explained what the CHW file does earlier in this thread.
See also http://en.wikipedia.org/wiki/Microsoft_Compiled_HTML_Help and search on CHW.
I believe the filename will always be the same as you CHM so you can program to uninstall it.
Peter is right. The CHW file takes its name from the CHM file name. So a file called HTMLHELP.CHM would create a file called HTMLHelp.CHW.
The RoboColum(n) | @robocolumn | Colum McAndrew |
Hi, Colum and others contributing to this thread:
I just received a new Windows 7 machine. I am seeing this exact same behavior when I access the index of a .chm I created on an XP machine, compiled using RH9 through TCS3. The source is all, wholly, in FM10 and I have not merged any other source into the compile. I will be submitting this as a bug momentarily. I cannot have this behavior on systems that our customers use out in the field. My workaround is to ensure that the .chm isn't on the desktop, so the user isn't aware of the .chw's creation. Since the .chm is in a folder that the users aren't likely to access, chances are that they'll never see it; additionally, thankfully, Windows 7 isn't making any noises about overwriting the .chw in the related folder.
Burtin
You say you are not installing it to the desktop. It cannot be on a network drive so where are you installing it?
It's on a local drive for every machine, and a registry tweak takes care of the security zone issue. There's more at: http://support.microsoft.com/kb/896358.
I am aware of that registry edit and it is covered in http://www.grainge.org/pages/authoring/chm_mspatch/896358.htm along with another solution. However that is only required for CHMs that are on a network drive.
When you said about the CHM not being on the desktop that implied it was on a network drive, hence my post to check you were aware of the security issue. Now however you are saying the CHM is local but the registry has been edited. That shouldn't be necessary.
I will check with IT to confirm what I stated about the registry edit. I brought it to their attention. That, however, still does not detract from the fact that .chw files are being spawned and should not be.
I'm not arguing that point.
What I was getting at was simply that the registry edit should not be necessary unless you are putting the help on a server. Also pointing out that if you are editing the user's registry, there is an alternative to that which you might prefer until the real problem is fixed.
My error, and my apologies. IT read the information I'd sent them and stored the .chm locally. They are aware of the registry modifications and opted out. The .chw-spawning issue appears to be a bug, as I reported. I have replicated the issue with .chm files generated/viewed on several different (XP and Win7) machines.
