13 Replies Latest reply on Aug 8, 2011 1:34 AM by hsu.shan.chuang
    Type was not found or was not a compile-time constant: ImportExportConfiguration
    gauravk.pandey Level 1
           I am using text layout framework and getting an error type was not found or was not a compile-time constant: ImportExportConfiguration. I am using Flex Builder 3 , Flex SDK version flex_sdk_4.0.0.10485 and flash player 10.0.12 , Surprisingly this error not located in my project workspace.
      In my code i uses
      import flashx.textLayout.container.DisplayObjectContainerController;
      Help
      Gaurav kumar Pandey
        • 1. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
          robin.briggs Adobe Employee
          You are using an older version of our code. I suggest you update to the latest code, see: http://opensource.adobe.com/wiki/display/flexsdk/Flex+SDK.
          You don't need to use the Flex Framework, but it comes with the latest textLayout libraries and source code.
          Hope this helps,
          - robin
          • 2. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
            Thanks Robin,
                I have solved the problem but fall under the new problem what i did used the sdk version flex_sdk_4.0.0.6175 and it shows a new prblem Severity and Description    Path    Resource    Location    Creation Time    Id
            1046: Type was not found or was not a compile-time constant: [flashx.textLayout.elements]::ITextLineCreator.
            plese help me
            Thanks and regards ,
            Gaurav kumar pandey
            • 3. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
              Can you tell me what is the code you are trying to run? You have TLF, and you are trying to run it with some code. Can you tell me what that code is? Does it work with a very simple example? ITextLineCreator is an old API, that is not present in the new code. But if you are trying to run TLF with some old example code, that could explain your difficulty.
              - robin
              • 4. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                Thanks Robin fro ur help i got the error i was using the old API now i have
                solved this but can there is any document that enlist the API for the new
                TLF changes
                • 5. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                  Glad you got it working!
                  If you build the build.xml that comes with TLF, it will build the docs for you. You can do this using Ant. The docs for TLF are not posted online yet.
                  - robin
                  • 6. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                    Alan Stearns Adobe Employee
                    You can also get the documentation for a particular Flex SDK 4 build under the "Language Reference" links here:
                    http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+4
                    This will include the docs for the TLF build that SDK uses.
                    • 7. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                      Nitika_Ag
                      Hi Gaurav,
                      How were you able to solve that problem... "" 1046: Type was not found...:ImportExportConfiguration""
                      I want to shift my project from flex SDK 3.5 to 4.0 and m facing this error.
                      Were you earlier working in flex 3.5.
                      Help
                      Nitika Agarwal
                      • 8. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                        Hi Nikita,
                        Sry for the delayed response, there is two possibility for that:
                        1. If you using Flex  Builder
                        •   Then put your sdk uncompressed folder in your flex builder sdk/ directory path, do one thing also first remove your flex sdk 3.5 from /sdk folder of flex bulder refrenced your flex 4 sdk as a default sdk and cleane your Flex builder from run , and write following command:
                              path of your flex bulder exe //pro file/adobe... put a space and write -cleane option
                        • Also check your fash player it must target flash player 10.
                        • go to adobe site how to extrenally point flash player 10, since there is a good tutorial there so i wont write it.
                        After error removed put back your removed sdk 3.5 to it's original location
                        2. If you using flash builder 4 then no need to do all the above exercise just change the Flex sdk version(if point flex sdk 3.5 ) to sdk 4.0.
                        Hope above solve your problem.
                        FAny further query or suggestion is most welcome
                        Gaurav Kumar Pandey
                        • 9. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                          singh.dhruv
                          hi,
                          I got same issue but in custome componets.
                          like:
                          Type was not found or was not a compile-time constant: spinner
                          Type was not found or was not a compile-time constant: winprogress
                          Is any one know why this happen ?
                          dhruv
                          • 10. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                            I don't think these are TLF errors. Can you tell me what you're trying to build?
                            - robin
                            • 11. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                              hsu.shan.chuang
                              I have same problem with can't use  TextConverter.importToFlow(...) , it show "type was not found or was not a compile-time constant: ImportExportConfiguration".My lib have a textLayout.swc component and I use it,my code as flow :
                              import .... ;
                              public class SimpleEditor extends MovieClip
                                private var _textFlow:TextFlow;
                                public function SimpleEditor ()
                                 var loader:URLLoader = new URLLoader();
                                 loader.load (new URLRequest("SimpleText.xml"));
                                 loader.addEventListener (Event.COMPLETE, loadCompleteHandler);
                                private function loadCompleteHandler (e:Event):void
                                _textFlow = TextConverter.importToFlow( e.target.data,TextConverter.TEXT_FIELD_HTML_FORMAT);
                              why ? if I delete  textLayout.swc  from my lib, it can work !
                              • 12. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                                hi,
                                What I am guseeyou uses Flex4 sdk with your application and your lib folder contain older version of textlayout.swc. Once you removed this swc from lib folder your code will point textlayout.swc from Flex 4 sdk folder, and when you have older version of textlayout.swc in your lib folder your code will target to that swc .
                                Hope you get the answer .Happy programming with TextLayoutFramework.
                                Gaurav Pandey
                                • 13. Re: Type was not found or was not a compile-time constant: ImportExportConfiguration
                                  hsu.shan.chuang Level 1
                                  It still can't work ! I use Flash CS5 and sdk is 4.0.In publish setting it have textLayout.swc and flex.swc form path of lib.When I add  TextConverter.export(..),it show Error 1046: Type was not found or was not a compile-time constant: importExportConfiguration.My code as flow :
                                  package
                                  import flashx.textLayout.elements.TextFlow;
                                  import flashx.textLayout.formats.IParagraphFormat;
                                  import flashx.textLayout.formats.ParagraphFormat;
                                  import flashx.textLayout.formats.ICharacterFormat;
                                  import flashx.textLayout.formats.CharacterFormat;
                                  import flashx.textLayout.formats.IContainerFormat;
                                  import flashx.textLayout.formats.ContainerFormat;
                                  import flashx.textLayout.formats.TextAlign;
                                  import flashx.textLayout.edit.EditManager;
                                  import flashx.textLayout.edit.UndoManager;
                                  import flashx.textLayout.edit.ElementRange;
                                  import flashx.textLayout.edit.IEditManager;
                                  import flashx.textLayout.events.StatusChangeEvent;
                                  import flashx.textLayout.events.SelectionEvent;
                                  import flash.events.Event;
                                  import flash.events.KeyboardEvent;
                                  import flash.events.IOErrorEvent;
                                  import flash.net.URLLoader;
                                  import flash.net.URLRequest;
                                  import flash.display.MovieClip;
                                  import flash.display.Stage;
                                  import flash.display.StageScaleMode;
                                  import flash.display.StageAlign;
                                  import flash.ui.Keyboard;
                                  import flash.text.Font;
                                  import flash.geom.Rectangle;
                                  import flashx.textLayout.conversion.ConversionType;
                                  import flash.events.MouseEvent;
                                  import flashx.textLayout.conversion.TextConverter;
                                  import flashx.textLayout.container.ContainerController;
                                  import fl.events.ColorPickerEvent;
                                  import fl.motion.Color;
                                  import flash.geom.ColorTransform;
                                          private var testFlow:TextFlow;
                                     TextFlow.defaultConfiguration.noFocusSelectionFormat = TextFlow.defaultConfiguration.focusSelectionFormat;
                                     //initWidgets ();
                                     //initStage ();
                                     myTextLayout.xmlText = e.target.data;
                                     initTextFlow ();
                                         private function initTextFlow ():void
                                     _textFlow = myTextLayout.textFlow;
                                              _textFlow.addEventListener (StatusChangeEvent.INLINE_GRAPHIC_STATUS_CHANGED, graphicChanged);
                                     _textFlow.addEventListener (SelectionEvent.SELECTION_CHANGE,selectionChangeListener,false,0,true);
                                     _textFlow.flowComposer.updateAllContainers ();
                                     _textFlow.interactionManager.setSelection (0,0);
                                     _textFlow.interactionManager.setFocus ();
                                    var xmlOut:XML = TextConverter.export(_textFlow,TextConverter.TEXT_LAYOUT_FORMAT,ConversionType.XML_TYPE) as XML;
                                         private function initWidgets ():void
                                     populateFontFamily ();
                                     direction.addEventListener (Event.CHANGE, changeDirection);
                                     blockprogression.addEventListener (Event.CHANGE, changeBlockProgression);
                                     verticalalign.addEventListener (Event.CHANGE, changeVerticalAlign);
                                     columngap.addEventListener (KeyboardEvent.KEY_UP, changeColumnGap);
                                     columncount.addEventListener (KeyboardEvent.KEY_UP, changeColumnCount);
                                     textindent.addEventListener (KeyboardEvent.KEY_UP, changeTextIndent);
                                     textalign.addEventListener (Event.CHANGE, changeTextAlign);
                                     lineheight.addEventListener (KeyboardEvent.KEY_UP, changeLineHeight);
                                     fontsize.addEventListener (KeyboardEvent.KEY_UP, changeFontSize);
                                     fontfamily.addEventListener (Event.CHANGE, changeFontFamily);
                                     btnItalic.addEventListener (MouseEvent.CLICK, changeFontItalic);
                                     btnBold.addEventListener (MouseEvent.CLICK, changeFontBold);
                                     fromPicker.addEventListener (ColorPickerEvent.CHANGE, changeColor);
                                    private function initStage ():void
                                     stage.scaleMode = StageScaleMode.NO_SCALE;
                                     stage.align = StageAlign.TOP_LEFT;
                                     stage.addEventListener (Event.RESIZE, resizeHandler);
                                        private function populateFontFamily ():void
                                     // try to add fonts to the drop down
                                     var fonts:Array = Font.enumerateFonts(true);
                                     fonts.sortOn ("fontName", Array.CASEINSENSITIVE);
                                     for (var i:int = 0; i< fonts.length; i++)
                                      fontfamily.dataProvider.addItem ({label: fonts[i].fontName, data: fonts[i].fontName});
                                      //trace( fonts[i].fontName);
                                      private function graphicChanged (sce:StatusChangeEvent):void
                                     _textFlow.flowComposer.updateAllContainers();
                                    private function selectionChangeListener (e:SelectionEvent):void
                                     // set display according to the values at the beginning of the selection range
                                     var paragraphFormat:IParagraphFormat = e.selectedElementRange.paragraphFormat;
                                     var characterFormat:ICharacterFormat = e.selectedElementRange.characterFormat;
                                     var containerFormat:IContainerFormat = e.selectedElementRange.containerFormat;
                                     // update the different comboboxes so their selectedItem matches the current selection
                                     updateComboBox (fontfamily, characterFormat.fontFamily);// font family
                                     updateComboBox (textalign, paragraphFormat.textAlign);// text alignment
                                     updateComboBox (verticalalign,containerFormat.verticalAlign);// vertical alignment
                                     updateComboBox (blockprogression,_textFlow.computedContainerFormat.blockProgression);// block progressions
                                     updateComboBox (direction,_textFlow.getComputedColumnDirection());// direction
                                     // update the different text input entries
                                     fontsize.text = characterFormat.fontSize.toString();// font size
                                     lineheight.text = characterFormat.lineHeight.toString();// line height
                                     textindent.text = paragraphFormat.textIndent.toString();// indentation
                                     columncount.text = containerFormat.columnCount.toString();// number of columns
                                     columngap.text = containerFormat.columnGap.toString();// gaps/gutter width
                                     //TextConverter.export(_textFlow,TextConverter.TEXT_LAYOUT_FORMAT,ConversionType.XML_TYPE );
                                    private function updateComboBox (box:ComboBox,val:String):void
                                     for (var i:int = 0; i < box.dataProvider.length; i++)
                                      if (box.dataProvider.getItemAt(i).data == val)
                                       box.selectedIndex = i;
                                       return;
                                     box.text = val;
                                    private function changeFontFamily (e:Event):void
                                     if (_textFlow && _textFlow.interactionManager is IEditManager)
                                      var cf:CharacterFormat = new CharacterFormat();
                                      cf.fontFamily = ComboBox(e.currentTarget).selectedItem.data;
                                      IEditManager(_textFlow.interactionManager).applyCharacterFormat (cf);
                                    private function changeFontSize (ke:KeyboardEvent):void
                                     if (_textFlow && _textFlow.interactionManager is IEditManager && ke.keyCode == Keyboard.ENTER)
                                      cf.fontSize = TextInput(ke.currentTarget).text;
                                    private function changeFontItalic (e:MouseEvent):void
                                      cf.fontStyle="italic";
                                    private function changeFontBold (e:MouseEvent):void
                                      cf.fontWeight="bold";
                                    private function changeColor (e:ColorPickerEvent):void
                                      var clipTransform:ColorTransform=new ColorTransform();
                                      clipTransform.color=fromPicker.selectedColor;
                                      cf.color=clipTransform.color;
                                    private function changeLineHeight (ke:KeyboardEvent):void
                                      cf.lineHeight = TextInput(ke.currentTarget).text;
                                    private function changeTextAlign (e:Event):void
                                      var pf:ParagraphFormat = new ParagraphFormat();
                                      pf.textAlign = ComboBox(e.currentTarget).selectedItem.data;
                                      IEditManager(_textFlow.interactionManager).applyParagraphFormat (pf);
                                    private function changeTextIndent (ke:KeyboardEvent):void
                                      pf.textIndent = TextInput(ke.currentTarget).text;
                                    private function changeColumnCount (ke:KeyboardEvent):void
                                      var cf:ContainerFormat = new ContainerFormat();
                                      cf.columnCount = TextInput(ke.currentTarget).text;
                                      IEditManager(_textFlow.interactionManager).applyContainerFormat (cf);
                                    private function changeColumnGap (ke:KeyboardEvent):void
                                      cf.columnGap = TextInput(ke.currentTarget).text;
                                    private function changeVerticalAlign (e:Event):void
                                      cf.verticalAlign = ComboBox(e.currentTarget).selectedItem.data;
                                    private function changeBlockProgression (e:Event):void
                                      cf.blockProgression = ComboBox(e.currentTarget).selectedItem.data;
                                      IEditManager(_textFlow.interactionManager).applyFormatToElement (_textFlow,null,null,cf);
                                    private function changeDirection (e:Event):void
                                      pf.direction = ComboBox(e.currentTarget).selectedItem.data;
                                      IEditManager(_textFlow.interactionManager).applyFormatToElement (_textFlow,null,pf,null);
                                    private function resizeHandler (e:Event):void
                                     myTextLayout.width = stage.stageWidth - myTextLayout.x;
                                     myTextLayout.height = stage.stageHeight - myTextLayout.y;
                                     _textFlow.flowComposer.getControllerAt(0).container.parent.scrollRect = new Rectangle(0,0,myTextLayout.width,myTextLayout.height);
                                  Did the problem had old version of flex sdk or not import lib or textLayout component not suppose TextConverter.export() class ? please help me, I have source code to download test.My e-mail : hsu.shan.chuang@gmail.com ,tks !
