Locked
How to connect to a remote php webservice?
Aug 02, 2011 Aug 02, 2011
It's possible develop a Flex Mobile Application using a php webservice hosted on a remote php server? How?
1.2K
Explorer , Oct 17, 2011 Oct 17, 2011
Thanks, i've learn that i can deploy my php webservices, doing a find&replace the local url for the remote url for testing. I've to secure my webservices prior to deploy.
Engaged ,
Aug 03, 2011 Aug 03, 2011
You can use the PHP settings of FB for PHP or connect to the webservice via HTTP (or HTTPS). I send and retrieve data from a php server via HTTP and it works well.
You just have to look at any example that explain how to connect to a webpage in FB 4.5.
Guest
Aug 05, 2011 Aug 05, 2011
Yes. You can use DCD to connect to a remote PHP service. In FB, go to Data > Connect to HTTP. Add the URL you want to connect to (including a sample request with parameters) in the operations table and it will figure out the necessary parameters.
Once you have that set up, you can right click on the method in the Data/Services tab and click on Generate Service Call. You can also bind to the data using Data > Bind to Data.
