smpp gateway
craig_mac Aug 5, 2011 6:30 AMHi i am having some problems with the smpp gateway which are
- some message id are not coming back to me
- lots of statuses are not coming back to me
i am not sure what i causing this out of 3000 sms sent 200 had no status returned and 60 had no message id, any ideas how i can debug or solve this i have attached my cfg file.
# SMSGateway configuration file
# Test server config
# This is the IP address of SMSC
ip-address=sms1.cardboardfish.com
# Port to bind to
port=8000
# Your system id
system-id=my_username
# Your password
password=my_password
# The source address for this client
source-ton=5
source-npi=0
# This is a made-up address
source-address=5551213
# The address range this smpp client will serve
# Generally the same as your source address
addr-ton=5
addr-npi=0
address-range=5551213
# Message sending rate; how many messages per second is the
# gateway allowed to send to your service provider.
# This can be a decimal (i.e. 0.1). 0 is unlimited.
# The default is 100 messages per second.
message-rate=100.0
# The mode of the gateway; Either synchronous or asynchronous
# In synchronous mode the gateway will wait for the response
# from the server when sending a message and the SendGatewayMessage()
# CFML function will return the SMS messageID of the message
# or an empty string if their is an error. In asynchronous mode,
# the gateway will not wait for a response and the SMS messageID
# will NOT be returned from SendGatewayMessage().
# The default is synchronous.
mode=synchronous
# Should the gateway retry delivery on Network Errors?
# If a network error occurs while trying to deliver a message,
# should the message be queued for delivery when the gateway
# is able to re-bind to the SMSC. This is useful if the gateway
# is in asynchronous mode, where no error status is returned from
# the CFML SendGatewayMessage() function.
# The default is no.
network-retry=no
# Should the gateway retry delievery on Transient Errors?
# If an error is returned from the SMSC that indicates
# the message may be able to be delivered in the future,
# should the gateway attemp to resend send the message?
# This is useful if the gateway is in asynchronous mode,
# where no error status is returned from the CFML
# SendGatewayMessage() function.
transient-retry=no
# Everything below here is usually OK.
# The function in the Gateway CFC which the is called
# when an incoming message arrives.
cfc-method=onIncomingMessage
# The default destination address info
destination-ton=1
destination-npi=1
# You can't have a default destination
# destination-address=
# The service type can be empty or one of
# the following values:
# CMT, CPT, VMN, VMA, WAP or USSD
# service-type=
# From the spec:
# Identifies the type of system requesting the bind.
# This may enable SMSC responses which are
# particular to a given type of ESME.
system-type=SMPP
# The receive timeout is a timeout for trying to receive a message
# from the SMSC. If you want go to infinite wait until a PDU
# is received, set the receive-timeout to -1.
# The value is in seconds. The default is 30 seconds.
receive-timeout=10
# The ping interval is how often the SMS Gateway will send an
# EnquireLink PDU to the server to verify the health of the connection.
# The value is in seconds. The default is 60 seconds.
ping-interval=60
# The number of connection attempts the gateway will make until it gives up.
# Use -1 to retry until connected. The default is -1 (try forever).
retries=-1
# Connection retry interval; how long to wait between connection attemps.
# The value is in seconds. The default is 10 seconds.
retry-interval=10
