Hi All
I've authored a PPT presentation which has 7 slides (each with about 20 animations on each slide)
I have synced with some audio I recorded and imported, but the published file plays the animations far too quickly (out of sync with the audio)
Can anyone help?
I cannot reproduce the scenario. I tried adding many slides, added text and applied animations to them.
I recorded some audio and tried to sync them to the animations. The output rendered by presenter seemed to be as expected i.e i could not
see the animations running too quickly.
It will be good if you can specify what animations did you use in your presentation.You can also share the presentation if possible.
Else please list the specifc steps you used to produce it.
Hi Alpi
Many thanks for your response
The animations are simple entrance and exits (faded zoom in and out)
I have even created a shorter version (basically deleted the last few slides) to see if this is a size issue but I get the same problem
How can I get the presentation to you? It's 4.38mb
You may bundle the resources folder as well as the presentation in a zipped format and mail me at alpagarw@adobe.com
