Can anyone tell me if RoboHelp assigns a unique project number (build number) for each project release? If so, where would i find it? I don't see anything like that in the SSL properties. I'm trying to determine how to uniquely identify the project for configuration management purposes.
Sherry
Hi Sherry. If you are referring to some sort of build number for your project's output, then no this is not recorded anywhere. However you could record this manually in a topic that could be accessible from an "About" button inside your help file.
The RoboColum(n) | @robocolumn | Colum McAndrew |
Or put it in Project Settings so that it appears in the title bar when the help is used. That way support can easily check the version of the help that has been referenced.
Do you mean add it to the Title Bar field under General in the Properties dialog?
Sherry
What version of RoboHelp are you using? Please see the sticky topic Before You Start.
I'm sorry. It's RoboHelp 9.
Sherry
File > Project Settings > General Tab > Project Title
Okay, thank you, Peter.
Sherry
