3 Replies Latest reply: Aug 9, 2011 9:38 AM by Tnmike RSS
    Clone Stamp Tool
    Tnmike Community Member
      When I first started using CS5 Extended the clone stamp tool display had a "halo" around it.  The top half of the "halo" showed the color shade of the Presnt selection.  The bottom half of the "halo" showed the color shade of the Previous selection.  I am fairly certain there is a switch or option in CS5 that turn this "halo" feature on and off.  I can find nothing in printed literature, help documents or tutorials that even address this feature.  Can someone tell me how to turn this clone stamp feature "on"
        • 1. Re: Clone Stamp Tool
          Noel Carboni Community Member
          The Clone Stamp Tool does not have a "halo" exactly as you describe.  I think perhaps you've confused two things.
          What you're describing sounds a bit like the color picker you see with the Brush Tool when you have enabled OpenGL and use the Alt key while sampling a color from the image.
          When OpenGL is enabled, the Clone Stamp Tool DOES, however, have the ability to preview a brush sized/shaped real-time "overlay" of what would be cloned if you were to click the mouse.
          To enable the Clone Stamp overlay, do this:
          1.  Choose Window - Clone Source from the menus.
          2.  Ensure the following box is checked:
          -Noel
          • 2. Re: Clone Stamp Tool
            You are correct, I was confused.  It was a feature I saw when first using CS5 but never used right away.  How do I enable OpenGL?
            • 3. Re: Clone Stamp Tool
              Please disregard the last questions.  I have found how to enable OpenGL.  Thanks so much for your help.  As usual it is spot on.
