Hello,
I am trying to migrating some processes that were created in ES into ES 2 by import them into a new application. I can see those are there now but not sure what to do next to have them available to use as sub processes for other new processes in ES 2.
Can any one please adivse as I am trying to learn more on ES 2.
Thanks in advance,
Han
Total Likes
Once you get the process imported, you need to create an Application and then add the ES process to that application
Launch workbench ES2 and login to your ES2 Server
Create a new application - File New Application, give it a name and click finish
Expand your new Application and you should see /1.0 version
Right click on the 1.0 version and click Import
Choose Process from the Select dialog and click Next
Find your ES process in the Select Process dialog and click Finish.
Now your ES process should be in your ES2 application
Total Likes
Hi Hodmi,
I imported the LCA that contains a few processes in the AdminUI and I can see it there in the list but when I click on the "Configure", I got the below message:
No configuration can be performed on archive "PTN-09-08-2011-1355". This is likely caused by one of the following:
So I went to Workbench ES2 to do the steps that you suggested and the application is there but I still do not see any process in the application or Process perspective.
I think I miss something but could not tell, can you please advise.
Han Dao
Total Likes
