2 Replies Latest reply on Aug 10, 2011 10:49 AM by BapediBoupi
    Retrieve specific user tasklist in DSC
    BapediBoupi Level 1
      Hi everyone,
      I developped a Custom Component that is trying to retrieve a list of task (List<TaskRow>) assigned to a specific user (passed as parameter).
      I understood that I need to connect to the server with his username and password in order to use the TaskManagerQueryService.taskList() and get his tasks.
      My problem is that when I use this code inside my DSC :
      Properties connectionProps = new Properties();
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_SOAP_ENDPOINT, soapEndpoint);
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL, ServiceClientFactoryProperties.DSC_SOAP_PROTOCOL);
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE, serverType);
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, userID);
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, userPassword);
      ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
      It seems that the connection is done with the default LiveCycle user, like when we use :
      ServiceClientFactory myFactory = ServiceClientFactory.createInstance();
      Is there a way to force the connection with a specific user inside a DSC Component ?
      Kind regards,
      Thomas
        • 1. Re: Retrieve specific user tasklist in DSC
          BapediBoupi Level 1
          After some investigational debugging in the server, I found the error.
          The DSC was indeed using the correct credentials.
          The new problem is that I have this exception :
          java.lang.ClassNotFoundException: [ACTIVE] ExecuteThread: '0' for queue: 'weblogic.kernel.Default (self-tuning)'Class name com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher from package com.adobe.idp.dsc.provider.impl.soap.axis.sdk not found.
          Do I need to "import" this class manually in my component ? If yes, how ?
          Kind Regards,
          Thomas
          • 2. Re: Retrieve specific user tasklist in DSC
            BapediBoupi Level 1
            After all I found a solution, I used EJB instead of SOAP for connection, so my code looks like this
            connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT, ejbEndpoint);
            connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL, ServiceClientFactoryProperties.DSC_EJB_PROTOCOL);
            Hope this helps !
            Thomas
