1 2 3 4 5 Previous Next 365 Replies Latest reply on Apr 23, 2018 12:26 PM by jane-e Go to original post Branched to a new discussion.
      • 80. Re: Replace, or "trash" your InDesign preferences
        Corinne Ishler
        Thanks - this fix worked for me on CS2.
        • 81. Re: Replace, or "trash" your InDesign preferences
          Gochu50
          That did it. You're the best. Thank you.
          • 82. Re: Replace, or "trash" your InDesign preferences
            ricbuchner Level 1
            Hi!
            I tried everything on this tread (renaming SING, erasing "indesign saved data" - defaults I dont have it) and nothing worked...
            Until yesterday, everything was running fine. Today it got screwed...
            My startup ID CS5 apears all the way to the end, program loads on screen for a few seconds, I can see the welcome screen (that one to choose if I want to open a recent file, create a noe one, etc) but this screen is empty, them the program closes itself, no messages, nothing.
            Any help?
            Is there an issue with AVG (I just updated to the new version, grrrr..) I tried to disable it, but didnt work.
            thanks!
            UPDATE: Some INDD files I can open, by double-clicking it. It loads fine, but right after I see a popup screen, asking me if I want to save the file before closing it. If I click yes or no, Indesign closes. there is no way to edit the file or whatever.
            • 83. Re: Replace, or "trash" your InDesign preferences
              John Hawkinson Level 5
              Good morning, Ric:
              Please start a new thread for your question. Please include the operating system and InDesign version (is it 7.0.4?) when you do so, thanks!
              It sounds like you're not getting the Adobe Crash Reporter, have you turned it off?
              • 84. Re: Replace, or "trash" your InDesign preferences
                ricbuchner Level 1
                Hi!
                Crash Reporter... No. I haven't touched it.
                The version... I don't know which one is, sinceI cannot load it anymore, so I can't check it.
                I will start a new thread.
                • 85. Re: Replace, or "trash" your InDesign preferences
                  syst_m Level 1
                  I reinstalled CS5 and it fixed everything.
                  • 86. Re: Replace, or "trash" your InDesign preferences
                    MystiMac Level 1
                    Sheesh!. I was hitting control-alt-shift repeatedly, so I can't have been too slow. Going through these other methods - seems waaay above and beyond the call of duty. I think I'll quite for the day, and tear my hear out tomorrow... Maybe even try to wade through the manual fix.
                    Thanks, though. You forum guys are really great, on the spot, ready to help, and I do appreciate it. But you'd think with such an expensive software, it wouldn't have such eggregious buggy things like this.
                    • 87. Re: Replace, or "trash" your InDesign preferences
                      MystiMac Level 1
                      Maybe the patch 7.0.3 is the way to go. In that case, I probably will need to wait until Adobe finally gets me my disk for my fully purchased InDesign CS5.5, and they are sooooper slow in that, so my trial version will run out before I even get the disk. At least then, hopefully I can start with a clean install.
                      • 88. Re: Replace, or "trash" your InDesign preferences
                        Peter Spier Most Valuable Participant (Moderator)
                        Press and HOLD them down. Don't release untill you see the dialog or ID has started, and we're talking miliseconds here for speed.
                        The current verison is 7.0.4, not 7.0.3, too.
                        • 89. Re: Replace, or "trash" your InDesign preferences
                          And if you are on the Mac platform (just a guess based on your user name), it's Cmd + Control + Opt + Shift. You can press only three keys till the cows come home and get nowhere.
                          • 90. Re: Replace, or "trash" your InDesign preferences
                            MystiMac Level 1
                            I'm on PC. I pressed and held the three keys... From the git-go... No luck.
                            So, tomorrow, you may see a new profile picture of me with bald spots on my
                            scalp, after I my hair-tearing-out momentr...
                            Guess I'll have to wait for Adobe to get around to shipping my disk to me,
                            after which I'll do a clean re-install. I sure as heck hope Adobe isn't
                            growing too big for it's shoes. I really have loved Adobe and its amazing
                            products and developers... But, if they can't support their products and
                            have a bug-fix department that's up to the task, that would be a very big
                            shame.... Thanks for offering your help.
                            • 91. Re: Replace, or "trash" your InDesign preferences
                              MystiMac Level 1
                              Dear Peter,
                              So, I'm trying the renaming the hidden files method now. From the link you (and the Mac guy sent, tho I'm on PC), for replacing or trashing InDesign preferences, to hopefully remove corrupt preferences and end bad behavior...
                              within this file:
                              Windows XP: C:\Documents and Settings\<USER>\Application Data\Adobe\InDesign\<Version #>\<language>\
                              in the eng_US folder, I'm seeing two subfolders: "Extensions" and "Scripting support." Are these the two I should rename?
                              And in the second set I'm supposed to rename:
                              Windows XP: C:\Documents and Settings\<USER>\Local Settings\Application Data\Adobe\InDesign\<Version #>\<Language>\Caches\
                              I don't see anything more in the folder, other than "Extensions" and "Scripting support" folders. And what would you suggest I rename them?
                              Am I missing something? I don't want to mess things up. And I'm hoping that my disk for the indd CS5.5 will arrive in a few days and I'll do a clean install. I have now only this one remaining day on my trial period, and the program is acting even buggier. Yesterday I was able to use the "review" panel as a pseudo "articles panel" (given that I can't get the articles panel proper to show - when I go to Window/articles, it gives me the review panel, then wants me to subscribe to the review subscription, and I can't even add "articles" to the review panel anymore). I'm trying to make good use of this remaining day of my trial period and not lose any more work time due to adobe having failed to ship my order until I'd waited 6 days, then called support desk (some guy with Indian accent who barely understood what I was talking about, but finally he "escalated" the case, and the order apparently shipped yesterday). Thank you for your patience. I'm no programmer, and am loathe to change registries, but I've done it successfully a number of times in the past with help...
                              • 92. Re: Replace, or "trash" your InDesign preferences
                                MystiMac Level 1
                                PS: Would it be useful to download the Adobe Support Advisor?
                                http://www.adobe.com/support/loganalyzer/
                                • 93. Re: Replace, or "trash" your InDesign preferences
                                  Do you not see the InDesign Defaults file in the first path, and the InDesign SavedData file in the second? If ID ever launced and closed successfully, they should be there. Those are the two things you need to rename.
                                  It also would be OK to rename any folder in the path below the "adobe" folder ( so you don't screw up other apps), like \InDesign\ (which will reset prefs for all versions) or \Version 7.5\ which will affect only CS5.5
                                  • 94. Re: Replace, or "trash" your InDesign preferences
                                    The log analyzer is only good for failed installations. It isn't going to help if ID launched, I think.
                                    • 95. Re: Replace, or "trash" your InDesign preferences
                                      MystiMac Level 1
                                      Here's what I see, in user application data\Adobe\InDesign\  (with "hidden files" showing) I see a folder named Version 7.0 and a folder named Version 7.5. Each of those has the en folder, and then the two I mentioned, "Extensions" folder and "Scripting support" folder. Nothing more. Maybe I can just rename "Version 7.5" folder? And if so, what do you suggest I name it?
                                      Thanks; I know it's Sunday...
                                      • 96. Re: Replace, or "trash" your InDesign preferences
                                        If ID has launced sucessfully and then closed:
                                        The <user>\Application Data\Adobe\InDesign\Version 7.5\en_US folder should have a FILE in it named InDesign Defaults.
                                        The <user>\Local Settings\Application Data\Adobe\InDesign\Version 7.5\en_US\Caches folder should have a FILE in it named InDesign SavedData
                                        You can change the name of both "Version 7.5" folders and accomplish waht needs to be done, but it's overkill.
                                        • 97. Re: Replace, or "trash" your InDesign preferences
                                          MystiMac Level 1
                                          Well, I'm not seeing all you see. Here's what I see:
                                          C:\Documents and Settings\Administrator\Application Data\Adobe\InDesign\Version 7.5\en_US
                                          Then... (new dvorak keyboard - dunno how to "print screen" - unexpected surprise...)
                                          then... (upon yet another restart of CS5.5)... folders named "composite," "Workspace," "Scripts," and beneath them, Indd defaults, an unknown file name (seems like progress); and, lastly, "color settings," another unknown file name....
                                          Time for "overkill"??
                                          Thanks again.
                                          • 98. Re: Replace, or "trash" your InDesign preferences
                                            Don't worry if you don't see all the sub-folders I have. They come when you do additional customizations.
                                            For the sake of speed and getting the job done, try just changing "Version 7.5" to "_Version 7.5" in both places.
                                            • 99. Re: Replace, or "trash" your InDesign preferences
                                              MystiMac Level 1
                                              Okay, renamed both files, with the underscore. Now, upon re-load, I get the "articles" panel (some progress, anyway), but can't drag "documents" into the panel, and the control click add (click plus button in the panel) is grayed out. In the panel "options" drop-down, everything but "use for reading order in tagged PDF" is grayed out.
                                              Thanks again for taking your time and patience, on a Sunday.
                                              • 100. Re: Replace, or "trash" your InDesign preferences
                                                It's time for you to start a brand new thread. We've passed beyond a problem with resetting the prefs.
                                                In the new thread, give the version of Windows and ID (I know them, but others won't), and a detailed description of what you are trying to do, along with details of what you see (screen captures would be extremely helpful). I'm not going to be much help withthe Articles Panel -- it's a feature I don't use in my workflow -- but there are plenty of other users who will pop in.
                                                • 101. Re: Replace, or "trash" your InDesign preferences
                                                  MystiMac Level 1
                                                  Okay, thanks. I'll give screenshots too, if I discover what format the image
                                                  upload takes. Enjoy our Sunday, what's left of it.
                                                  • 102. Re: Replace, or "trash" your InDesign preferences
                                                    I recommend .png for screen caps.
                                                    • 103. Re: Replace, or "trash" your InDesign preferences
                                                      MystiMac Level 1
                                                      Thank you. That was critical!!
                                                      • 104. Re: Replace, or "trash" your InDesign preferences
                                                        MystiMac Level 1
                                                        Just wanted to let you and any audience know that after I re-started my computer (and having renamed the files you designated), now I can get the articles panel. So I'm muddling through, moving forward from that point... not able to export to epub having selected radio button "according to articles panel," (grayed out), but according to the "based on page layout" radio button selected, the output ain't bad. Fortunately, my first project is pretty basic -- just text, styles, no graphics, a couple drop caps. Thank you for your help thus far.
                                                        I hope the Adobe team doesn't spend all their human resources pressured to turn out a new version every year (as the survey I went through said Adobe aspired to do), but keeps enough human resources fixing what seems to be a pretty buggy CS5.5.
                                                        • 105. Re: Replace, or "trash" your InDesign preferences
                                                          mezmiranda11 Level 1
                                                          thanks, will give that a go.
                                                          • 106. Re: Replace, or "trash" your InDesign preferences
                                                            MystiMac Level 1
                                                            After various frustrations with indesignCS5.5 installation, which, per advice of adobe tech in Asia, changing the user account on my pc (windows xp), the user accounts were all corrupted... Not wanting to lose any more time, I bought a new computer, PC, running Windows 7. Now with inddCS5.5, the preferences are all screwy -- can't open more than one panel. If I open pages, then want to additionally have character, paragraph panels open, the pages panel gets changed to something else. I tried going to the user accounts, making files visible via your method, renamed the file InDesign Defaults to _InDesign Defaults. I didn't see InDesign SavedData, neither in the administrator account (I'm the administrator), nor in the users account. Then I restarted Indd, but still the preferences weren't working. Here's what I have now in explorer:
                                                            Once again, can you help with this issue, now that I'm on Windows 7, and have the indd CS5.5 (with updates already in)?
                                                            • 107. Re: Replace, or "trash" your InDesign preferences
                                                              MystiMac Level 1
                                                              Here's a little better screenshot.
                                                              • 108. Re: Replace, or "trash" your InDesign preferences
        I'm still on XP, but that screen grap looks OK, presuming you renamed InDesign Defaults to _InDesign Defaults. InDesign SavedData is in C:\Users\<USER>\AppData\Local\Adobe\InDesign\<Version #>\<Language>\Caches\
        Notice that you A different folder, so you have to go back up the tree and open the AppData folder and work back down.
        That said, I don't think this is a corrupt prefs issue. More likely you have the panel groups reduced to icons or icons plus labels. If that's the case, it's expected that opening one panel from an anchored collection of grouped panels would close other panels in the same collection.
        • 109. Re: Replace, or "trash" your InDesign preferences
        MystiMac Level 1
        Thanks Peter,
        Your comment about panel groups reduced to icons or icons plus labels -- I'm not seeing icons... Is there some setting, like "preferences" from the file menu? Or some other way to see if it's about panel groups?
        • 110. Re: Replace, or "trash" your InDesign preferences
        MystiMac Level 1
        Aha! I messed around and discovered how to make visible all the panels available. Now I'll customize my workspace. Thank you soooo very much!! You're awesome!
        • 111. Re: Replace, or "trash" your InDesign preferences
        claytab30
        Thanks for the advice.  My page transitions had completely stopped functioning as well as any background colour for my pages when exported.  I took your advice, held down clt, alt shift and all is well again!
        Good job...
        • 112. Re: Replace, or "trash" your InDesign preferences
        Heli P
        I'm having a similar issue, I opened up an old file which was made in CS5, and all my paragraph styles are missing. the paragraph style window only shows the "basic" style. I went through this thread and did everything you suggested with no result
        I trashed my preferences with the keyboard short cut. closed and reopened indesign.
        I uninstalled indesign and reinstalled it.
        I activated all the fonts that were in the file using fontexplorer.
        I even opened the file from 3 different sources I had it saved on.
        I went into my library>users>preferences and it no longer has the adobe indesign folder. only file I found that had indesign in it was "com.adobe.InDesign.7.0.plist"
        none of these steps brought back the paragraph styles.
        Any suggestions what else I could do?
        • 113. Re: Replace, or "trash" your InDesign preferences
        Heli P Level 1
        also, this is only happening to one particular file. I opened another and it has all the paragraph styles.
        • 114. Re: Replace, or "trash" your InDesign preferences
        When problems are isolated to a particular file they usually have nothing to do with Prefs. Instead try Remove minor corruption by exporting
        • 115. Re: Replace, or "trash" your InDesign preferences
        Heli P Level 1
        Thank you for such a quick reply. I tried exporting as .IDML then saving it as .indd and it didn't work either. No idea why this is happening. I suppose I'll just have to redo the styles. Thankfully its just a single spread document.
        Thanks again for your help.
        • 116. Re: Replace, or "trash" your InDesign preferences
        From your description it sounds like the styles are missing when you open it in CS5.5. You might try opening it in CS5
        (and there you could export to IDML).
        Also, if you have other documents with the same styles, you can of course use Paragraph Styles (panel) > Load Styles.
        It sounds like your document was just corrupted though. Unfortunately.
        • 117. Re: Replace, or "trash" your InDesign preferences
        Heli P Level 1
        I'm working with CS5 and had made the file using the same. So I figured there wouldn't be any compatibility issues.
        After creating the file with all the styles I had saved it on my mac's hard drive, an external hard drive and burned it onto a cd. And neither of those files seem to have the styles when I open them in indesign as is. And even when I go to load styles from the same file saved on a different location, it still only shows the basic paragraph style. Its bizarre. I have other files that are working just fine, this is the only problem child so I'm guessing its completely corrupt.
        • 118. Re: Replace, or "trash" your InDesign preferences
        _acj1123
        My keyboard shortcuts in InDesign CS5 have suddenly stopped working.
        Some of them work (v = selection tool etc) but the ones that are used to switch tools WHILE using another tool (ie: using the selection tool and then holding down SHIFT = hand tool) has stopped working.
        I've followed this instruction and copied the ID Defaults and SavedData files to my desk top and then re-started ID.
        Some of the presets were restored to defaults, but not these keyboard shortcuts that I use approx 327 million times a day!
        Any other ideas?
        Should i have RENAMED the two files instead of just copying over and re-starting the program?
        Also, still having trouble with holding the cmd+cntrl+opt+shift at the launch.
        • 119. Re: Replace, or "trash" your InDesign preferences
        That's SPACEBAR to get the hand tool....
        Any other ideas?
        Keyboard shortcut sets are not lost (though it might switch you to the default set rather than a custome set) when you replace the prefs. If reppaling the prefs didn't help you can copy the old ones back where they were. It makes no functional differnce if you've moved or reamed the old ones, they are still available as backup. The keyboard method replaces the current set without saving a backup copy.
