1 2 3 Previous Next 95 Replies Latest reply on Mar 30, 2012 6:00 PM by lennyd15
    Flash Player 10.3.183.5 Released
    chris.campbell Adobe Employee
      This release addresses compatibility issues that include:
      • Mac OS X Lion: The Flash Player settings dialog does not respond to mouse clicks (2918693)
      • Microsoft Internet Explorer 9: Audio may stop playing after switching tabs (2927827)
      In addition, this release includes security fixes that will benefit all users.
      You can download this release from the following pages:
      Get Flash Player
      Alternate Flash Player Download Page
      Additional details regarding this release can be found here:
      Flash Player Release Notes
      Security Bulletin APSB11-21
      Please let us know if you encounter any difficulties.
      Chris
        • 1. Re: Flash Player 10.3.183.5 Released
          Gridking1
          will this fix the fact that fullscreen is no longer fullscreen also?
          that is the problem I am having with Chrome and IE
          • 2. Re: Flash Player 10.3.183.5 Released
            Gridking1 Level 1
            nope, still no fullscreen working
            please address, Thank you for your time and effort
            • 3. Re: Flash Player 10.3.183.5 Released
              Hi Gridking1,
              I'm unfamiliar with this problem.  Do you know if there is a bug report for this over at bugbase.adobe.com?  If not, could you please create one and include your system details (instructions for this can be found here) the URL and steps you're taking to reproduce the problem.  Please post back on a new thread with the bug's URL so that others affected can add their votes to the bug.
              Chris
              • 4. Re: Flash Player 10.3.183.5 Released
                jime0000
                Does this fix the issue in Lion OS which causes my iMac to freeze when trying to view a video after the computer has been "woken up" from "sleep"??
                I know I'm not the only one with this issue.
                • 5. Re: Flash Player 10.3.183.5 Released
                  sgamat
                  It doesn't work in Windows Vista using a Standard Account.  The plugin is NOT listed in the Firefox's plugin list for the current user (Standard Account).
                  • 6. Re: Flash Player 10.3.183.5 Released
                    Muntyhoven
                    10.3.183.5 has fixed the "Mac OS X Lion: The Flash Player settings dialog does not respond to mouse clicks (2918693)" problem, good work, thanks.
                    However under Mac OS X Lion I am still unable to select my webcam. I have an inbuilt iSight cam on my MBP 15" 2010 and also an iSight cam on my Apple Cinema Display 27" 2010. I am only able to use the iSight cam on my MBP (so it's quite usless when I'm at my desk using my monitor).
                    ie. in the Adobe Flash Player Settings, Camera tab I only have one entry for USB Video Class Video available in the drop down menu.
                    May I please ask if this is a known problem and will be fixed in a later release?
                    Some notes:
                    This happens in the latest versions of Chrome and Safari.
                    There was not a problem on OS X 10.6.8 (and whatever the latest version of Flash Player was then?).
                    Both my iSight cams are selectable using Facetime and iChat. I've no other webcams on my system.
                    There is no way AFAIK in OS X to disbale only one webcam; you can disable them both via moving a system file, but even this crude workaround is not available.
                    Thanks again, we're getting to a stage where people with MacBooks can use their webcams at a workstation it seems!
                    • 7. Re: Flash Player 10.3.183.5 Released
                      Muntyhoven Level 1
                      OK, sorry, this still doesn't work but a workaround is simply to close the lid on my MacBook. This means the MacBook's iSight camera is no longer available so Flash Player now uses the Cinema Display's.
                      I'm -pretty- sure that I could select my webcam in 10.6.8 (contradicting myself slightly from before) as I can in Facetime and iChat? However is Flash's problem that it can't cope with two webcams of the same name, in this case they're both called "USB Video Class Video"? Facetime calls one "Display iSight" and the other "Built in iSight"?
                      • 8. Re: Flash Player 10.3.183.5 Released
                        Jon-Hall
                        What's the new silent install command? The ActiveX version used to use -install and Other was /install, both of which bring up the basic UI with status bar and Finished button, then the Flash Player completion webpage opens.
                        Jon
                        • 9. Re: Flash Player 10.3.183.5 Released
                          smia
                          do adobe have mail list or sth that notfiy us flash player upgraded
                          it seems 10.3.183.5 with alchemy not work now,after hard work we finally find the player upgraded and some mechanism changed
                          maybe its about security improved ,but you upgread the player WITHOUT ANY NEWS,BLOG,MAIL,just a forum post!
                          now 2000 our clients can not play with flash player,we spent 6 hours at night just find the damm player upgraded
                          • 10. Re: Flash Player 10.3.183.5 Released
                            tkessler45
                            Hello Chris,
                            Even with this latest update, in OS X Lion enabling hardware acceleration seems to kill video when streaming live video from CNN. Go to the Flash settings and enable hardware acceleration on an OS X system running Lion, and then go to http://www.cnn.com/video, click the "Live" button at the top, and then select one of the live streaming broadcasts at the bottom of the screen (under the subscription streams). The video will load and ask to install the octoshape plugin. It will show the advertisement perfectly fine, but then will show a blank window when the video content loads. The audio seems to work just fine.
                            This is on a MacBook Pro (2009 model), and happens when either of the GPUs is active (Geforce 9400M or 9600M). The system is fully updated, running the latest version of Safari, Firefox, and Chrome, and the problem happens on all three browsers. I have cleared caches and cookies for the browsers, and have tried loading both with and without the octoshape plugin installed...still no go. The only way to get the video to work in this situation is to disable hardware acceleration.
                            • 11. Re: Flash Player 10.3.183.5 Released
                              We are aware of this bug and we believe the root cause of the problem has been found and hope it should make a future update in the next few months.  I have seen reports that this also occurs with other video playback, in addition to Flash.
                              Chris
                              • 12. Re: Flash Player 10.3.183.5 Released
                                ksilfer
                                Do the 10.3.183.5 MSI installers not have the Windows Control Panel applet included?
                                Installed overtop of an older install that already has the applet, it does not delete it, but if you install fresh from the 10.3.183.5 MSI's, it does not install the applet.
                                • 13. Re: Flash Player 10.3.183.5 Released
                                  I just tried this out with a standard account on Win 7 and the plug-in loaded properly.  Can you verify that the "NPSWF32.dll" file is present in the following folder:
                                  32 bit OS: C:\Windows\System32\Macromed\Flash
                                  64 bit OS: C:\Windows\SysWOW64\Macromed\Flash
                                  Chris
                                  • 14. Re: Flash Player 10.3.183.5 Released
                                    Hi Munty,
                                    This is a known bug (our interntal bug number is 2785485) and is marked fix for Flash Player 11.  In fact, we just released a new beta of Flash Player 11 today, which should include this fix.  We'd love to get your feedback.  If you're up for trying it out, you can grab the build here:
                                    http://labs.adobe.com/technologies/flashplatformruntimes/flashplayer11/
                                    Chris
                                    • 15. Re: Flash Player 10.3.183.5 Released
                                      Jon
                                      Hi Jon,
                                      Pinging the installer team about this.  I had thought one of the two (slash or dash) would work.  I'll let you know what I hear back.
                                      Chris
                                      • 16. Re: Flash Player 10.3.183.5 Released
                                        Hi Smia,
                                        I'm sorry you guys went through that last night.  As it happens, there is actually a blog specifically for Runtime releases.  This should be a great way to keep updated with both official and beta releases of AIR and Flash Player.
                                        Adobe Flash Platform Runtime Releases
                                        Hope this helps,
                                        Chris
                                        • 17. Re: Flash Player 10.3.183.5 Released
                                          tkessler45 wrote:
                                          Hello Chris,
                                          Hi tkessler45,
                                          I just tried this on my 2010 MacBook Pro (NVIDIA GT 330M/Intel HD Graphics) but hardware acceleration worked fine with the live stream.  I'll find out if this is a known issue with that GPU or if we have this system in our lab and give it a try.
                                          Chris
                                          • 18. Re: Flash Player 10.3.183.5 Released
                                            I've asked our installer team for their feedback.  I'll let you know what I find.
                                            Chris
                                            • 19. Re: Flash Player 10.3.183.5 Released
                                              DeastCCM Level 1
                                              Chris
                                              I use to be able to go the the trouble shoot page for installing flash player and there would be an option for manual intstall.
                                              I used that to bypass all the adobe air and other stuff
                                              Today I went to that page and there was no option for manual install
                                              I use Vista 32 bit OS an Internet Explorer
                                              has this option been taken away from users?
                                              • 20. Re: Flash Player 10.3.183.5 Released
                                                chris.campbell wrote:
                                                Jon
                                                Hi Jon,
                                                Chris
                                                Jon,
                                                Our installer engineers just finished retesting this and were unable to reproduce the problem.
                                                "InstallAX.exe -install" worked as expected, no UI is displayed, Flash Player completion page did not display
                                                "InstallPlugin.exe -install" worked as expected, no UI is displayed, Flash Player completion page did not display
                                                Can you retry this and let us know how it goes?
                                                Chris
                                                • 21. Re: Flash Player 10.3.183.5 Released
                                                  Chris
                                                  We're reproduced this bug.  Thanks for reporting this!  If you'd like, please enter a bug on this over at bugbase.adobe.com and post back with the URL so others affected can cast their votes.  I'll link it to our internal bug so you'll be able to track the status.
                                                  Chris
                                                  • 22. Re: Flash Player 10.3.183.5 Released
                                                    tkessler45 wrote:
                                                    Hello Chris,
                                                    Hi tkessler45,
                                                    Chris
                                                    We've been able to reproduce this with the current and previous version of Flash Player with both 10.6 and 10.7.  Could you add this as a new bug report over at bugbase.adobe.com?  Please post back with the URL (you might want to make a new thread) so that others affected can cast their votes and add comments.  I'll link your bug with our internal one and you should be able to see status updates as the bug progresses.
                                                    Chris
                                                    • 23. Re: Flash Player 10.3.183.5 Released
                                                      DeastCCM wrote:
                                                      Chris
                                                      Try this page:
                                                      http://kb2.adobe.com/cps/191/tn_19166.html#main_DownloadInstallFireFox
                                                      Scroll down a bit to the first "Advanced Troubleshooting" section, you should see two links for Flash Player for ActiveX and Flash Player Plugin.
                                                      Chris
                                                      • 24. Re: Flash Player 10.3.183.5 Released
                                                        DeastCCM Level 1
                                                        Chris, I'm using IE as my browser and I don't have any proxy stuff
                                                        So are you saying that the link
                                                        install_flash_player_ax.exe
                                                        should take me to the correct installation of the lates Flash player for Vista OS with IE as browser?
                                                        • 25. Re: Flash Player 10.3.183.5 Released
                                                          Yes, exactly.
                                                          Chris
                                                          • 26. Re: Flash Player 10.3.183.5 Released
                                                            DeastCCM Level 1
                                                            so it gives me exactly the same thinga s far as flash player normal download, in regard to the flash player stuff itself (exclusive of the get plus stuff)?
                                                            Just as if I did the normal download from the download page?
                                                            and which one do I use for Vista the active x or the plugin?
                                                            • 27. Re: Flash Player 10.3.183.5 Released
                                                              DeastCCM Level 1
                                                              and I can use this trouble shooting work around even if I DON'T  have a proxy thing issue
                                                              • 28. Re: Flash Player 10.3.183.5 Released
        Here are the direct download files, which is what I was hoping the tech doc where pointing to:
        Windows
        Flash Player for Internet Explorer
        Flash Player for all other browsers
        Macintosh
        Flash Player for all supported browsers
        Chris
        • 29. Re: Flash Player 10.3.183.5 Released
        Ritteh Level 1
        Major troubles for us as it is no longer compatable with Pendulab's ChatBlazer.
        http://www.chatblazer.com/
        We are dealing with lots of support phone calls and e-mails due to this. Ugh!!!
        I don't know if the problem is Adobe Flash or ChatBlazer, but it has worked fine with prior versions of Flash. This is a major issue for us as a company, as we use the ChatBlazer software to provide real time interactions with our customers.
        • 30. Re: Flash Player 10.3.183.5 Released
        pwillener Level 8
        You don't specify what kind of "problems" you or your customers encounter.
        Can you reproduce any of these problems?  If so, do they go away if you revert to the previous Flash Player version?
        • 31. Re: Flash Player 10.3.183.5 Released
        Ritteh Level 1
        As we are not the developers of ChatBlazer, I can not state what the exact problem is. All I can tell you is the symptoms. On Windows, we just see a black screen where the Flash app should be. On Mac, the title screen is shown, it looks like it's doing some loading in the background due to a progress bar. The progress bar then stops and we are stuck on the screen.
        Yes, reverting back to the previous version of Flash works.
        • 32. Re: Flash Player 10.3.183.5 Released
        pwillener Level 8
        With that new Flash Player version, can you see the Flash animation (rotating red 'f') at http://www.adobe.com/software/flash/about/ ?
        If yes, can you right-click on that Flash object, then under Settings disable Hardware Acceleration?
        • 33. Re: Flash Player 10.3.183.5 Released
        Ritteh Level 1
        I disabled hardware acceleration but the problem continues.
        I've been searhing a littler deeper. I downloaded the debug version hoping that would give me some sort of error log, but got nothing.
        However, after about a second of the movie loading, I get the following context menu:
        Movie not loaded...
        Show Redraw Regions
        Debugger
        About Adobe Flash Player 10.3.183.5
        All three top options are disabled/greyed out. Movie not loaded is certainally something I wouldn't expect to see.
        Now, what's particularly interesting is that for the first couple seconds, I can get the normal context menu. Play, forward, next, etc.
        My guess, and that's all this is - a guess, is that the application is trying to load another swf and failing. I do know this application loads a skin file and perhaps it is dying there. I know it's finding the skin file, because an error appears when I rename it. The net view in browser (firebug or chrome developer tools) shows the skin file loading properly. I know this isn't much to go on, but it's one more data point.
        The whole issue might be some weird coding in the ChatBlazer app, however it's certain that this Flash upgrade isn't 100% backwards compatable.
        • 34. Re: Flash Player 10.3.183.5 Released
        13xforever
        Archived Flash Player versions KB have wrong release date, release version number AND invalid download link. Isn't it funny?
        • 35. Re: Flash Player 10.3.183.5 Released
        ksilfer Level 1
        Registered bug for installers not installing Windows Control Panel applet:
        https://bugbase.adobe.com/index.cfm?event=bug&id=2940568
        Message was edited by: ksilfer
        • 36. Re: Flash Player 10.3.183.5 Released
        mlem116 Level 1
        I have installed Adobe Flash Player version 10.3.183.5 and now any flash pages are telling me that Flash Player 9.0.0 is required.  Its almost like any webpages that use Flash in Safari think I am using an OLD version of Flash.  Any help would be appreciated.  I have tried to uninstall and reinstall without any success.
        Mac 10.6.8 installed
        • 37. Re: Flash Player 10.3.183.5 Released
        Movie not loaded...
        Show Redraw Regions
        Debugger
        Hi Ritteh,
        I've been able to confirm this against 10.3.183.5 and beta 2 of Flash Player 11.  I'll be entering a bug about it internally so we can continue our investigation.  If you'd like to get updates, please feel free to enter a new bug over at bugbase.adobe.com and we'll link the internal bug against the public.  Please post back with the bug URL so that others can cast their votes and add comments.
        Chris
        • 38. Re: Flash Player 10.3.183.5 Released
        Oops, thanks for the heads up.  I believe the download link is valid but the version and date are off.  We'll get this fixed.
        Chris
        • 39. Re: Flash Player 10.3.183.5 Released
        Could you go to the following page and let me know what version of the player is reported being installed?
        Chris
        1 2 3 Previous Next
