After we publish a Presenter file, the output displays additional text in the Slide notes (ex. DRAFT ONLY - Version 1.0 - Last Updated September 2, 2010...). This text does not display in the Slide Notes of the original file. I'm trying to determine if there's a Powerpoint versioning setting or Presenter setting that is causing this behavior. I still haven't been able to figure it out. I'm working on a XP operating system with Office 2010 installed. I'm using Presenter v.7.0.5. I tried running the 7.0.6 patch update, but I get a message that it is not a valide Win32 application. I don't know if these 2 issues are associated with the same root cause.
Does anyone know how to fix this Slide Notes issue?
Within Powerpoint - go to the INSERT tab then select Header and Footer, there you will see the notes that you mention are appearing.
Hope this helps.
Hope this helps.
Thanks very much! Your instructions helped me to fix this issue.
