Is RTMP tunneling suported?
Avatar
Level 2
Flash Media Sevrer allows you to tunnel RTMP. Does FDS suport
this?
Avatar
Level 3
Hi Sparky,
FDS does not support RTMP tunneling. If using dedicated RTMP
socket connections isn't an option you should use AMF polling. This
is a feature area that we're doing investigation around for a
future release.
Best,
Seth
Avatar
Level 2
Bear in mind that there are Flex 1.5 apps out there that use
Flash Communication Server to do the data push bit of what in V2 is
done by the RTMP support in FDS
Avatar
Level 3
Yes, you can use Flash Media Server to do data push using
remote shared objects.
But data push to clients is only part of the FDS story.
Remote shared objects hosted on FMS don't integrate as directly
with J2EE domain models/Hibernate and JMS messaging as FDS does. If
tight integration with a Java backend isn't a requirement, using
Flash Media Server for push can be a great approach for your app.
Best,
Seth
Avatar
Level 2
Seth,
Thanks for your advice.
Tell me, apart from streaming media into a Flex UI would
there any reason to use FMS in a V2 application for data push or is
it ALWAYS best in your opinion to migrate V1.5 apps (that use
FCS/FMS for data push) to FDS2?
Graeme
PS I might point out that this important topic is not
mentioned in the Flex 1.5 to 2.0 Migration Guide.
Avatar
Level 3
Hi Graeme,
My advice is to "always" do what makes the most sense for
your application ;) I'm a firm believer in the absense of
absolutes.
That said, FMS should be used to stream AV to a Flex app
because the FDS RTMP support is data-only. I wouldn't recommend
porting an existing FMS application that Flex clients integrate
with to FDS unless you had a good business reason to do so.
If you can envision the need to make RemoteObject calls
against server-side Java resources, proxy web service or HTTP
calls, or need to hook into JMS messaging or Java domain models
using data management services I'd recommend FDS. Client to client
data exchange can be accomplished with either server so your total
set of requirements should drive your final decision.
Best,
Seth
