Robohelp 7 open Robohelp 9 project?
Guest
Aug 10, 2011 Aug 10, 2011
as I search through internet, I understand that robohelp 7 unable to open robohelp 9 project
we have two robohelp 7 licenses and three robohelp 9 licenses
when working on project in robohelp 9, it need to upgrade the project, but robohelp 7 is unable to open the project after upgraded
Is it any way opening Robohelp 9 project(converted from version 7 project) in Robohelp 7?
Is it upgrade Robohelp 7 to 9 is the only way? We do not wish to upgrade is because i am wondering if later Adobe release robohelp 10, and by that time we need more robohelp license and we purchased additional license, we will need to upgrade all other old robohelp product?
1.4K
Hi there
The only way I can fathom opening a project in RoboHelp 7 after you have upgraded it to RoboHelp 9 would be to create a CHM output in RoboHelp 9, then decompile it to get the source files. You could then create a version 7 project using the source files.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Guest
thanks, is there anything will lost if using this way?
for example, conditional tags?
Hello again
Yep, conditional tagging is handled in the project before you compile or generate, so indeed they would be lost as would any information you excluded via the tab and build expression.
Not perfect, but at least you get a project you may continue editing in version 7.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Picking up on the upgrading point....
When Adobe released RoboHelp 9 they changed the upgrade pricing policy. Upgrade from 8 is $399, much lower then previously. If that continues, then the two licences you will have to buy now for 9 will not cost as much to upgrade to 10 as perhaps you are thinking.
@petergrainge
Guest
Aug 11, 2011 Aug 11, 2011
I just want to add that there is a tool called HHP Builder that can be used to create a HHP file in the folder with the decompiled source files. This can then be opened in Robohelp.
Why would you need the HHP builder? When RoboHelp generates an output, it creates an HHP file. That doesn't change the code in the source files so RoboHelp 9 source files will not play nicely with RoboHelp 7.
@petergrainge
Guest
Aug 12, 2011 Aug 12, 2011
Peter, I suppose you mean that you copy the HHP from the project folder into the folder of the decompiled files and open it there with Robohelp? I have never tested that, RH9 supports merged TOCs etc. that are generated during production but if the file names are the same then it should work.
I thought you were suggesting that to open the RoboHelp 9 project in RoboHelp 7 the HHP could be used, in other words open RH7 and point it at the RoboHelp 9 project HHP. As the HHP would already exist, you would not need to build it, hence not following what you were getting at.
When you reverse engineer a CHM using the methods on my site, you get an HHP. I hadn't considered dropping in the HHP from the 9 project.
@petergrainge
Guest
Peter, please excuse if I misunderstood (I'm not a native speaker). My
proposal was to use the decompiled CHM as you has suggested, then to use
HHP Builder to generate the HHP there - simply the same workflow as if
you had some odd CHM without a RoboHelp project.
If I understood you correctly, you meant to use the HHP within the
project folder, copy it into the folder with decompiled files instead of
using HHP Builder? Sounds fine, I have not tested this but it may work.
The other option to open the HHP file directly in the Project folder
using the original source files would not work in my opinion. RoboHelp
inserts proprietary code and I do not think that RH7 is able to work
with RH9 source files.
Sorry for any confusion.
Robert
First, there's nothing wrong with your English.
We have misunderstood each other but bottom line is that if you decompile following the instructions on my site, you will have an HHP file for RoboHelp 7 and we are agreed using the HHP from the RoboHelp 9 project would be questionable to say the least.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
