Clueless NEWBIE DEVELOPER, NEEDS ASSIST with Insert Record Server Behavior
Aug 07, 2006 Aug 07, 2006
Experienced DW designer learning CFMX7. I cannot seem to get beyond this error message when using the Insert Record server behavior to write data from a form into the database. Using MS Access 2002, CFMX7's internal server, DW 6.0. Please note that I am learning development for the first time and am using tutorials. I was able to connect at one point but now I cannot.
See error message below:
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
Error Executing Database Query.
Syntax error in INSERT INTO statement.
Resources:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322)
Remote Address 127.0.0.1
Referrer http://localhost:8500/moosek/TMPu724j3nl2j.cfm
Date/Time 07-Aug-06 07:23 PM
Text Text
Advanced techniques
440
Perhaps this is a reserved word problem, with the word password. I don't use access myself so I am not sure, but it's something that comes up on these forums a lot.
Aug 08, 2006 Aug 08, 2006
I would guess that the UserRoleID is an integer and should not have quotes around it.
BTW - you may want to post questions like this under the Getting Started Forum versus Advanced Techniques.
Aug 14, 2006 Aug 14, 2006
MongoSlade,
I had this exact same problem with a CFMX 7 datasource that was set up as Microsoft Access with Unicode. It turns out that "Password" is a reserved word in the Unicode driver. Or somewhere. I got around it by putting square brackets, i.e., [ ] around the column name, like this:
update MyTable
set [Password] = '#form.Password#'
where UserID = '#form.UserID#'
That solved the problem nicely. I hope this solution will work for you as well.
Guest
Aug 15, 2006 Aug 15, 2006
You may want to use <cfqueryparam ... /> just in case someone
has a password with escape characters.
ex.
password=she'sallthat
Aug 22, 2006 Aug 22, 2006
Thank you all. It appears that the reserve word was indeed the problem. Used 'pword' instead. I will also ask these types of questions on the getting started board as suggested.
Thanks again.
Documentation
