Yesterday, I followed Peter Grainge's procedure to delete my
CPD and XPJ, and it worked like a charm (thanks Peter!).
I am running RoboHelp X5.0.1.
I knew from the website that 3-frame framesets caused a
problem, so I removed them from the HHP and added them back in
later. I also read that the Conditional Build Tags would be gone,
so I added them back in. But then I noticed that in my project, the
Templates section was empty in the Project Manager. I tried to
re-import the templates, but nothing happened. I then tried to
delete the template and create a new one with the same name, but I
got a message that a template of that name was already in use
(which, of course, it was). For the record, I was able to create a
brand new template without any trouble.
I then checked to see if I could select a template when
creating a new topic. Although the template drop-down on the New
Topic window is empty, I can find and select the template by
clicking the Folder icon, and it applies. The existing files also
display the template when generated.
So, all in all, I have a work-around. But I was wondering if
anyone else has experienced a similar situation, or knows why this
is happening.
Rob Myre
