14 Replies Latest reply on Nov 13, 2011 12:59 PM by Wild Dog Road Photography
    PPro CS5 always conforming files
    jphilip75 Level 1
      I have downloaded and installed today the CS5 trial version (my order is still pending). Doing some test and it seems I have some problems with CS5 that I've never had with CS4.
      Each time I open a project the audio conforming files of the project are regenerated which means I have the same conforming files on the media cache files folder, each time renamed
      filename 48000.cfa
      filename 48000_1.cfa
      filename 48000_2.cfa
      filename 48000_3.cfa
      etc....
      seems never ending, I don't understand what is wrong , why the program doesn't use the previous cfa file and create another one ? it's a big waste of time and space disk
        • 1. Re: PPro CS5 always conforming files
          the_wine_snob Level 9
          Please tell us about your system, and especially details on where you have your Scratch Disks located.
          Continued/lost Conforming is often related to external HDD's, networked HDD's, or similar. More detail, the better.
          Good luck,
          Hunt
          • 2. Re: PPro CS5 always conforming files
            jphilip75 Level 1
            I have four internal HDD on my computer , no external drive.
            The media cache files is located on a non-system disk , a 1,5TB HDD with 350GB space free avalaible.
            Well it seems that it depends of the source file, maybe it's the audio track of some files ? I'm just testing CS5 with random imported files. Soome files seem OK others always conform.
            Thanks for your help anyway.
            Phil
            • 3. Re: PPro CS5 always conforming files
              Phil,
              Interesting. I was just throwing out possibilities, based on others' experiences with similar behavior. Sounds like not of those situations match yours.
              I would wonder what would cause this behavior with some files, but not others.
              Good luck, and maybe someone else will have the key to your problem.
              Hunt
              1 person found this helpful
              • 4. Re: PPro CS5 always conforming files
                Wil Renczes Adobe Employee
                Are your source files read-only?
                • 5. Re: PPro CS5 always conforming files
                  LluisV Level 1
                  I'm working in a project with two avchd files (2hours each).  The files where recorded with two identical consumer cameras.  I copied the folders of the sd cards to two folders in the hard disk and imported into Premiere cs5 5.0.2 Every time I open the project, one of the files must be conformed. Allways the same file in the project, and allways the First file I imported.  I tried to import is diferent order and allways the first file must be conformed.  Each camera has three video files, both groups of files have the same names. I thought the problem may be the name of the file... I joined the three files of each camera in one file and renamed it, but I had the same problem, the first file I imported is conformed every time I open the project.  I deleted all temporary files, I copied the files to other folders and created new project for test.  The computer has an I7, 8GB memory, windows7, one 1TB hard disk, adobe production cs5, microsoft office 2007, Adobe Audition, and nothing else.  Can I test something to find a workaround?  Lluís
                  • 6. Re: PPro CS5 always conforming files
                    nahawand
                    same problem with CS5.5..
                    when I read this post I discovered that my internal SATA drive where treated as external drives appearing in Safely Remove Hardware tray, so, I thought that this was the cause for the problem.. I followed this: http://superuser.com/questions/12955/how-do-i-remove-the-option-to-eject-sata-drives-from- the-windows-7-tray-icon doing it for each controller ie. a key for controller0, controller1, etc..  as it it solved my problem of getting the drives in the safely remove hardware tray icon..
                    well, nothing really changed with PPRO doing the same conforming of AVCHD files each time I open the project..
                    AME does the same re-conforming thing when I try to encode sequences from the same AVCHD Project..
                    also in addition, anyone tried to export XDCAM MXF out of PPro then try re-import or enocode using AME? it re-conforms with every single action you try to do withing AME or PPRO.. a nightmare..
                    hope this gets a solution coz its very frustrating..
                    Thanks all,
                    • 7. Re: PPro CS5 always conforming files
                      Karan S.
                      You can try these steps in case of continous conforming of audio files -
                      1. Try resetting the preferences
                      - Windows
                      __________ Go to run, type %appdata% in the box, hit enter. When the Windows Explorer window has opened up, open Adobe folder, then open Premiere Pro folder, delete the specific version folder( or rename that to keep a backup). Do remember to close all the applications before resetting the preferences.
                      - Macintosh
                      _________ Go to {USER}/ Library/ Preferences/ Adobe/ Premiere Pro/ - delete the specific version folder. Remember to close all background applications, including your browser.
                      After resetting the preferences, try putting an audio in a new project. Most probably, your issue would be resolved.
                      • 8. Re: PPro CS5 always conforming files
                        digitlman Level 1
                        function(){return A.apply(null,[this].concat($A(arguments)))}
                        when I read this post I discovered that my internal SATA drive where treated as external drives appearing in Safely Remove Hardware tray, so, I thought that this was the cause for the problem.. I followed this: http://superuser.com/questions/12955/how-do-i-remove-the-option-to-eje ct-sata-drives-from-the-windows-7-tray-icon doing it for each controller ie. a key for controller0, controller1, etc..  as it it solved my problem of getting the drives in the safely remove hardware tray icon..
                        Thanks all,
                        Yes i have the same problem, premiere makes the MXF file with 8 mono audio tracks and sits there and conforms them all (even though they are empty!)
                        conformed audio is simply a nightmare and MUST BE REMOVED FROM FUTURE VERSIONS OF PREMIERE!
                        • 9. Re: PPro CS5 always conforming files
                          Drew_Clockhouse
                          Another solution.
                          To anyone that comes across this thread as I did searching for a solution to this issue this is what worked for me - ffdshow.
                          I am using a particular codec that sort of works in premiere but that I found was giving the constant audio conform problem. After installing ffdshow it went away.
                          I installed version ffdshow_rev3631_20101115_clsid_x64.exe as this is a win7 64 bit version.
                          Basically ffdshow decodes your video files within Premiere. It handles the more esoteric formats that people like to use and also 'pro-sumer' formats like the various flavours of MPEG4 and the compressed audio formats etc.
                          When you install it just tick the formats you want it to decode.
                          Try it, you can always uninstall it if it doesn't work for you.
                          Drew
                          • 10. Re: PPro CS5 always conforming files
                            Harm Millaard Level 7
                            It is even better not to install it at all.
                            • 12. Re: PPro CS5 always conforming files
                              digitlman Level 1
                              I am very familiar with FFDSHOW and do not see how it could cause premiere to stop conforming audio files when video clips are imported. Actually i have it installed on a couple of my machines so i can play back 4:2:2 video in mediaplayer classic but it does not seem to have any effect on premiere.
                              • 13. Re: PPro CS5 always conforming files
                                Drew_Clockhouse Level 1
                                I'm not saying that FFDshow stops Premiere from audio conforming - just the opposite in fact.  For me it allows me to use a particular type of file (fourCC - MP42) within Premiere without getting stuck in an endless conforming audio loop.
                                • 14. Re: PPro CS5 always conforming files
                                  Wild Dog Road Photography Level 1
                                  I have been experiencing this sporadically but frequently enought to be very annoying.  I shoot using a Canon VIXIA (AVCHD) MTS files and a Canon T2i MOV files.  I record wave sound using a Zoom H4n.  I create a project and import all the files into the same directory but separate bins.  Premiere Pro 5 is configured to save the conform files in the same directory as the source files.  Sometimes repeated conforming happens during the initial import.  Today everything went smoothly and I created a FCP transfer file to allow Pluraleyes to create a syncronized FCP transfer file.  PP was left open.  When Pluraleyes finished I went back to PP and it started to repeat the conforming of the all the MTS and MOV files.  This is happening before I load the FCP file.  Looking at the directory it appears that there is a .cfa and a _1.cfa as well as a .pek and a _1.pek for each source file.
                                  Since my projects have 2 to 4 hours of dual camera video this is a huge waste of time.
                                  Sometimes I end up with several _n versions of each pek and cfm file all with the same sizes.
                                  Win 7 64 bit
                                  Dell 8300
                                  8GB ram
                                  External USB2 hard drive
                                  Generally this effect goes away after the initial setup of the project and the import of the Pluraleyes file and any reconforming triggered then.
                                  I will try shutting down PP while PE runs for the next project.
