Exception found .class
Avatar
Level 2
I´m trying this site´s sample:
http://weblogs.macromedia.com/dharfleet/archives/2006/07/integrating_jav.cfm#comments
I have a problem running this. I´m using flex data
service´s jrun server and when I run this, the server send me
a exception and the TextInput still in blank.
I have next tree:
C:\fds2\jrun4\servers\default\flex\FDSWeb\WEB-INF\classes\fdsweb\EchoService.class
and i have edit
C:\fds2\jrun4\servers\default\flex\WEB-INF\flex\remoting-config.xml
file, adding sample´s code.
When I run the integrated flex server i can read next:
error Could not pre-load servlet: MessageBrokerServlet
[1]flex.messaging.MessageException: Cannont create class of
type ´fdsweb.EchoService´. Type
´fdsweb.EchoService´not found.
at flex.messaging.
util.ClassUtil.createClass(ClassUtil.java:57)
at
flex.messaging.factories.JavaFactory$JavaFactoryInstance.getInstanceClass(JavaFactory.java:244)
Someone can help me???
1 Reply
Avatar
Level 3
Have you restarted your JRun server since dropping that
.class file in WEB-INF\classes? Also, double check that you've
added the class file to the correct web app. This error indicates
that loading the "fdsweb.EchoService" class failed due to a
ClassNotFoundException - so once you get that class on the web
app's classpath you'll be fine.
Best,
Seth
