I had this issue before where only flash based applications would launch but not adobe air. The issue is when you click run on adobe air, in the task manager on windows 7, 64 bit you get: Adobe Air Debug Launcher. Killing that gives me: If the program is already running, close it before attempting to run.
The program never launches hence why you have to kill it in the task manager.
I tried cleaning out the PreloadSWF entry in the mmc.cfg file. This does nothing to help the cause.
Ideas?
please help byresponding - bump
bump
bump
Does your application descriptor XML file have visible set to true?
A stale preload entry and visible being set to false are two things that can cause this.
-Anirudh
Please read the OP on the stale pale loader. I already took out the line in mm.cfg and I set vsible to true (never had to before on any air application Oo)
Tests:
The setting to visible to true though worked..... (again with never had to set that before)
WindowedApplication sets visible to true at the right time.
If you're using something else as the root class (like s:Application), then you need to toggle visible.
OMG, thank you! This was the first time I needed it. I thought it was a bug...
