Is there any way for securing the serverside actionscript code so that it wont be acceessible to others ? At present all the code we have is just plain text which anybody can read and understand. Any help will be appreciated.
Did you look at the -compile option?
It creates bytecode out of your script. Won't that help you?
Check out far.exe tool in fms tools folder.
-compile and/or -package option should help.
thanks vijay for that quick answer. but i have already looked in to it and waht i understood is its just a compressing utility where anybody can uncopress it also. i may be wrong but is there any article which mention the usage of this tool ?
Actually i haven't looked in to the compile option. If its outputting bytecodes certainly that will solve my issue, Let me have a look. thanks.
Out of curiosity how would one go about viewing SSAS without actaully logging into my FMS server locally if you will and opening the application folder?
in an ideal case where you have full physical control over the server this issue wont come. but there are scenarios where you share a server with somebody else also. so its better to be on safer side always by keeping your code secure.
