error
Hi Guys,
This is my first post in this forum, hence I am new to flex programming.
i have created a simple hello world mobile application using following url http://www.adobe.com/devnet/flash-builder/articles/hello-world.html .this application worked properly on emulator but on physical device it gives following error
i am using Adobe Flash Builder 4.5.1
please tell me what should i do to solve this problem.
please help me.
Thanks in advance.
Your phone cannot install AIR applications because it is under the minimal requirements :
http://www.adobe.com/products/air/systemreqs/
Your phone contains an ARMv6 600MHz processor.
Sorry
How did you create the APK? Try to export a release build and install it with adb install (in the command line)
i am using On device launch method to test my application on my handset. Failure[INSTALL_FAILED_INVALID_APK] error always occured . i am using release build method to create apk file but generated apk not installed in my handset.
Try emailing it to yourself and installing it that way. Make sure your phone options are set to allow for non Android Market files to be installed. I had to do a system update on my HTC Inspire to allow for this.
What is your device model?
Samsung Galaxy 5
Sorry
Oh.... thats the problem
anyways Thanks a lot for your help Rangora
