Hi, I'm using captivate 5. I have a simulation course where i need to insert text boxes for interactivity. I have successfully inserted several textboxes and was able to publish or view it in swf successfully. However, after several textboxes, the next time i tried to view or even publish my course, I got this error message. I was able to narrow down what's causing it and indeed it's whenver i insert additional textboxes.
Some attempts i did:
1) I tried to change the textbox' variable name - failed
2) Change Item name - failed.
Any help would be greatly appreciated!!
Hello,
From the message I can only conclude that you have used twice the same ID-label. This could be for the user variable associated with Text Entry Boxes, but also for all objects. Each need an invididual ID. Try to change the labels of the TEB's themselves. And some words are reserved as well - see Help. Do you use advanced actions?
Lilybiri
