1. Re: TROUBLE WITH DIP TO BLACK IN AFTER EFFECTS CS5
Todd_Kopriva Aug 16, 2011 10:43 PM (in response to dolamike810)Your question isn't clear. Are you using After Effects CS5 or CS5.5?
What exactly are you seeing and what are you doing?
I'm going to guess about how to interpret your post and point you to this thread about a bug in After Effects CS5 and a workaround for it:
http://forums.adobe.com/message/3455089#3455089
That bug is fixed in After Effects CS5.5.
2. Re: TROUBLE WITH DIP TO BLACK IN AFTER EFFECTS CS5
dolamike810 Aug 16, 2011 11:21 PM (in response to Todd_Kopriva)im using cs5.5 and they fixed the cross dissolve but now dip to black seems 2 have the same bug.so my cross dissolves are fine but when i preview my clip it doesnt dip 2 black...
3. Re: TROUBLE WITH DIP TO BLACK IN AFTER EFFECTS CS5
Todd_Kopriva Aug 16, 2011 11:29 PM (in response to dolamike810)See the documentation for what is supposed to come across. The only transition mentioned as being supported is cross dissolve. Dip to black isn't on the list.
4. Re: TROUBLE WITH DIP TO BLACK IN AFTER EFFECTS CS5
dolamike810 Aug 17, 2011 6:41 PM (in response to Todd_Kopriva)ok well it must be a bug they over looked or im not doing sumthen rite the dip to black is n my comp but when i play it it doesnt dip 2 black. it just shows as a black video all my cross dissolves work but not my dip 2 black problem still not solved...
5. Re: TROUBLE WITH DIP TO BLACK IN AFTER EFFECTS CS5
Todd_Kopriva Aug 17, 2011 7:12 PM (in response to dolamike810)It seems that you didn't understand my response.
The dip to black transition is not one that is supposed to come across from Premiere Pro to After Effects. See the link that I provided for details of what comes across.
6. Re: TROUBLE WITH DIP TO BLACK IN AFTER EFFECTS CS5
dolamike810 Aug 17, 2011 7:25 PM (in response to Todd_Kopriva)o ok sorry 4 the miss read well im workin on my project now this is what i got happening now if i import the sequence into ae cs5.5 as just 1 clip with no cuts it dips 2 black but if i double click on clip so i csn se my wholr composition it doesnt dip 2 black so what can i do do i have 2 go back and re edit in premiere pro? just 2 get the dip 2 black what do u suggest?
