Is it possible to change a sequences settings once you've set up the sequence?
In Sequence Settings everything is grayed out so I can't change it.
In that case, no.
But you can create a new one with the desired settings and Copy/Paste clips into it.
In that case, no.
Too bad. In FCP you can change the sequence settings to anything anytime. It may not look right, but you can do it.
Thanks for you help.
Here is one way to be sure your sequence is right so you don't have to make changes
Just out of curiosity, if the footage does not look right, what would be the purpose of changing the Sequences' settings?
Hunt
If, for instance, you created a DV seq and put HD material in it - FC would resize the material to DV size, when you changed the seq setting to HD the clip would be too small, you could then remove the resizing so it would display properly. It would ususally be easer to create a new seq and copy and paste into it, same as Premeir.
OK, thanks.
In PrPro, from CS 5 up, one can just Import an Asset into the Project, and then drag that Asset to the New Icon, and PrPro will create the proper Sequence for that, so one should not have to change Sequence settings, or experience having the wrong one.
Good luck,
Hunt
Hello All
Problem with that is that some media, AVCHD, is being read wrong by Premiere. I have personally tried what you suggest with AVCHD 1080p video clips and had them set to be on a AVC - Intra 100 1080i 60hz timeline after dropping them on the new sequence icon. There are a lot of threads about this problem and I have fallen victim to it twice since moving to CS6. In my most recent case I didn't notice till it was too late. Now I have to replace all the sequences I have this sequence clip on with a new one.
What type of camera did you record your AVCHD footage on? The reason I ask is because I'm thinking the most likely reason it thought your video was interlaced is because several AVCHD camera's shoot footage that they call "1080p" but it's not actually normal progressive footage. It's actually PsF footage. (Progressive segmented frame) Which with this footage it just records both fields, so what ends up happening is that Premiere ends up reading the footage like it's interlaced which it basically is, except unlike normal interlaced footage this PsF has both fields. Anyways though you can find out if this is the case by using the modify>interpet option from inside your bin, then if it says that you files field order is anything besides progressive then you'll know you will need to conform the footage to progressive as explained in this article in order to make Premiere work with it properly. Although this issue might not be the same thing you're experincing I just figured I'd mention that since it's fairly common place for AVCHD cameras to record PsF.
You may want to check out this article although it may not apply to you depending on what type of camera you're using. Although they cover basically all the major AVCHD camera makers
They talk about several Cannon, Panasonic and Sony avchd cameras that all currently record footage this way.
Canon Vixia HFS20
Sony HDR-XR150
I have already been through the parts of the articles I needed to. I am reworking a project now that I know what is going on. From this point on I have to remember that all my footage from these 2 cameras are fake interlaced that needs to be interpreted.
Thanks.
Hopefully at some point camera makers will start being a little bit more up front with this information. I actually ran into quite a big headache awhile ago when I got some footage from a client and it drove me nuts that Sony didn't disclose all the facts and they simply list it as 1080p even though no edit programs are going to see it as 1080p... I remember I kept wondering why my finished product didn't look crisp and clear and instead looked "jagged" and "blurry" then I came accross the pro video articles that explained what was going on. I find it silly that the camera makers can't simply list the fact it's PsF and also the fact that both Final Cut and Premiere will see it as interlaced somewhere in their manuals...
Although quite a few AVCHD cams shoot in PsF so I guess they might be figuring we should just know. But still I think it's silly.
But that's just my personal hope. However until then I'm glad you now have a proper work-around.
Does this also apply to progressive footage. I read somewhere that "all HD video... if you're shooting progressive video both fields are displayed simultaniously." I was always under the impression that progressive video was only one frame, no fields.
Normally, progressive video is all one frame, no fields. But some cameras don't record true progressive, they record what's called PsF, Progressive Segmented Frame. It splits the original frame up into two separate fields. This is done to make the footage compatible with broadcast hardware that simply isn't capable of dealing with progressive footage. It's a technique that had much more relevance in the days of analog standard definition broadcasting, which was originally only interlaced with progressive SD coming along decades later. But the new ATSC standard has had genuine progressive timing as part of the specification from the start, so there's really no good excuse for any HD video to be using PsF, other than maybe some camera makers cheaping out on their chips.
That's what I thought. Just wanted to confirm.
My Panasonic HMC150 says it records natively as progressive and if you choose interlaced it will process it internally before send out interlaced. This isn't what you're referring to, is it?
Thanks again,
Nope. Panny's do it right with genuine progressive sensors and recording.
Sa - weet! Thanks.
To change sequence settings with Premiere Pro CC, right click on the sequence in your project panel ---- Change sequence settings----- Choose the preset you want.
Can't do that in previous version. As it has been said already, just create a new sequence with the right settings and just copy-paste from previous sequence timeline.
Here's a video tutorial of how to fix the horizontal lines issue by changing the sequence settings.
Jim Simon wrote:
In that case, no.
In 5.5 I did noticed the handles on clips were sometimes lost when copying and pasting clips into a new sequence, in that you can't change the in and out points to extend the duration as you could in the original sequence. What I did was copy and paste the entire clip then set the in and out point in the final sequence. I hope that has been fixed in 6.0.
This literally just saved me 30 hours of work. Thanks!
Here's more information about choosing and changing sequence settings:
Well yes but only if the sequence is empty.
Drag clip to timeline and a Clip Mismatch Warning dialog box appears.
Hit Change Sequence Settings.
Ann,
Good call. I had not considered that possible workflow. You have just altered my way of thinking, as would have said "No," until you pointed out this exception.
Thank you,
Hunt
If not the video side of the sequence, it would be nice to be able to change the Audio master track. I keep forgetting to make my sequences 5.1.
Richard Knight
I emptied my sequence still could not make the changes. Does it also have to not be used anywhere as a nested timeline?
