I am using RoboHelp 8 to create a CHM file. The CHM file has a listing of buttons at the top, one of which is Options. Is there a wa to disable the Options button from showing on the toolbar?
Cheryl
Hi Cheryl. You can disable that button inside the properties of the window you are using (see below).
The RoboColum(n) | @robocolumn | Colum McAndrew |
Welcome to our community
If you click View > Pods > Project Set-up you will focus the Project Set-up pod.
Expand the Windows section.
Double-click the CHM window type (assuming it exists - it may not and you may need to create one)
Look at the Buttons area. There is a check box you need to clear.
Recompile and ensure your Single Source Layout recipe is pointing at your window you should be set.
Cheers... Rick
