showing a pdf
Guest
Aug 23, 2006 Aug 23, 2006
Hi i am using coldfusion mx 6.1
i have a query output which i want to show as a printable pdf, i know this is possible using coldfusion 7
can i do this with mx 6.1?
Advanced techniques
497
Participant ,
Aug 24, 2006 Aug 24, 2006
Hi
can you try by setting the cfheader & cfcontent tags to pdf format.
i am doing the same thing for and xml. i am using the below code to display in excel.
so in the same u can get it i think so.
<CFHEADER NAME="content-disposition" VALUE="attachment; filename=new.xls">
<CFCONTENT TYPE="application/vnd.ms-excel">
Guest
ok many thanks
but how would i do this from a query and display my output as a pdf
Participant ,
Hi
First design the cfm page in general way how it has display.
once this is done then put those 2 tags in the first, and run this file..it will shows in pdf format.
Guest
Aug 25, 2006 Aug 25, 2006
ok thanks so would this be the code below?
<CFHEADER NAME="content-disposition" VALUE="attachment; filename=new.pdf">
<CFCONTENT TYPE="application/vnd.ms-pdf">
I though it was not possible to show PDF format on 6.1, you can do the excel and word doc, but PDF I'm not sure, because the document tag was introduced in MX 7
Documentation
