Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Repeating subform placed on next page
Avatar
Level 2
How do I force a repeating subform to be placed at the top of the next page everytime the "add" button is clicked?
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
On the Pagination tab in the Place property choose Top of Next page as your option instead of following previous.
Paul
Avatar
Correct answer by
Paul
Avatar
Level 2
Thanks for answering. When I do that it adds and extra page.
Avatar
What is your setting for the After parameter on the same pagination tab?
Paul
Avatar
Just tried it here and i a not seeing that behaviour .....can you send your form to LiveCycle8@gmail.com and I will have a look and see if I can spot something.
Paul
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
