Under MacOS X (10.6.8), the firewall restricts all incoming communications. But this can be changed in the firewall settings as an exception to automatically allow "signed software" to receive incoming communications.
However this doesn't seem to work with Adobe Flash Builder 4.5 for PHP. When I check the code-signing status of the Application, it doesn't look good:
$ codesign -vvv /Applications/Adobe\ Flash\ Builder\ 4.5/Adobe\ Flash\ Builder\ 4.5.app/ /Applications/Adobe Flash Builder 4.5/Adobe Flash Builder 4.5.app/: a sealed resource is missing or invalid /Applications/Adobe Flash Builder 4.5/Adobe Flash Builder 4.5.app/Contents/Resources/AMT/AAM/LWA/ZS/en_US/stringtable.xml: resource added /Applications/Adobe Flash Builder 4.5/Adobe Flash Builder 4.5.app/Contents/Resources/AMT/application.xml: resource modified /Applications/Adobe Flash Builder 4.5/Adobe Flash Builder 4.5.app/Contents/Resources/AMT/adobe.trial.suppress: resource missing
The only work around for my remote debugging to work is to disable the firewall, every time I do my work. Can someone from Adobe/Zend confirm if what I have described here is a known issue?
I want to know if this issue was faced by you in FB PHP 4.5 or FB PHP 4.5.1. This was a bug we had run into in 4.5. I would request to try the 4.5.1 installer for FB PHP.
http://www.adobe.com/cfusion/tdrc/index.cfm?product=flash_builder_php
The bug has been resolved in this version. Please report back to us if you face this issue again.
Nishad
Hi Nishad,
Thanks for the response. I bought Flash Builder 4.5 for PHP when it came out and had an update applied when 4.5.1 was released. Attached screenshot of the Installed software:
are you saying I need to re-install Flash Builder to fix this problem?
Hi ,
This is an issue which only a full build can fix. I see that you have
applied the patch to install 4.5.1. I suggest you install the full
build the location to which I had given before. You can use the same
license number. This should resolve the issue. Do let us know if it
doesn't.
Nishad
Hi Nishad,
Will a re-install retain all my project settings and plugins I have installed? Or to word it differently, what settings will I lose if I install the Flash Builder 4.5.1 for PHP from above link.
You can use the same workspace after reinstalling. I am afraid you
will lose the installed plugins. Those you might have to install
again. I suggest trying out the fix on another system to make sure if
the remote debugging works the way you expect it to before
uninstalling.
Nishad
