1. Re: First Play Problems
Stan Jones Aug 24, 2011 6:06 AM (in response to bigmanfontu)Seems like this has come up before. Burn a test disk and it will probably work. I assume you are playing a folder on the computer for your test of the build.
I just did a test, and I get correct results in Encore preview and from a burned disk, but not from a build to folder using vlc player.
2. Re: First Play Problems
Neil Wilkes Aug 24, 2011 8:23 AM (in response to Stan Jones)I second that - software players are frankly all a bad joke.
The only way to test anything is to try it in a Nuts n Bolts player
Personally, I'd dump the MPA audio too - it blows even harder than Dullby does..
3. Re: First Play Problems
bigmanfontu Aug 24, 2011 10:16 AM (in response to Stan Jones)Hey,
You were right on the money. I do use VLC for pretty much everything, including previewing the folder containing the dvd files. And through VLC the intro didnt play and the button subpictures all looked wonky.
But, just as you said, I burned a test copy to disc and it looked and played exactly as it should.
It seems I was getting frustrated over nothing. Ha ha.
It's hard to believe that the software still isn't there for computers to play DVD's accurately.
Thanks for your help.
4. Re: First Play Problems
President Beeblebrox May 26, 2013 5:10 PM (in response to bigmanfontu)I don't really want to be a thread necro, but I have looked EVERYWHERE to find the solution to my problem.
Same thing -> Play First wouldn't play. Curse you VLC!
On my PSP3 it worked perfectly
A very late, but warm THANK YOU.
