Hi Joan and welcome to our community
Questions:
1. Does this only happen in Internet Explorer (IE) or does it
happen in all browsers?
2. If it only happens in IE, for the movies that are
exhibiting this behavior, have you simply tried hovering the mouse
over the movie before trying to click the button? If so, so you see
a little yellow "tooltip" appear that says something to the effect
of "Click to activate and use this control"?
If this is the case, it's a result of a change in behavior
that Microsoft was forced to make to the way IE handles content
such as Flash files. Again, if this is the case, the first click
"activates" the control. (basically patting Internet Explorer on
the head and telling it that the world will, in fact, NOT come to a
fiery end if it shows you the active content). Subsequent clicks
should be interpreted as they should be until a different movie is
loaded up. Then things start over.
Hopefully this helps... Rick
