can you try by setting the cfheader & cfcontent tags to
pdf format.
i am doing the same thing for and xml. i am using the below
code to display in excel.
so in the same u can get it i think so.
First design the cfm page in general way how it has display.
once this is done then put those 2 tags in the first, and run
this file..it will shows in pdf format.
I though it was not possible to show PDF format on 6.1, you
can do the excel and word doc, but PDF I'm not sure, because the
document tag was introduced in MX 7
