19 Replies Latest reply on Jul 21, 2012 5:31 PM by M0N5TERS
    StageVideo on iOS
    KarelBrascamp
      Hi all,
      It would be so great if there would be stagevideo support for iOS devices. I know there's a workaround using StageWebView, but I need to be able to place objects on top of the video.
      Does anyone know if, and if so, when Adobe plans to release support for StageVideo on iOS?
      Karel
        • 1. Re: StageVideo on iOS
          relaxatraja Level 5
          You can do call the native video player from the IOS using stagewebview and play H.264 videos.
          • 2. Re: StageVideo on iOS
            KarelBrascamp Level 1
            Thanks, but using the stagewebview workaround, I'm not able to put flash objects on top of the video. And I need that for my application..
            • 3. Re: StageVideo on iOS
              relaxatraja Level 5
              I think its possible if you not occupy the whole stage width and height. and you can use the space for your purpose?
              • 4. Re: StageVideo on iOS
                Nope, I need to place objects on top of the video. Wich according to the documentation, doesn't seem possible:
                'The StageWebView instance attached to a stage is displayed on top of any Flash display objects' (source)
                Cheers,
                Karel
                • 5. Re: StageVideo on iOS
                  sebelga
                  Hello,
                  I'm trying to do the same thing with the new AIR 3 beta 2 in Adobe Labs. With the new stagevideo API available for iOS we should be able to play a h264 movie. I'm trying it on a iPad 1 with iOS 4.3.5 with no luck. I get the sound playing, but no video. I do get the "Accelerated" with GPU though....
                  Have you tried it yourselft with better results?
                  thanks..
                  sebastian
                  • 6. Re: StageVideo on iOS
                    loic_digitas
                    Hello Sebelga,
                    I'm trying the same thing than you with an iPad 1 with iOS 4.3.3 and I have the same result. I have the sound but no video with the gpu render mode.
                    Adobe, do you know if it's a known issue with the iPad 1 ?
                    Thank you
                    Loïc
                    • 7. Re: StageVideo on iOS
                      sebelga Level 1
                      I created a bug at Adobe. You will find there a zip file with the test project I did.
                      At the end I could see a portion of the video "outside" the stage.. Check it to understand.
                      https://bugbase.adobe.com/index.cfm?event=bug&id=2960080
                      seb
                      • 8. Re: StageVideo on iOS
                        I actually managed to do it, targeting flash player 11, and packaging with the Adobe Air 3.0 RC sdk.
                        • 9. Re: StageVideo on iOS
                          Arthy the crab
                          @karelBrascamp : Is it possible to get your example files ? i spent my week end trying to do it on android + ipad2... (i successfully traced the runtime as the latest airt3 beta, but still no stagevideo available)
                          • 10. Re: StageVideo on iOS
                            Arthy the crab Level 1
                            Ok i did successfully in integrating VideoStage and play accelerated video, but performance are very bad and far from expected, even if followed adobe recommandation from Adobe AIR TV article : http://www.adobe.com/devnet/devices/articles/video_content_tv.html.
                            • Video codec: H.264, Main or High profile, progressive encoding
                            • Resolution: 720i, 720p, 1080i, or 1080p
                            • Frame rate: 24 or 30 frames per second
                            • Audio codec: AAC-LC or AC3, 44.1 kHz, stereo
                            • Combined bit rate: up to 2Mbps (or higher depending on available bandwidth)
                            • Audio bit rate: up to 192 kbps
                            • Pixel aspect ratio: 1 × 1
                            performance on Xoom tablet are not good. Did someone managed in configuring AIR3 app + video encoding to fit expected results (0% CPU, and 100% GPU video decoding as i understood) ????
                            • 11. Re: StageVideo on iOS
                              BoogieBot
                              Hey guys, I've put together an iOS Stage Video class that works great on iPad/iPad2 (have yet to test it on my iPhones), this should help you out! It's not perfect, but it works like a charm!
                              You will have to add in the following compiler arguments to your Flex project:
                              -swf-version=13 -target-player=11.0
                              and in your app descriptor file set the rendermode to 'direct'
                              <renderMode>direct</renderMode>
                              you must also set the 'backgroundAlpha' to 0 on your main component
                              usage:
                              var path:String = new File(new File( app:/path/to/mp4 ).nativePath).url;
                              var vid:iOSStageVideo = new iOSStageVideo( path , 1024 , 768 );
                              vid.addEventListener('videoDone' , function():void{
                              vid.stopVideo();
                              container.removeChild( vid );
                              removeElement( container );
                              container = new UIComponent();
                              container.width = stage.stageWidth;
                              container.height = stage.stageHeight;
                              addElement( container );
                              container.addChild( vid );
                              and here is the class:
                              package
                                        import flash.display.Sprite;
                                        import flash.display.StageAlign;
                                        import flash.display.StageQuality;
                                        import flash.display.StageScaleMode;
                                        import flash.events.Event;
                                        import flash.events.NetStatusEvent;
                                        import flash.events.StageVideoAvailabilityEvent;
                                        import flash.events.StageVideoEvent;
                                        import flash.geom.Rectangle;
                                        import flash.media.StageVideo;
                                        import flash.media.StageVideoAvailability;
                                        import flash.media.Video;
                                        import flash.net.NetConnection;
                                        import flash.net.NetStream;
                                        [Bindable]
                                        public class iOSStageVideo extends Sprite
                                                  private var videoPath:String;
                                                  private var videoWidth:Number;
                                                  private var videoHeight:Number;
                                                  private var _sv:StageVideo;
                                                  private var _vd:Video;
                                                  private var _obj:Object;
                                                  private var _ns:NetStream;
                                                  public function iOSStageVideo( path:String , w:Number , h:Number ){
                                                            videoPath = path;
                                                            videoWidth = w;
                                                            videoHeight = h;
                                                            addEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
                                                  //stage is ready
                                                  private function onAddedToStage(e:Event):void{
                                                            stage.scaleMode = StageScaleMode.NO_SCALE;
                                                            stage.align = StageAlign.TOP_LEFT;
                                                            var nc:NetConnection = new NetConnection();
                                                            nc.connect(null);
                                                            _ns =  new NetStream(nc);
                                                            _obj = new Object();
                                                            _ns.client = _obj; _ns.bufferTime = 2;
                                                            _ns.client = _obj;
                                                            _obj.onMetaData = MetaData;
                                                            _sv = stage.stageVideos[0];
                                                            _sv.viewPort = new Rectangle(0, 0, videoWidth , videoHeight );
                                                            _sv.attachNetStream(_ns);
                                                            playVideo();
                                                  //video is ready, play it
                                                  //public, can be called externally
                                                  public function playVideo():void{
                                                            _ns.play( videoPath );
                                                            _ns.addEventListener(NetStatusEvent.NET_STATUS, videoStatus);
                                                  //required metadata for stagevideo, even if not used
                                                  private function MetaData(info:Object):void{ }
                                                  //get video status
                                                  private function videoStatus(e:NetStatusEvent):void{
                                                            switch(e.info.code){
        case "NetStream.Play.StreamNotFound":
        //do something
        break;
        case "NetStream.Play.Start":
        //do something
        break
        case "NetStream.Play.Stop":
        stopVideo();
        break;
        case "NetStream.Buffer.Empty":
        //do something
        break;
        case "NetStream.Buffer.Full":
        //do something
        break;
        case "NetStream.Buffer.Flush":
        //do something
        break;
                                                  //stop and clear the video
                                                  public function stopVideo():void{
                                                            _ns.close();
                                                            _ns.dispose();
                                                            dispatchEvent( new Event('videoDone', true ) );
                              • 12. Re: StageVideo on iOS
                                billo Level 1
                                Can someone please provide a Flash Professional CS5.5 solution for StageVideo on iOS.  A FLA file would be preferred.  I have used StageWebView successfully on an iPad.  I have tried using various document classes but cannot get the video file to play.  The solution must stream the video file from a remote server (NOT A FLASH MEDIA SERVER).  Are there any settings that need to be adjusted within Flash Professional CS5.5?  Remember, I DO NOT want a Flash Builder solution only Flash Professional CS5.5!
                                • 13. Re: StageVideo on iOS
                                  Sharpe D User Group Manager
                                  Did anyone ever come up with a StageVideo example for Flash CS 5.5?
                                  Dave
                                  • 14. Re: StageVideo on iOS
                                    billo Level 1
                                    Below is the Flash CS5.5 solution. Make sure your using AIR 3.1 and the AIR for iOS rendering setting is set to GPU.
                                    package {
                                              import flash.desktop.NativeApplication;
                                              import flash.desktop.SystemIdleMode;
                                              import flash.display.MovieClip;
                                              public class Main extends MovieClip {
                                                        private var VIDEO_URL:String = "http://www.website.com/video.mp4";
                                                        private var netConnection:NetConnection;
                                                        private var netStream:NetStream;
                                                        private var video:StageVideo;
                                                        public function Main() {
        NativeApplication.nativeApplication.systemIdleMode = SystemIdleMode.KEEP_AWAKE;
        netConnection = new NetConnection();
        netConnection.connect(null);
        netStream = new NetStream(netConnection);
        netStream.client = this;
        video = stage.stageVideos[0];
        video.attachNetStream(netStream);
        video.viewPort = new Rectangle(0, 0, 480, 270);
        netStream.play(VIDEO_URL);
                                                        public function onMetaData(dataObj:Object):void {
        // Do nothing.
                                    • 15. Re: StageVideo on iOS
                                      franky303at
                                      for me it only plays sound, no video visible
                                      • 16. Re: StageVideo on iOS
                                        billo Level 1
                                        franky303at -- What version of Air are you using?  I used Air 3.1 for this file.  Did you set rendering to GPU?  Did you test it on the device?
                                        • 17. Re: StageVideo on iOS
                                          franky303at Level 1
                                          Tried setting both renderMode "direct" and "gpu". - Using AIR 3.2 SDK ...   And yes, only testing on ipad 2 with iOS 5.1.  Both target ipa-debug and ipa-ad-hoc ...   Video is mp4 with h264 codec.
                                          • 18. Re: StageVideo on iOS
                                            DanaBrousseau
                                            The tutorial posted here: http://01am.co.uk/comment/2 is working perfectly for me.
                                            However, I get no audio. The mp4 file itself contains audio (when played in Quicktime) but is silent when played in my IOS app.
                                            Is there something I need to do to activate StageVideo's sound? Has anyone else had similar issues?
                                            • 19. Re: StageVideo on iOS
                                              M0N5TERS
                                              I had the same issue. It seems to be a bug. There's an easy way to fix it. Just play a sound, before playing the video.
                                              I just added a short sound file that I'm playing onLoad. Without this, Flash doesn't seem to know how to handle sound in video files, but once you played a sound, it "remembers" how to do it for stagevideo.
                                              Silly solution, but it worked for me
