1 2 Previous Next 51 Replies Latest reply on Nov 6, 2013 6:04 PM by Leftee
    PROBLEMS opening  PDF in IE 9 or X
    Jim_TSI
      How can it be that Adobe releases a new version not able to open a PDF from a link?
      ADOBE GET IT FIXED!!!!!!!
      It can not be true that you have to change the settings in preferences before it works. How do I explain this to 1000 of  my costumers?
        • 1. Re: PROBLEMS opening  PDF in IE 9 or X
          dave_m_k Adobe Employee
          Good day,
          Microsoft Internet Explorer 9 was released after development for Adobe Reader X was complete.  While we made every effort to anticipate the way the final release version of IE9 would behave, our PDF viewer plugin is not yet compatible with IE9.  This is being worked on by our engineering department.  In the interim, when trying to open a PDF file from the browser, save it locally to your computer and open it directly in Adobe Reader.
          Moving forward, please continue to install updates to Adobe Reader X as they become available.  When this issue has been resolved, it will be pushed via an update.
          Thank you,
          David
          Acrobat Community Manager
          Adobe Systems
          • 2. Re: PROBLEMS opening  PDF in IE 9 or X
            Andrea Taroni
            I hope it will be fixed shortely, but for now I prefer to install a previous version...
            Adobe acrobat 8 has a problem with IE9 too, in spooling phase.
            • 3. Re: PROBLEMS opening  PDF in IE 9 or X
              Flying_Kiwi
              dave_m_k wrote:
              Good day,
              Hello David and thank you for that reply. This is all very well and good when pdf files can be saved to the desktop but I have a few where the last thing I click on in IE9 to get to the pdf is not a shortcut to the pdf itself but a radio button leading to another page (which then somehow pushes the pdf to me). If I right click on that final webpage 'confirm' radio button before the pdf opens in my browser (but cannot be worked with properly because the buttons don't work), I do not get the option to save the pdf as a file. There seems that in some cases saving the pdf to file just isn't an option...
              How can I view such files in the interim until Adobe have this problem nailed - and when do you expect to release the patch for Reader X which addresses this? If you can't be specific is it days.... weeks or.... well you get the idea?
              • 4. Re: PROBLEMS opening  PDF in IE 9 or X
                Bugsy14u Level 1
                I am running XP  sp2/sp3 with IE8 and it doesn't work in that either. Contacted support ,moronic term, on 4/13 and they had no clue there was even a problem. Maybe someone in India could help??
                • 5. Re: PROBLEMS opening  PDF in IE 9 or X
                  Andrea Taroni Level 1
                  Hi, I have resolved my problem in an unexpected way:
                  http://kb2.adobe.com/cps/404/kb404597.html
                  I think it may help you...
                  • 6. Re: PROBLEMS opening  PDF in IE 9 or X
                    Flying_Kiwi Level 1
                    Alas that solution doesn't work for me and I still have problems with Reader X under IE9 and Windows 7 SP1 (x64 now) set to 150% display settings. The toolbars won't work and it's just hopeless trying to do anything unless it can be opened in the standalone version of Reader X. Unfortunately not all websites make this easy as not all give the option of saving the pdf file to disk. I really hope a fix for this will be coming soon and I've applied to assist with the pre-release version coming up...
                    • 7. Re: PROBLEMS opening  PDF in IE 9 or X
                      dawnjamin
                      I am using Win7 (32-bit), IE9 and ARX.  I cannot view PDFs on some websites.  I bank with two different banks, I can get my bank statement on one site but not the other site.  The suggestion of saving the PDF to my computer then opening locally doesn't work either.  It tells me pdf couldn't be downloaded.  This problem started sometime in the past 3 months, but I don't know the timeline of what programs were updated/installed.  About 5 or 6 weeks ago my browser was updated, but I don't know when Adobe Reader was last updated.  Before I found this thread, I uninstalled/reinstalled ARX thinking there was a problem with my version of it.  Has this incompatibility issue been fixed yet?  Is there something else I can try?
                      • 8. Re: PROBLEMS opening  PDF in IE 9 or X
                        Flying_Kiwi Level 1
                        If you are getting a message such as this, I suspect that's down to the server at the other end. At least you can right click and attempt to save to disk - many of the pdf files I'm thinking of, don't give that option because there's a button to open them. They do open in ARX within IE9 but because none of the menu or toolbar options work, I can't then save the pdf to open it in stand-alone ARX.
                        I've chased up my application to assist with pre-release testing but was advised they may or may not choose me to help. I guess they must have a huge workload to make it compatible with IE9 on Win 7 with displays set to other than 100% and still be working on getting a pre-release ready....
                        • 9. Re: PROBLEMS opening  PDF in IE 9 or X
                          FloridaRex
                          I have learned that by downloading Chrome, you can open PDF files. For the time being I'm using it as a work-around, but I do hope that the problem with Internet Explorer is worked out.l
                          • 10. Re: PROBLEMS opening  PDF in IE 9 or X
                            zannix
                            Yeah, just switching a browser is a good idea that works. Google Chrome is far better than IE in my opinion anyway.
                            • 11. Re: PROBLEMS opening  PDF in IE 9 or X
                              DanFromBoston
                              This problem has been out there for 5 months now.  I get an update from Adobe everytime I turn around, but IE9 still crashes on downloading PDF's.  When are
                              you guys going to get this fixed?
                              • 12. Re: PROBLEMS opening  PDF in IE 9 or X
                                wildplaces1 Level 1
                                Easy for you to say, but if .NET business software requires IE we have no choice in the matter.
                                • 13. Re: PROBLEMS opening  PDF in IE 9 or X
                                  Lion Rock Level 1
                                  Well Adobe released AR version 10.1.1 on 13 Sep and the release notes say:
                                  Added support for:
                                  Microsoft Windows 7 or Windows 7 SP1 Starter, Home Premium, Professional, Ultimate or Enterprise (32 bit and 64 bit)
                                  • Viewing PDFs in Firefox 4 on Windows (not Mac)
                                  • WebCapture with Firefox 4 and IE 9 on Win and Mac
                                  • Mac OS 10.6.7
                                  • IE 9 is fully supported.
                                  So I duly updated and expected the IE9 and ARX incompatibility problem to be solved.  But alas I still cannot view or download PDF statements from my credit card company. When I click on the PDF link absolutely nothing happens.  So I have no idea what the problem is now!  I am using Win 7, IE9 (32bit) and AR 10.1.1  Does anyone have an idea on what the problem could be?
                                  • 14. Re: PROBLEMS opening  PDF in IE 9 or X
                                    wildplaces1 Level 1
                                    Try going into the Advanced settings under Internet Options.  Under the <Browsing> section make sure the box "Use 3rd rty Browser Extensions" is checked.
                                    • 15. Re: PROBLEMS opening  PDF in IE 9 or X
                                      Lion Rock Level 1
                                      Thanks for the suggestion, in my case the "Enable third-party browser extensions" box is checked.  Any more ideas appreciated.
                                      • 16. Re: PROBLEMS opening  PDF in IE 9 or X
                                        Lion Rock Level 1
                                        In IE9 try going to Tools/Compatibility View settings  and add the site where the PDF is located to the Compatability list.  This worked for me.
                                        • 17. Re: PROBLEMS opening  PDF in IE 9 or X
                                          oracledba01
                                          I suspect you are trying to open the pdf doc (32 bit) with a 64 bit browser.  In windows 7, the OS is likely 64 bit but it will support both 32/64 bit programs.  Try navigating to program files (x86), then to the folder Internet Explorer.  Find the iexplore application and right click!  run this program as administrator if possible.  now navigate to website where pdf is available, you should be able to open the file now.
                                          • 18. Re: PROBLEMS opening  PDF in IE 9 or X
                                            FloridaRex Level 1
                                            Thank you.
                                            Yours, Rex
                                            [private data removed]
                                            • 19. Re: PROBLEMS opening  PDF in IE 9 or X
                                              welshaddict
                                              I know it's been a while since this post was posted but as I've found a way around this problem I thought I'd share it. If you download files using firefox instead of internet expolorer they download with no problems
                                              • 20. Re: PROBLEMS opening  PDF in IE 9 or X
                                                TapperAronson
                                                I think the problem is with Internet Explorer 9, not with Adobe Reader X.  I downloaded the free version of Apple's Safari as my web browser  Then I went to my bank, VISA, and brokerage accounts from Safari and was able to easily view and print my recent statements.  I did this only after spending countless hours downloading, deleting, re-downloading, and trying all the recommended fixes for Adobe problems.  Hope this works for you!
                                                • 21. Re: PROBLEMS opening  PDF in IE 9 or X
                                                  welshaddict Level 1
                                                  Yes it's definitely IE 9 not Adobe and like you spent hours trying to
                                                  sort it. I found out, that it was  problem with IE9 and not my
                                                  computer, via Amazon. I was trying to print gift vouchers and couldn't.
                                                  They were aware of this problem and recommended using Firefox as my
                                                  browser. This works fine with Adobe so every time I need to download an
                                                  Adobe file I switch my web browser.
                                                  • 22. Re: PROBLEMS opening  PDF in IE 9 or X
                                                    TapperAronson Level 1
                                                    I wonder how many hours of time have been spent trying to figure out this problem – probably millions!
                                                    • 23. Re: PROBLEMS opening  PDF in IE 9 or X
                                                      Shri2012
                                                      I had the same problem with IE 9. I have both Acrobat 7.0 Professional  and Adobe Reader X (10.1.2) installed on my machine (Windows 7, 64-bit).
                                                      I opened the reader and in Edit -> Preferences -> General section , I clicked on the  button "Set Default PDF Handler" and selected "Adobe Reader X (10.1.2)"  and  clicked "OK". It installed something and prompted me to restart the machine. After restart it worked fine. I can now open PDF documents in IE without any problem.
                                                      • 24. Re: PROBLEMS opening  PDF in IE 9 or X
                                                        CollectionsUncovered
                                                        Thanks for the help. I've been struggling with this problem for ages. I opened Adobe Reader X and used this procedure. Initially I was disappointed because the 'default pdf handler' was already set to Adobe Reader X (10.1.2). I re-selected 'Adobe Reader X (10.1.2)' and after the automatic install and restart the problem is solved. Thanks again.
                                                        • 25. Re: PROBLEMS opening  PDF in IE 9 or X
                                                          ukdeejay Level 1
                                                          12 months on... & still IE9 & Adobe Reader 'X' are 'not compatible'! - The simplest 'workaround' - which has already been put forward on this Discussion/Thread - is to try a different browser. I only learned of this compatibility issue after emailing my energy supplier to say I could not open PDF versions of my bills from their website! Why this issue has been kept a 'secret', by Adobe & Microsoft, for so long is anybody's guess?
                                                          • 26. Re: PROBLEMS opening  PDF in IE 9 or X
                                                            Flying_Kiwi Level 1
                                                            Alas this seems to be an indication of the lack of interest Adobe has towards users of Microsoft software. They eventually addressed the problem I reported earlier with 125% desktop settings under IE9 but still the maximum 150% setting causes problems (toolbar buttons don't work at all and Reader X is unusable within IE9). Why they didn't simply address both at the same time, I'll never know. With the official release of IE 10 (and Windows 8) just around the corner (and available already in pre-release form), I certainly hope Adobe are carefully testing for such issues with future OS's. It's a very dissapointing perfomance by Adobe so far as far as I'm concerned.
                                                            • 27. Re: PROBLEMS opening  PDF in IE 9 or X
                                                              ty22g
                                                              Hi Jim_Tsi
                                                              I was having the same problem and went on these forms to get help. I found out that Adobe X is not compatible with IE9. So to fix the problem. I just uninstalled IE9 and went back to IE8, I also uninstalled Adobe X and went back to Adobe 9. My problem is now fixed. Which reminds me of an old saying my dad use to say to me all the time. "IF IT AIN'T BROKE, DON'T FIX IT."
                                                              I hope this helps you out Jim or anyone else who is experiencing the same problem.
                                                              • 28. Re: PROBLEMS opening  PDF in IE 9 or X
        Nikhil.Gupta Adobe Employee
        Hi All,
        Please try using adobe Reader in 32-bit mode.
        Just to be sure that the problem is with Adobe Reader, please try to open this link and see if it works:
        http://helpx.adobe.com/content/dam/help/attachments/Acrobat_Reader_ReleaseNote_10.1.3.pdf
        Also please use updated version of Adobe Reader i.e. 10.1.3
        • 29. Re: PROBLEMS opening  PDF in IE 9 or X
        Flying_Kiwi Level 1
        Thanks for that suggestion but my system is ALL 32 bit and 2 days ago I performed a totally fresh installation from the ground up and using the FTP version of the full 10.1.3. Alas, I'm still getting the toolbar being totally unresponsive in ARX while my system is set to 150% (as desribed above) although (in my case) the pdf you linked to will open - I just can't do anything with it that I'd need the toolbars for!
        Do you have any idea when this problem is likely to be addressed please? It's been a problem for a very long time now.
        • 30. Re: PROBLEMS opening  PDF in IE 9 or X
        Hi Flying_Kiwi,
        Can you please try to open a pdf in Adobe Reader while the system is set to 100%?
        • 31. Re: PROBLEMS opening  PDF in IE 9 or X
        Flying_Kiwi Level 1
        As may be inferred from my posts in this thread nos 9 and 27, 100% is fine and 125% is (now) fine (the latter having been fixed a few months ago). Unfortunately neither of these settings result in decent sized icons and graphics on my screen so 150% is a must. I have reported it to your UK HQ (they're just a couple of miles from where I live so I took in a letter with some printed screenshots). If you need further info though, don't hesitate to ask and I'll be glad to tell you more.... anything to help get this problem finally fixed!
        • 32. Re: PROBLEMS opening  PDF in IE 9 or X
        Hi Flying_Kiwi,
        Sorry for all the inconvenience caused.
        This is a known issue and we are working on it at our end.
        Nikhil
        • 33. Re: PROBLEMS opening  PDF in IE 9 or X
        mikazraeesha
        I am not sure if what I am encountering is related with the plugin for IE9.  I installed a Document management software.  It can be accessed through IE only for the client.  When I try to open a PDF file, it will always display the first one that I opened.
        • 34. Re: PROBLEMS opening  PDF in IE 9 or X
        SEBryant
        I too have a problem with IE9 opening pdf files. IE9 stops working and I'm not given the option to save the file. This is a very serious issue for some of us (as we transact business and send/receive many documents as pdf).  What are your customers supposed to do until this issue is resolved?
        • 35. Re: PROBLEMS opening  PDF in IE 9 or X
        SEBryant Level 1
        I had to install Google Chrome to read & save pdf files.
        • 36. Re: PROBLEMS opening  PDF in IE 9 or X
        dawnjamin Level 1
        Google Chrome is the answer.  I actually use it all the time now, in my opinion it's much better than IE.
        • 37. Re: PROBLEMS opening  PDF in IE 9 or X
        welshaddict Level 1
        Hi lion rock,
        The problem with not being able to save your credit card statements could be your credit card company not Adobe. I use MBNA and whilst you can load a PDF statement and print it you can't save it. I spoke to them re this and it's the way they've set it up and not the fault of Adobe. Hence I reverted back to paper statements as the idea of going paperless was to be paperless.
        Hope this helps
        • 38. Re: PROBLEMS opening  PDF in IE 9 or X
        Lion Rock Level 1
        Thanks welshaddict,
        I reverted to paper statements too after trying to get my credit card company (Amex) to change the way they load their pdf statements without any success or even response.  However I then found a solution that worked for me - see post No.16.
        I hope Adobe have this problem sorted for IE10.
        • 39. Re: PROBLEMS opening  PDF in IE 9 or X
        jayroz52
        Knowing these are ancient posts- I still wonder if everyone is having a problem on  windows 7 machine ( ie9 + reader )...jayroz
        1 2 Previous Next
