Hi All,
First let me start by saying that I know next to nothing about Flash. I have inherited a website maintenance project that has a Flash rotating image banner. I have managed to get the images to fade-in and fade-out correctly, but now I need to make these images clickable - linking images to pages in the website. I have read many posts here and have reviewed the video tutorials. I have been able to get the first image clickable using this AS3 action:
mars_btn.addEventListener(MouseEvent.CLICK, buttonClickHandler);
function buttonClickHandler(event:MouseEvent) :void {
navigateToURL(new URLRequest("http://somewebsite/mars.php"));
trace("I'm clicked");
However, when I attempt to make another image clickable by using a different instance of a button I get the error message:
1021: Duplicate function definition.
I have a separate instance of a button with this AS3 action:
jupiter_btn.addEventListener(MouseEvent.CLICK, buttonClickHandler);
navigateToURL(new URLRequest("http://somewebsite/jupiter.php"));
Obviously I'm not understanding how I'm supposed to do this so that I don't create a duplicate function definition. Any help would be most appreciated.
if you know nothing about AS then the simplest way would just rename the handler methods to unique names
mars_btn.addEventListener(MouseEvent.CLICK, marsClickHandler);
function marsClickHandler(event:MouseEvent) :void {
jupiter_btn.addEventListener(MouseEvent.CLICK, jupiterClickHandler);
function jupiterClickHandler(event:MouseEvent) :void {
Wow, thanks for the quick help! It works great now. Many thanks.
excuse me , I have a question i hope that you help .. ( im new in here )
we were asked to create an interactive application on flash in two languages..
so i created two different fla files same exact codings ... i was wondering how can i combine them so the viewer can be able to choose the language from a button ?
when i try to combine them i get lots of errors of duplications in the actionscript
PS : MY MAIN PAGE INCLUDES A CAROUSEL with images ..
I was thinking of saving one of the fla as a movie and then add it some how to the second fla and combine it with a button but i can't figure it how..
i hope i was clear enough.. but is there any possibility to help me please ?!
when i tend to change names or something it creates error.. ( IM NOT A PRO IN AS3 ) and when i dublicate the scenes it give duplication errors.. WHAT IS THE SOLUTION ??
this is the code of the actionscript in the main page.. ( the carousel's code i took from someone ) and i used it on my project
import com.ccanvas.carousel.*;
var centerX:Number = stage.stageWidth/4;
var centerY:Number = stage.stageHeight/4;
var carc:Carousel = new Carousel(centerX, centerY, 256, 75, "icons.xml");
carc.addTooltip(new tooltip); // use 'tooltip' movieclip for item tooltip
addChild(carc); // add carousel to stage
function down(event:MouseEvent):void {
trace(event.currentTarget.toolText); // simple click interaction
function destroyCarousel(event:MouseEvent):void {
carc.destroy(); // remove all item in carousel as well as tooltip
function removeNextItem(event:MouseEvent):void {
if(carc.numOfItems > 2) {
carc.removeItem(2); // remove the item next to the remove item icon
create.addEventListener("mouseDown", createCarousel);
function createCarousel(event:MouseEvent):void {
if(carc.CREATED == false) {
// recreate the carousel
carc = new Carousel(centerX, centerY, 256, 75, "icons.xml");
addChild(carc);
}/* Click to Go to Scene and Play
Clicking on the specified symbol instance plays the movie from the specified scene and frame.
Instructions:
1. Replace "Scene 3" with the name of the scene you would like play.
2. Replace 1 with the frame number you would like the movie to play from in the specified scene.
Tools_button.addEventListener(MouseEvent.CLICK, fl_ClickToGoToScene);
function fl_ClickToGoToScene(event:MouseEvent):void
MovieClip(this.root).gotoAndPlay(1, "Toolse");
Instructions:
games_button.addEventListener(MouseEvent.CLICK, fl_ClickToGoToGames);
function fl_ClickToGoToGames(event:MouseEvent):void
MovieClip(this.root).gotoAndPlay(1, "Gamese");
Instructions:
Identity_button.addEventListener(MouseEvent.CLICK, fl_ClickToGoToIdentity);
function fl_ClickToGoToIdentity(event:MouseEvent):void
MovieClip(this.root).gotoAndPlay(1, "Identitye");
Instructions:
Reviews_button.addEventListener(MouseEvent.CLICK, fl_ClickToGoToScene_13);
function fl_ClickToGoToScene_13(event:MouseEvent):void
MovieClip(this.root).gotoAndPlay(1, "Reviewse");
Instructions:
Facts_button.addEventListener(MouseEvent.CLICK, fl_ClickToGoToScene_20);
function fl_ClickToGoToScene_20(event:MouseEvent):void
MovieClip(this.root).gotoAndPlay(1, "Factse");
