12 Replies Latest reply: Jan 19, 2012 12:17 AM by Eric Helier RSS
    llvm(?) error while compiling to swc
    bonext
      I'm trying to build a project using OpenCV with alchemy (that's a tough topic, I know). My idea was to isolate the parts I need from OpenCV (v.2.2), comile them with alchemy g++ and link with my code statically. So here's what I do:
      I have several parts of openCV 2.2 (core, imgproc) built file by file with the following string:
      alc-on; for src in *.cpp ; do g++ -I../../include -DOSX -c -Wall -O3 -o ${PWD##*/}_`basename $src .cpp`.o $src ; done ; mv -v *.o ~/dev/cut/obj/
      (Basically, I compile all the needed parts file-by-file and copy the resulting .o's into a specific folder)
      After that, I take a simple OpenCV test file with the following contents:
      #include <opencv/cv.h>
      #include "AS3.h"
      void testCV()
        cv::Mat a(3,3,CV_8UC1,cv::Scalar(1.0));
        cv::Mat b(3,3,CV_8UC1,cv::Scalar(2.0));
        cv::Mat c;
        c=a+b;
      static AS3_Val test(void* self, AS3_Val args)
        testCV();
        return 0;
      int main()
        AS3_Val testMethod = AS3_Function(NULL,test);
        AS3_Val result = AS3_Object("test: AS3ValType",testMethod);
        AS3_Release(testMethod);
        AS3_LibInit(result);
        return 0;
      And when I try to link it against all the *.o I have (assuming they are in the same folder):
      g++ -I../include -Wall -O3 -DOSX -swc test_cv.cpp *.o -o cvtest.swc
      I get the following error report:
      WARNING: While resolving call to function 'main' arguments were dropped!
      WARNING: While resolving call to function 'stub_null' arguments were dropped!
      WARNING: While resolving call to function 'stub_zero' arguments were dropped!
      Assertion failed: (TLI.isTypeLegal(VT) && "Intrinsic uses a non-legal type?"), function visitTargetIntrinsic, file /Volumes/data/dev/FlaCC/llvm-2.1/lib/CodeGen/SelectionDAG/SelectionDAGISel.cpp, line 2465.
      0   llc                                 0x00636dfe _ZNSt8_Rb_treeIN4llvm3sys4PathES2_St9_IdentityIS2_ESt4lessIS2_ESaIS2_EE13insert_uniqueERKS2_ + 6078
      1   llc                                 0x006373a2 _ZNSt8_Rb_treeIN4llvm3sys4PathES2_St9_IdentityIS2_ESt4lessIS2_ESaIS2_EE13insert_uniqueERKS2_ + 7522
      2   libSystem.B.dylib                   0x9125e05b _sigtramp + 43
      3   ???                                 0xffffffff 0x0 + 4294967295
      4   libSystem.B.dylib                   0x912eb5a5 raise + 26
      5   libSystem.B.dylib                   0x913016e4 abort + 93
      6   libSystem.B.dylib                   0x912ee20f __assert_rtn + 252
      7   llc                                 0x003f3e2a _ZN4llvm11StoreSDNodeD1Ev + 90026
      8   llc                                 0x003f5256 _ZN4llvm11StoreSDNodeD1Ev + 95190
      9   llc                                 0x003f817c _ZN4llvm11StoreSDNodeD1Ev + 107260
      10  llc                                 0x0040bc68 _ZN4llvm11StoreSDNodeD1Ev + 187880
      11  llc                                 0x0040d3f2 _ZN4llvm11StoreSDNodeD1Ev + 193906
      12  llc                                 0x0040f92e _ZN4llvm11StoreSDNodeD1Ev + 203438
      13  llc                                 0x005d1926 _ZN4llvm12FunctionPassD1Ev + 20998
      14  llc                                 0x005d1f3a _ZN4llvm12FunctionPassD1Ev + 22554
      15  llc                                 0x005d20c5 _ZN4llvm12FunctionPassD1Ev + 22949
      16  llc                                 0x00002e44 0x0 + 11844
      17  llc                                 0x00001f36 0x0 + 7990
      18  ???                                 0x00000006 0x0 + 6
      Can anybody explain what is it all about and where should I look to fix it somehow?
        • 1. Re: llvm(?) error while compiling to swc
          bonext Community Member
          Ok, I've got some more info on the topic. The problem seems to come from matop.cpp from opencv2.2 core module. Currently I tried to exclude it from linking list and now I'm getting the following message while further linking:
          Couldn't allocate output reg for contraint '{ax}'!
          What is it about?
          • 2. Re: llvm(?) error while compiling to swc
            One more exclude (system.cpp from core module) and all I get is an undefined sym for lrint at runtime
            • 4. Re: llvm(?) error while compiling to swc
              excluding matop.cpp is not a good idea, cause it has some necessary functions (thus runtime undef sym errors). Need to fix something inside matop
              • 5. Re: llvm(?) error while compiling to swc
                Dirty hack:
                remove all between
                #if SSE_2
                #else
                and leave only the else-section in opencv/core/arithm.cpp
                This will allow you to compile the example...
                Just in case I point out that we have basic OpenCV stuff working in alchemy...
                • 6. Re: llvm(?) error while compiling to swc
                  Eric Helier Community Member
                  Did you finally succeed ?
                  I'm trying to compile from your github repository on cygwin (windows).
                  I achieved to compile each C++ and C sources from opencv / zlib / lapack (without DOSX option)
                  Now i'm stuck at compiling the C++ wrapper from the flash folder as it seems the llvm fails resulting in a llvm-ld.stackdump file
                  I tried with and without core_system.o as stated in readme with same result.
                  I don't see any "SSE_2" in core/arithm.cpp but a grep command shows there are lots of "CV_SSE2" in mathfuncs.cpp
                  • 7. Re: llvm(?) error while compiling to swc
                    I'm sorry, but the project has been (temporarily?) suspended, so no work has been done since my last commit (However, someone forked it).
                    I didn't manage to set up the toolchain for cygwin either.
                    I suggest you try compiling C++ sources one by one to determine which one actually causes the compiler fail and then look into it, or look at the log file I create in build commands, that could clear things a bit.
                    The reason for removing SSE_2 was simply to get rid of assembly code. I'm pretty sure you will have to remove any of it you come across in order to alchemy-compile OpenCV, so don't hesitate to remove that stuff if compiling fails in files with assembly insertions.
                    • 8. Re: llvm(?) error while compiling to swc
                      OK thank you for your answer.
                      I'll try to investigate further, following your advices, or maybe ask for some help of C/C++ coders coworkers...
                      If i succeed in any way, i'll try to document the process.
                      • 9. Re: llvm(?) error while compiling to swc
                        I got some success at this time : achieved to compile and run the AS3 Sample from your repository (converting webcam frames to grayscale)
                        I used ar to find where the llvm problem come from and found that the lapack/slas*.cpp are in cause.
                        Simply excluding all theses + core/system.cpp from compilation it works
                        I also used ar llvm archiver to compile first an archive library from all .o files
                        Right now i'm trying to setup a simple face detection test...
                        • 10. Re: llvm(?) error while compiling to swc
                          That's pretty cool, I was also aiming at face detection at the time I started porting.
                          It would be great if you made a kind of example on face detection if it works out, so it would be possible to extend the repository with it along with your observations and instructions.
                          • 11. Re: llvm(?) error while compiling to swc
                            Hello,
                            About FaceDetection, at this time, i'm stuck at loading HaarCascades xml files. A coworker gave me his working version, but he works with opencv2.0, so it doesn't seem correct. And the supplyFile method of alchemy doesn't seem to work with HaarCascade.load from opencv...
                            I spend some time testing image processing methods, like medianblur, flip, etc. (didn't achieve to make work methods like GaussianBlur that needs some "border data" (?) on the source image.
                            I found that in the sample code on your repo, width and height of the frame (corresponding to rows and cols in opencv) where inverted, and that the color space of Flash frame is actually ARGB, and not RGBA.
                            I also tried not to pass the ByteArray from flash to C and C to flash, but using returned pointer to read/write directly to memory. But that didn't change a lot about performances. MedianBlur on 640x480 gives me a 3fps rate. I will try to compare with native execution performances.
                            • 12. Re: llvm(?) error while compiling to swc
                              Actionscript and alchemy require additional workarounds for file operations, and it could happen that you would need to make a wrapper for openCV loader functions, like here: http://blog.debit.nl/2009/03/using-bytearrays-in-actionscript-and-alchemy/#more-79
                              • 13. Re: llvm(?) error while compiling to swc
                                Yes it seems it is not as simple as using supplyFile...
                                I tried with a static cpp version of haarcascade xml that a coworker gave me, but they work with opencv2.0. So at this time i started back compiling opencv2.0...
                                ./configure didn"t work because of the "adl stuck" bug so i took the same way as yours with opencv2.2, compiling every .cpp to .*and so on.
                                I know have a working opencv2.0.swc... let's hope i achieve to make a basic facedetection working sample today...
                                For the medianblur comparison with native c application here are my results : (sigh)
                                - Alchemy OpenCV (lapack) : ~400ms
                                - C OpenCV (IPP) : ~10ms
                                I begin to think that it won't be possible to get realtime tracking simply porting opencv with alchemy...
