1
Unlock all objects in document(s)?
Aug 31, 2011 Aug 31, 2011
I suspect the answer is no, but is there a way to do this? I've got 60 files originally made by rhesus monkeys and they found the "lock" command.
Thanks.
27.8K
Advisor , Aug 31, 2011 Aug 31, 2011
Ariel,
There is no need to loop through allPageItems. It's just slow and pointless.
allPageItems returns all items no matter if they are grouped or not.
If you noticed, you can't lock object which is inside of group.
Therefore, using simple one line of code you can unlock all
items in the document like Jongware did in his post:
app.activeDocument.pageItems.everyItem().locked = false;
To unlock items just on master pages use this:
app.activeDocument.masterSpreads.everyItem().pageItems.everyItem().locked
I have a hunch that it could be scripted. One of our scripting gurus may answer whether it's possible.
user Harbs has answered this question in an earlier thread:
http://forums.adobe.com/message/2988802
EDIT: or Jongware's answer in this earlier thread:
http://forums.adobe.com/message/3725137
admittedly, searching on the forum's indesign scripting site sucks. user John Hawkinson suggested a better way of searching it. to quote him directly:
Use google instead, you can specify site:forums.adobe.com +"indesign scripting"
If the answer wasn't in my post, perhaps it might be on my blog at colecandoo!
Lovely, thanks.
At least they weren't marmosets, or everything would be on a non-printing layer, too.
While in InDesign, click on 'Object' from the Menu options and select 'Unlock All on Spread'. See if it helps.
Rachit
Thanks, but there are 1,013 spreads, so I'd like to avoid that.
Got the script running. So far, so good.
Thanks, all.
People's Champ ,
Untested, but try this little script:
items = app.activeDocument.allPageItems;
for (a=0; a<items.length; a++){
items.locked = false;
Ariel
or the OP should try ariel's script above... just tested in CS5 (mac) and it works there.
The simple one works in CS5.5; will try the other if anything changes.
Thanks again.
Advisor ,
Ariel,
app.activeDocument.masterSpreads.everyItem().pageItems.everyItem().locked = false;
To unlock all items just on pages, not master pages:
app.activeDocument.pages.everyItem().pageItems.everyItem().locked = false;
Hope that helps.
Marijan (tomaxxi)
http://tomaxxi.com
People's Champ ,
Sep 01, 2011 Sep 01, 2011
Hi Marijan,
Thanks that's good. I thought of allPageItems.everyItem() but then I saw
that it returned an array, not a collection, so it didn't work. At the
back of my mind I remembered that there was an object that would work
with everyItem() but I couldn't remember offhand what it was.
Ariel
Oct 13, 2023 Oct 13, 2023
It works great!
Can you add pages range to these code lines? So that you can unlock only specific pages in the document, e.g. from 12-50?
PS My problem is "find and replace" on specific pages, the only solution is to block the entire document and unlock the pages on which I want to make changes.
You didn't say what version of InDesign?
InDesign CS5 you can open the Layers panel, here there is a triangle to expand the layer.
And you can unlock all items by clicking and holding and sliding down the side with the locks on it.
Or use the Sub menu and choose "unlock all"
Dec 03, 2020 Dec 03, 2020
You can also try this script which is now apparently only accessible via the WayBackMachine.
https://web.archive.org/web/20151016221507/http://www.premediasystems.com:80/downloads/Lock_Unlock_P...
It worked great for me in Insdesign CC2021 to unlock every element in a 280-page document.
Hi erique,
Marijan (tomaxxi) gave the correct answer back in 2011.
His ExtendScript (JavaScript) code is still working.
Even with the lastest version of InDesign 2021.
Perhaps one could add another line of code that also unlocks all layers of the active document:
app.activeDocument.layers.everyItem().locked = false ;
FWIW: An expanded version could also memorize all locked objects so that a user will be able to lock all items that were unlocked later.
Uwe Laubender
( ACP )
Aug 23, 2022 Aug 23, 2022
Hello guys,
can you please let me know how to run this scritp ?
Hi @Amr.Hamdy ,
copy the code to a text editor and save it without any formatting with the file suffix *.jsx for ExtendScript.
How to install a script file in your User folder so that the script is showing up in the Scripts panel:
https://helpx.adobe.com/indesign/using/scripting.html
Also this:
https://creativepro.com/files/kahrel/indesign/script-info.html
And that:
https://www.indiscripts.com/pages/help#hd0sb2
Uwe Laubender
( Adobe Community Professional )
Jun 02, 2023 Jun 02, 2023
@Laubender Thanks man,
