Quickly after starting the installation procedure, the installer says the installation is cancelled and gives me the following error report:
Exit Code: 24
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 16 error(s), 2 warning(s)
WARNING: DS013: Payload {ED679BB6-B428-4DCF-A52F-F9AAAA117101} Flash Player 10.0.45.2 is already installed and the session payload {09E9550D-7D89-4B9D-B6BB-72AF22CA9D3B} Flash Player 10.2.153.1 has no upgrade/conflict relationship with it.
WARNING: DS013: Payload {298CF0B0-8B47-46DF-B726-8E4BFAD5432E} AdobeHelp 1.0.0.0 is already installed and the session payload {B86DCC32-8B28-4788-8A09-6D1C9F7EAAAD} AdobeHelp 3.4.0.0 has no upgrade/conflict relationship with it.
ERROR: DS013: Verifying payload integrity : Failed with code 1
ERROR: DW001: Set payload cancelled status
ERROR: DW049: Payload {09E9550D-7D89-4B9D-B6BB-72AF22CA9D3B} has an action "install" but no resultState
ERROR: DW049: Payload {24516988-6529-480E-8FE3-8428704FCAAB} has an action "install" but no resultState
ERROR: DW049: Payload {2C79B880-4D30-4572-91C7-FB6B6003DEF9} has an action "install" but no resultState
ERROR: DW049: Payload {3FA63389-0091-497A-8522-998E43648AEF} has an action "install" but no resultState
ERROR: DW049: Payload {6F3A624B-1B72-4081-96E8-23261F389C5C} has an action "repair" but no resultState
ERROR: DW049: Payload {9947B700-1D03-48A8-9C89-415C5E38D74F} has an action "install" but no resultState
ERROR: DW049: Payload {9D0088AD-BBB1-470B-B7B8-520EDEFAE5F3} has an action "install" but no resultState
ERROR: DW049: Payload {A04E70DF-CF2C-45FE-AA69-3267F28849D8} has an action "install" but no resultState
ERROR: DW049: Payload {B86DCC32-8B28-4788-8A09-6D1C9F7EAAAD} has an action "install" but no resultState
ERROR: DW049: Payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} has an action "repair" but no resultState
ERROR: DW049: Payload {E0BCE1AA-B57D-4983-A05A-1B2CBF124494} has an action "install" but no resultState
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Suite Shared Configuration CS5: User cancelled installation
ERROR: DW001: User cancelled the operation
Uninstall adobe air, and adobehelp. You versions causes conflict with Master Collection CS5 versions
I found the solution...for me, anyway...
I have a new Mac Mini Server running Lion Server and Lion. I could not get CS5 to install and was getting the same "DW049" errors.
As a new(er) Mac user I am hesitant to start tinkering with my system drive, partitions, OS, etc...I saw a lot of forum responses all over the place discussing the migration of apps from a MacBook Pro, loading Snow Leopard on top of Lion, etc. etc.
I didn't do any of that.
I simply removed any old install files.
Updated Java for OS X Lion here: http://support.apple.com/kb/DL1421
Restarted
Worked fine. Java update came out in July, apparently.
HTH,
Dave
I tried this and it works perfectly! There was nothing o
n the Adobe KB?
