I have done the application with two type of authentication
First one is the presenter
Second one is the viewer
(both are connect to the same FMS application)
i want to notify the viewer when presenter log out or connection lost , how it's possible, please help me, thanks in advance
NetStatus event listener. Its in the AS3.0 live docs.
You'll need to keep track of the two clients on the server side, and invoke a client side method on the viewer client when the presenter disconnects. For example:
On the viewer, you'll have a method in the netconnection's client object:
onPresenterDisconnect = function(){
// Notify the client here
on the server side:
application.onDisconnect = function(client){
// Test to see if the disconnecting client is the presenter
if(client is the presenter){
// Loop through the client list to find the viewer or viewers
for(var i=0; i<application.clients.length; i++){
if(application.clients is a viewer){
application.clients.call("onPresenterDisconnect" null);
Obvoiously, the above is not complete code. You'll need to add your own logic to determine whether a given client is a presenter or a viewer.
oh yeah I was a little hasty on this one sorry. I would probably have an object on the server side that tracks all users and have an attribute that denotes presenter or subscriber. something like
//intialize in onAppStart
this.adminObj = new Object();
//get user data from connection string on client side
"rtmp://192.168.1.102/someApp/someInstance","userNameVariable"
//add username in onConnect to Object
client.userName=userName;
this.userObj[client.userName]=client;
//call this from client side depending on whether the user chooses to be presenter or subscriber.
Client.prototype.setStreamID = function(userName,streamType){
this.userObj[client.userName].streamID = streamType;
//find out onDisconnect what type the client is.
//application.onDisconnect = function(oldClient)
if(application.userObj[oldClient.userName].streamID=="presenter"){
//then either send or call the subscribers
//This is imperfect just an example of how I might go about it.........I've also have tracke FPS on the client side to see when the presenter stops presenting. to track frames per second though you need to continously poll the fps property of the netstream with either a timer or onEnter (onEnterFrame).
