Hello All
I want to invoke Certify method of Signatiure Service provided in adobe live cycle but i dont understad the parametres passed to it. can any one know the details of the parameters and it's use.
Solved! Go to Solution.
Total Likes
You can access the API documentation (JavaDocs) here... http://help.adobe.com/en_US/enterpriseplatform/10.0/programLC/javadoc/
From the "classes" section (upper left corner) select com.adobe.livecycle.signatures.client
Select SignatureServiceClient from the panel below the classes section.
Select the "certify" operation from the Method Summary pane, this will load a page with links to information on each of the parameters.
Hope this helps.
Steve
Total Likes
Basically, all of the parameters are documented in the Java Docs
Are there any specific ones that you have questions about?
Regards
Steve
Total Likes
Hi Steve
Thanks For your help.out of all parameters i understand the use of following parameters.
Document pdfdocument
String signatureFieldName
HashAlgorithm hashAlgorithm
String reason
String Location
String contactInfo
but i dont understand the use of remaining parameters and what values should i pass for these remaining parameters.
Credential credential
MDPPermissions mdpPermissions
String legalAttestaion
PdfSignationAppearanceOptionSpec appearanceOptionSpec
Boolean embedRevocationInfo
Boolean lockCertifyingField
OCSpOptionSpec ocspOptionSpec
CRLOptionSpec crlOptionSpec
TSPOptionSpec tspOptionSpec
it would be grate help if you could provide me any link or document where i can get the information about all the above listed parameters.
Regards
Rahul
Total Likes
Hope this helps.
Steve
Total Likes
