2 Replies Latest reply: Sep 7, 2011 5:29 AM by sobolevsky RSS
    Encore CS5 - missing chapters after Layer Break in DL DVD
    sobolevsky Community Member
      Hello.
      I have huge problem trying build project in Encore CS5.
      I have menu with 16 buttons(1 chapter to each button) and button Return
      Im using dynamic link to link Encore to Premiere sequence (all chapters are on one timeline in PrPro)
      I check the project - everything is as I want, build ISO DVD till 10th chapter is ok, from 11 to 16 is not. The plases of chapters are completely different, and my movie ends after chapter 15 :/ - my question is, where is the chapter 16? and why chapters are in different places ? How to Fix that ?
      The problem is only with Dual Layer DVD, Bly Ray disc and DVD 4.7GB is fine.
        • 1. Re: Encore CS5 - missing chapters after Layer Break in DL DVD
          shuchi shrivastava Community Member
          Are you using any chapter playlists? Are you using automatic or manual layer break?Can you paste a screen shot of your flowchart so that i can better understand the problem.
          There is an issue with Encore layer breaks so most probably this is what is causing the problem.In some cases Encore places an extra chapter on the timeline at the place where the layer break occurs.This causes subsequent chapters to be incremented by 1.So, I guess your problem is related to this behaviour only.
          • 2. Re: Encore CS5 - missing chapters after Layer Break in DL DVD
            thx for reply,
            no Im not usign a chapter playlist
            Im using automatic layer break, do You think it could be a cause of issue ?
            I'checked this and you're right !! Another chapter was added to my timeline in layer break place, so encore moved chapters after layer break., I've changed Layer Break to manually, and placed exactly on chapter 11 and now works !!!
            Thank You. issue solved.
