1. Re: Encore CS5 - missing chapters after Layer Break in DL DVD
shuchi shrivastava Sep 7, 2011 3:57 AM (in response to sobolevsky)Hi,
Are you using any chapter playlists? Are you using automatic or manual layer break?Can you paste a screen shot of your flowchart so that i can better understand the problem.
There is an issue with Encore layer breaks so most probably this is what is causing the problem.In some cases Encore places an extra chapter on the timeline at the place where the layer break occurs.This causes subsequent chapters to be incremented by 1.So, I guess your problem is related to this behaviour only.
2. Re: Encore CS5 - missing chapters after Layer Break in DL DVD
sobolevsky Sep 7, 2011 5:29 AM (in response to shuchi shrivastava)thx for reply,
no Im not usign a chapter playlist
Im using automatic layer break, do You think it could be a cause of issue ?
I'checked this and you're right !! Another chapter was added to my timeline in layer break place, so encore moved chapters after layer break., I've changed Layer Break to manually, and placed exactly on chapter 11 and now works !!!
Thank You. issue solved.
