14 Replies Latest reply on Sep 9, 2011 4:20 AM by Mark Southee
    ePub output - bulleted lists mangled RH9
    Mark Southee Level 2
      I was pleasantly surprised when doing an investigation in to outputting to ePub format, that everything seemed to be transformed quite nicely, even my tables, which according to what I read don't get handled too well by the ePub output.
      But (there's always a but!), as seems invevitable, bulleted lists don't work, with the bullet appearing in the text, as below.
      All lists in my project are affected. As this is a linked FrameMaker project which normally outputs to WebHelp, is there anything I can to to change this?
      Mark
        • 1. Re: ePub output - bulleted lists mangled RH9
          Willam van Weelden Adobe Community Professional & MVP
          My guess is that this is a css issue. Try the following:
          1. Make sure that your bulleted lists are converted to HTML lists on import/generation.
          2. Add the following line of code to your css files:
          ul { list-style-position: outside; }
          If this doesn't work, please post the HTML of one of those lists so I can take a look.
          Greet,
          Willam
          • 2. Re: ePub output - bulleted lists mangled RH9
            Hi Willam,
            Been on holiday and just caught up with this!
            My lists are converted to HTML lists.
            I added the linde to my css file, but no change.
            Below is HTML from a file
            <body>
            <p class="Title">Getting Started</p>
            <p class="FM_Body">This section describes how to access ICM and describes
            the functionality and navigation around the system.</p>
            <ul type="disc">
            <li><p class="FM_Bulleted"><a href="System_Requirements.htm#XREF_98462_System_Requirements">System
            Requirements</a></p></li>
            <li><p class="FM_Bulleted"><a href="Log_in_to_ICM.htm#XREF_85581_Log_in_to_ICM">Log
            in to ICM</a></p></li>
            <li><p class="FM_Bulleted"><a href="Layouts.htm#XREF_77140_Layouts">Layouts</a></p></li>
            <li><p class="FM_Bulleted"><a href="Menus.htm#XREF_14919_Menus">Menus</a></p></li>
            <li><p class="FM_Bulleted"><a href="Create_a_Custom_Layout.htm#XREF_75406_Create_a_Custom">Create
            a Custom Layout</a></p></li>
            </ul>
            </body>
            Cheers
            Mark
            • 3. Re: ePub output - bulleted lists mangled RH9
              This is probably caused by a paragraph with a negative indent. The strange thing is that you should also experience the same problem with WebHelp.
              Check your CSS file and search for p.FM_Bulleted. Does this style have a negative indent such as margin-left: -20px?
              If you can't find the style, please post your css and I'll take a look.
              Greet,
              Willam
              • 4. Re: ePub output - bulleted lists mangled RH9
                Hi Willam,
                Here is the style:
                p.FM_Bulleted {
                font-family: Arial;
                margin-left: 18pt;
                list-style: rh-list;
                x-list-class: rl-p-FM_Bulleted;
                x-list-level: 1;
                No negative indent
                Mark
                • 5. Re: ePub output - bulleted lists mangled RH9
                  Hi Mark,
                  Can you share the project with me? I'd like to take a look and dig around a bit. You can contact met at contact [at] wvanweelden [dot] eu.
                  Greet,
                  Willam
                  • 6. Re: ePub output - bulleted lists mangled RH9
                    Peter Grainge Adobe Community Professional (Moderator)
                    Willam
                    Isn't the problem that the paragraph style is including definitions that should be in the list style?
                    @petergrainge
                    • 7. Re: ePub output - bulleted lists mangled RH9
                      Hi Willam,
                      Unfortunately, due to the NDA at the client, I can't send you the project.
                      I thought it strange that the list style refers to:
                      I have the conversion setting to HTML list (or am I misinterpreting the RH css)?
                      Mark
                      • 8. Re: ePub output - bulleted lists mangled RH9
                        @Peter: Perhaps, but not with the posted definition. ePub uses XHTML 1.1 which is even stricter than the XHTML 1.0 that WebHelp uses. So the problem should also be present in WebHelp... But it certainly is worth checking out.
                        @Mark:
                        - I haven't seen the list-style: rh-list before. It certainly isn't a valid css rule. But that may be because this css is used as a conversion template. How does the css look in the style sheet that is actually assigned to the topic? Are you sure you aren't converting to a RoboHelp Multilevel list?
                        -  Generate your XML layout and open the faulty topic in your browser. How does it look then? Is the HTML the same as in WebHelp?
                        -  Too bad you can't share the project. Can you perhaps only share the css file?
                        Greet,
                        Willam
                        • 9. Re: ePub output - bulleted lists mangled RH9
                          Mark
                          You should be able to create the same problem in a new project with just a couple of topics. Garbage content will do and enable Willam to help you.
                          This is some sample text. This is some sample text. This is some sample text. This is some sample text. This is some sample text. This is some sample text. This is some sample text. This is some sample text. This is some sample text. This is some sample text. This is some sample text. This is some sample text. This is some  sample text. This is some sample text. This is some sample text. This is  some sample text. This is some sample text. This is some sample text.  This is some sample text. This is some sample text. This is some sample text.
                          @petergrainge
                          • 10. Re: ePub output - bulleted lists mangled RH9
                            Here is my CSS file. I will put together a quick project in the next couple of days. BTW Peter, have you seen the Yorkshire version of Lorem Ipsum? http://tlipsum.appspot.com/
                            /*Created with Adobe RoboHelp 9.*/
                            p.BodyLevel1 {
                            margin-left: 18.000pt;
                            margin-right: 0.000pt;
                            text-align: left;
                            text-indent: 0.000pt;
                            margin-top: 8.000pt;
                            margin-bottom: 0.000pt;
                            word-spacing: 0.250em;
                            font-family: Arial;
                            font-style: normal;
                            font-weight: normal;
                            font-size: 11.0pt;
                            color: #000000;
                            letter-spacing: 0.00em;
                            text-decoration: none;
                            p.BodyLevel2 {
                            margin-left: 36.000pt;
                            text-align: left;
                            font-family: Arial;
                            font-style: normal;
                            font-size: 11.0pt;
                            color: #000000;
                            p.BodyLevel3 {
                            margin-left: 54.000pt;
                            text-align: left;
                            font-family: Arial;
                            font-style: normal;
                            font-size: 11.0pt;
                            color: #000000;
                            h1 {
                            margin-left: 0.000pt;
                            text-align: left;
                            margin-top: 17.000pt;
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 14.0pt;
                            color: #000000;
                            h2 {
                            margin-right: 36.000pt;
                            text-align: left;
                            margin-top: 16.000pt;
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 13.0pt;
                            color: #000000;
                            h3 {
                            text-align: left;
                            margin-top: 14.000pt;
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 12.0pt;
                            color: #000000;
                            h4 {
                            text-align: left;
                            margin-top: 13.000pt;
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 11.0pt;
                            color: #000000;
                            p.Title {
                            text-align: left;
                            margin-top: 22.000pt;
                            margin-bottom: 11.000pt;
                            font-family: Arial;
                            font-style: normal;
                            font-size: 24pt;
                            color: #f7961e;
                            font-weight: bold;
                            p.AuthorBook {
                            text-align: left;
                            margin-top: 0.000pt;
                            margin-bottom: 292.000pt;
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 13.0pt;
                            color: #000000;
                            p.CellBody {
                            text-align: left;
                            margin-bottom: 4.000pt;
                            font-family: Arial;
                            font-style: normal;
                            font-size: 9.0pt;
                            color: #000000;
                            p.CellHeading {
                            text-align: left;
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 9.0pt;
                            color: #ffffff;
                            p.Extract {
                            margin-right: 18.000pt;
                            text-align: left;
                            margin-top: 7.000pt;
                            font-family: Arial;
                            font-style: normal;
                            font-size: 9.0pt;
                            color: #000000;
                            p.Footnote {
                            margin-left: 12.000pt;
                            text-align: left;
                            text-indent: -12.000pt;
                            margin-top: 3.000pt;
                            font-family: Arial;
                            font-style: normal;
                            font-size: 9.0pt;
                            color: #000000;
                            p.PublisherBook {
                            text-align: left;
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 12.0pt;
                            color: #000000;
                            p.TitleBook {
                            text-align: left;
                            margin-bottom: 60.000pt;
                            font-family: Arial;
                            font-style: italic;
                            font-size: 30.0pt;
                            color: #000000;
                            letter-spacing: -0.04em;
                            H5 {
                            font-weight: bold;
                            font-size: 10.0pt;
                            x-next-type: P;
                            font-family: Arial;
                            H6 {
                            font-weight: bold;
                            font-size: 8.0pt;
                            x-next-type: P;
                            font-family: Arial;
                            span.PageNumber {
                            font-weight: bold;
                            span.EquationVariables {
                            font-style: italic;
                            span.Emphasis {
                            font-style: italic;
                            span.Callout {
                            font-family: Arial;
                            font-style: normal;
                            font-size: 8.0pt;
                            color: #000000;
                            span.BulletSymbol {
                            font-family: Courier;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 11.0pt;
                            color: #000000;
                            span.FirstLetterTitle {
                            font-family: Arial;
                            font-style: italic;
                            font-size: 42.0pt;
                            color: #000000;
                            span.EquationNumber {
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 8.0pt;
                            color: #000000;
                            span.ChapterNumber {
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 10.0pt;
                            color: #000000;
                            letter-spacing: 0.04em;
                            span.StepNumber {
                            font-family: Arial;
                            font-style: normal;
                            font-weight: bold;
                            font-size: 8.0pt;
                            color: #000000;
                            span.WebJump {
                            span.Superscript {
                            font-family: Arial;
                            font-style: normal;
                            color: #000000;
                            span.Underline {
                            font-style: normal;
                            color: #000000;
                            span.Bold {
                            font-style: normal;
                            font-weight: bold;
                            color: #000000;
                            span.BlueBold {
                            font-weight: bold;
                            color: #2e97dc;
                            span.White {
                            color: #ffffff;
                            span.Symbol {
                            font-family: Symbol;
                            font-style: normal;
                            font-size: 10.0pt;
                            color: #000000;
                            span.GreyBold {
                            font-family: Arial;
                            font-weight: bold;
                            color: #3f3f3f;
                            span.Subscript {
                            font-family: Arial;
                            font-style: normal;
                            color: #000000;
                            table.CellBorder {
                            padding: 0px;
                            border-top: Solid 1px #000000;
                            border-left: Solid 1px #000000;
                            x-border-spacing: 0px;
                            table.CellBorder td {
                            border-right: Solid 1px #000000;
                            border-bottom: Solid 1px #000000;
                            table.Colorful1 {
                            padding: 0px;
                            border-left-style: Solid;
                            border-left-width: 1px;
                            border-left-color: #000000;
                            border-top-style: Solid;
                            border-top-width: 1px;
                            border-top-color: #000000;
                            x-1st-row: 1;
                            x-1st-row-name: row1;
                            x-1st-col: 1;
                            x-1st-col-name: col1;
                            table.Colorful1 tr.row1 td {
                            background-color: #800000;
                            padding-right: 10px;
                            padding-left: 10px;
                            font-weight: bold;
                            border-right-style: Solid;
                            border-right-width: 1px;
                            border-right-color: #000000;
                            border-bottom-style: Solid;
                            border-bottom-width: 1px;
                            border-bottom-color: #000000;
                            color: #ffffff;
                            table.Colorful1 td.col1 {
                            background-color: #c0c0c0;
                            padding-left: 10px;
                            font-weight: bold;
                            table.Colorful1 td {
                            padding-left: 10px;
                            table.Colorful2 {
                            padding: 0px;
                            x-1st-row: 1;
                            x-1st-col: 1;
                            table.Colorful2 tr.row1 td {
                            background-color: #000080;
                            padding-left: 10px;
                            font-weight: bold;
                            color: #ffffff;
                            table.Colorful2 td.col1 {
                            background-color: #0000ff;
                            font-weight: bold;
                            padding-left: 10px;
                            color: #ffffff;
                            table.Colorful2 td {
                            padding-left: 10px;
                            table.Colorful3 {
                            padding: 0px;
                            border-left-color: #ffffff;
                            border-top-color: #ffffff;
                            x-1st-row: 1;
                            table.Colorful3 tr.row1 td {
                            padding-left: 10px;
                            font-weight: bold;
                            color: #ffffff;
                            table.Colorful3 td {
                            border-right-color: #ffffff;
                            border-bottom-color: #ffffff;
                            padding-left: 10px;
                            table.Colorful4 {
                            padding: 0px;
                            x-1st-row: 1;
                            x-1st-col: 1;
                            table.Colorful4 tr.row1 td {
                            background-color: #008000;
                            padding-left: 10px;
                            font-weight: bold;
                            color: #ffffff;
                            table.Colorful4 td.col1 {
                            background-color: #ffff00;
                            font-weight: bold;
                            padding-left: 10px;
                            table.Colorful4 td {
                            padding-left: 10px;
                            table.LastColumn {
                            x-row-pat-1: 1;
                            x-row-pat-1-name: t1Row;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            x-row-pat-2-name: t2Row;
                            x-last-col: 1;
                            x-last-col-name: last;
                            text-align: Right;
                            font-size: 10pt;
                            table.LastColumn tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LastColumn tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LastColumn td.last {
                            font-family: Arial;
                            text-align: Right;
                            font-size: 10pt;
                            table.lastcolumn tr.t1row td.last {
                            font-family: Arial;
                            text-align: Right;
                            font-size: 10pt;
                            table.lastcolumn tr.t2row td.last {
                            font-family: Arial;
                            text-align: Right;
                            font-size: 10pt;
                            table.LastRow {
                            padding: 0px;
                            x-last-row: 1;
                            x-last-row-name: last;
                            text-align: Right;
                            font-family: Arial;
                            font-size: 10pt;
                            table.LastRow td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LastRow tr.last td {
                            text-align: Right;
                            font-family: Arial;
                            font-size: 10pt;
                            table.BottomRowRightColumn {
                            padding: 0px;
                            x-last-row: 1;
                            text-align: Right;
                            font-family: Arial;
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            x-last-col: 1;
                            table.BottomRowRightColumn td {
                            table.BottomRowRightColumn tr.last td {
                            text-align: Right;
                            font-family: Arial;
                            font-size: 10pt;
                            table.BottomRowRightColumn tr.t1Row td {
                            text-align: Right;
                            font-family: Arial;
                            font-size: 10pt;
                            table.BottomRowRightColumn tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.BottomRowRightColumn td.last {
                            text-align: Right;
                            font-family: Arial;
                            font-size: 10pt;
                            table.BottomRowRightColumn tr.t1row td.last {
                            text-align: Right;
                            font-family: Arial;
                            font-size: 10pt;
                            table.BottomRowRightColumn tr.t2row td.last {
                            text-align: Right;
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumn {
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            x-1st-col: 1;
                            x-1st-col-name: t1st;
                            table.LeftColumn tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumn tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumn td.t1st {
                            background-color: #cccccc;
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.leftcolumn tr.t1row td.t1st {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.leftcolumn tr.t2row td.t1st {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.LeftColumnAlternatingColumns {
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            x-1st-col: 1;
                            x-col-pat-1: 1;
                            x-col-pat-1-name: t1Col;
                            x-col-pat-count: 2;
                            x-col-pat-2: 1;
                            x-col-pat-2-name: t2Col;
                            table.LeftColumnAlternatingColumns tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumnAlternatingColumns tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumnAlternatingColumns td.t1st {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.leftcolumnalternatingcolumns tr.t1row td.t1st {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.leftcolumnalternatingcolumns tr.t2row td.t1st {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.LeftColumnAlternatingColumns td.t1Col {
                            background-color: #ccffcc;
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumnAlternatingColumns td.t2Col {
                            table.LeftColumnRepeatingColumns {
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            x-1st-col: 1;
                            x-col-pat-1: 1;
                            x-col-pat-2: 1;
                            x-col-pat-count: 3;
                            x-col-pat-3: 1;
                            x-col-pat-3-name: t3Col;
                            table.LeftColumnRepeatingColumns tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumnRepeatingColumns tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumnRepeatingColumns td.t1st {
                            background-color: #808080;
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.leftcolumnrepeatingcolumns tr.t1row td.t1st {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.leftcolumnrepeatingcolumns tr.t2row td.t1st {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.LeftColumnRepeatingColumns td.t1Col {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumnRepeatingColumns td.t2Col {
                            font-family: Arial;
                            font-size: 10pt;
                            table.LeftColumnRepeatingColumns td.t3Col {
                            font-family: Arial;
                            font-size: 10pt;
                            table.Line1 {
                            padding: 0px;
                            border-bottom-width: 3px;
                            border-bottom-color: #008000;
                            border-top-width: 3px;
                            border-top-color: #008000;
                            x-1st-row: 1;
                            table.Line1 tr.row1 td {
                            table.PaddedCells {
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            x-border-spacing: 2px;
                            table.PaddedCells tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.PaddedCells tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.PaddedCells td {
                            padding-left: 5px;
                            padding-right: 5px;
                            padding-top: 5px;
                            padding-bottom: 5px;
                            table.Retro7 {
                            x-border-spacing: 15px;
                            x-row-pat-count: 1;
                            x-row-pat-1: 1;
                            table.Retro7 tr.t1Row td {
                            border-top-style: Groove;
                            border-bottom-style: Groove;
                            border-top-color: #00ff00;
                            border-top-width: 4px;
                            border-bottom-color: #00ff00;
                            border-bottom-width: 4px;
                            table.Retro7 td {
                            padding-left: 10px;
                            padding-top: 0px;
                            padding-bottom: 0px;
                            table.ShadedAlternatingColumns {
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            x-col-pat-1: 1;
                            x-col-pat-count: 2;
                            x-col-pat-2: 1;
                            table.ShadedAlternatingColumns tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.ShadedAlternatingColumns tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.ShadedAlternatingColumns td.t1Col {
                            font-family: Arial;
                            font-size: 10pt;
                            table.ShadedAlternatingColumns td.t2Col {
                            font-family: Arial;
                            font-size: 10pt;
                            table.ShadedAlternatingRows {
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            font-family: Arial;
                            table.ShadedAlternatingRows tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            background-color: #0c72af;
                            table.ShadedAlternatingRows tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            background-color: #ffffff;
                            table.SimpleBorder {
                            padding: 0px;
                            table.SimpleBorder td {
                            table.TopRow {
                            x-1st-row: 1;
                            x-1st-row-name: t1st;
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            table.TopRow tr.t1st td {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            text-align: Center;
                            table.TopRow tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.TopRow tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.TopRowRepeatingRows {
                            x-row-pat-1: 1;
                            x-row-pat-2: 1;
                            x-1st-row: 1;
                            x-row-pat-count: 3;
                            x-row-pat-3: 1;
                            x-row-pat-3-name: t3Row;
                            table.TopRowRepeatingRows tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.TopRowRepeatingRows tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.TopRowRepeatingRows tr.t1st td {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            text-align: Center;
                            table.TopRowRepeatingRows tr.t3Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.TopRowAlternatingRows {
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            x-1st-row: 1;
                            table.TopRowAlternatingRows tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.TopRowAlternatingRows tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.TopRowAlternatingRows tr.t1st td {
                            text-align: Center;
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.TopRowLeftColumn {
                            x-row-pat-1: 1;
                            x-row-pat-count: 2;
                            x-row-pat-2: 1;
                            x-1st-row: 1;
                            x-1st-col: 1;
                            table.TopRowLeftColumn tr.t1Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.TopRowLeftColumn tr.t2Row td {
                            font-family: Arial;
                            font-size: 10pt;
                            table.TopRowLeftColumn tr.t1st td {
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            text-align: Center;
                            table.TopRowLeftColumn td.t1st {
                            text-align: Center;
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.toprowleftcolumn tr.t1row td.t1st {
                            text-align: Center;
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            table.toprowleftcolumn tr.t2row td.t1st {
                            text-align: Center;
                            font-family: Arial;
                            font-size: 10pt;
                            font-weight: bold;
                            p.FM_Body {
                            font-family: Arial;
                            p.FM_Bulleted {
                            font-family: Arial;
                            margin-left: 18pt;
                            x-list-level: 1;
                            p.FM_Caption {
                            font-family: Arial;
                            p.FM_CellBody {
                            font-family: Arial;
                            p.FM_CellHeading {
                            font-family: Arial;
                            color: #ffffff;
                            font-weight: bold;
                            p.FM_Heading1 {
                            font-family: Arial;
                            font-weight: bold;
                            font-size: 14pt;
                            p.FM_Heading2 {
                            font-family: Arial;
                            font-weight: bold;
                            p.FM_Heading3 {
                            font-family: Arial;
                            font-weight: bold;
                            font-size: 12pt;
                            p.FM_HeadingRunIn {
                            font-family: Arial;
                            p.FM_Note {
                            font-family: Arial;
                            color: #0c72af;
                            font-weight: bold;
                            font-style: normal;
                            p.FM_Numbered {
                            font-family: Arial;
                            margin-left: 18pt;
                            x-list-class: rl-p-FM_Numbered;
                            x-list-level: 1;
                            p.FM_Numbered1 {
                            font-family: Arial;
                            x-list-class: rl-p-FM_Numbered1;
                            x-list-level: 1;
                            margin-left: 18pt;
                            p.FM_TableFootnote {
                            font-family: Arial;
                            p.FM_Title {
                            font-family: Arial;
                            span.FM_Emphasis {
                            font-family: Arial;
                            font-weight: bold;
                            font-style: normal;
                            span.FM_Hyperlink {
                            font-family: Arial;
                            color: #0000ff;
                            font-style: normal;
                            text-decoration: underline;
                            span.FM_Subscript {
                            font-family: Arial;
                            span.FM_Superscript {
                            font-family: Arial;
                            span.FM_TE Blue {
                            font-family: Arial;
                            p.FM_Footnote {
                            font-family: Arial;
                            P {
                            margin-top: 14pt;
                            margin-bottom: 14pt;
                            margin-left: 0pt;
                            margin-right: 0pt;
                            font-family: Arial;
                            p.FM_Chapter Heading No Number {
                            font-size: 24pt;
                            color: #f7961e;
                            font-weight: bold;
                            p.FM_TableTitle {
                            font-weight: bold;
                            color: #000000;
                            text-align: left;
                            rh-list.rl-p-FM_Numbered1 {
                            x-level-count: 1;
                            x-lvl-1-format: "<x>.";
                            x-lvl-1-type: decimal;
                            rh-list.rl-p-FM_Numbered {
                            x-level-count: 1;
                            rh-list.rl-p-FM_Bulleted {
                            x-level-count: 1;
                            x-lvl-1-type: disc;
                            rh-list.rl-p-FM_Bulleted_indent {
                            x-level-count: 1;
                            x-lvl-1-type: disc;
                            span.FM_CommandLine {
                            font-family: "Courier New";
                            font-size: 12pt;
                            p.FM_Bulleted_indent {
                            margin-left: 36pt;
                            x-list-class: rl-p-FM_Bulleted_indent;
                            x-list-level: 1;
                            x-level-count: 1;
                            x-lvl-1-type: disc;
                            p.FM_Bulleted {
                            rh-list.Style1 {
                            x-lvl-1-format: "<x>&c";
                            x-lvl-2-type: lower-alpha;
                            x-lvl-2-format: "<x>&c";
                            x-lvl-2-margin: 20px;
                            x-lvl-3-type: lower-roman;
                            x-lvl-3-format: "<x>&c";
                            x-lvl-3-margin: 40px;
                            x-lvl-4-type: decimal;
                            x-lvl-4-format: "&o<x>&c";
                            x-lvl-4-margin: 60px;
                            x-lvl-5-format: "&o<x>&c";
                            x-lvl-5-margin: 80px;
                            x-lvl-6-type: lower-roman;
                            x-lvl-6-format: "&o<x>&c";
                            x-lvl-6-margin: 100px;
                            x-lvl-8-type: lower-alpha;
                            x-lvl-8-margin: 140px;
                            x-lvl-7-format: "<x>.";
                            x-lvl-7-margin: 120px;
                            x-level-count: 9;
                            x-lvl-9-type: lower-roman;
                            x-lvl-9-margin: 160px;
                            A.breadcrumbs {
                            font-family: Arial;
                            font-size: 10pt;
                            p.FM_Heading3 {
                            p.FM_Heading2 {
                            p.FM_Heading1 {
                            • 11. Re: ePub output - bulleted lists mangled RH9
                              The rh-list from one of your previous posts definitely a RoboHelp Mutilevel list. But the HTML you posted is a regular HTML list Are you 100% sure that you are converting the lists to a HTML list and not a RoboHelp Multilevel list?
                              Greet,
                              Willam
                              • 12. Re: ePub output - bulleted lists mangled RH9
                                Hi Willam,
                                Yes definitely HTML Lists. I have, during the course of this project tried RH lists to see if it cured another issue I had (it didn't!).
                                Mark
                                • 13. Re: ePub output - bulleted lists mangled RH9
                                  Ok, understood. I'll await your test project to see what's going wrong.
                                  Greet,
                                  Willam
                                  • 14. Re: ePub output - bulleted lists mangled RH9
                                    Hi Willam,
                                    Just sent you a sample project with the CSS file as posted above.
                                    Thanks for having a look at this
                                    Mark
