Hoping there is a SQL guru out there that can help me with this
I have two tables that I want to pull data from and display a report, based on a particular date range, for this example let's say 08/01/2011 to 08/31/2011
In one table there would be an affiliate ID - AFF_UID and also the date and a counter for that date, IMP_COUNTER , now there may only be a few records not every day might be covered, say
TABLE IMP
date,aff_uid,imp_counter
08/01/2011,999,2000
08/02/2011,999,2050
08/20/2011,999,2030
etc
I then have another date, similar set up only there are multiple records in here for a single day, again not all days covered, I would need to total up each row for each day to get a count. So it might be:
TABLE LEAD
date,aff_uid
08/01/2011,999
08/01/2011,999
08/01/2011,999
08/01/2011,999
08/12/2011,999
So we have different dates covered, sometimes the same date, I need the counter from the first table, and from the second table I need to add them up for a total, and then display any date that has a value and put both counter and lead count together
Result from above
date,imp total,lead total
08/01/2011,2000,4
08/02/2011,2050,0
08/12,2011,0,1
08/20/2011,2030,0
I am sure there must be a SQL command that can gel all of this together with some grouping? Last thing I need is a ton of SQL statements in a loop!
My alternative is to add a counter to the IMP table for each lead, so every time I update the lead table with a record, I will also update the counter, but that's unncessary storage of data I already have an an extra update statement that I might be able to do without, but maybe it would make generating reports faster, just pulling to counters with no 'addition' required.
Appreciate any feedback
Mark
select imp.date
, imp.aff_uid
, count(lead.aff_uid)
, counter
from imp join lead on imp.date = lead.date and imp.aff_uid = lead.aff_uid
where imp.date >= somedate
and imp.date < someotherdate
group by imp.date, imp.aff_uid
This is pretty basic stuff. Since you had to ask, I've heard good things about the book, Teach Yourself SQL in 10 Minutes by Ben Forta
Thanks Dan, I'll give it a shot later on. I've done grouping and joins before but often seem run into problems, it was the ability to join more than one item that got me there, should have known that!
Mark
I put in the correct field names and tried it out, but unfortunately it's throwing an error
[Macromedia][SQLServer JDBC Driver][SQLServer]The multi-part identifier "imppressions.imp_date" could not be bound.
Here's what I have
SELECT
imp_date,
imp_aff_uid,
imp_counter,
count(leads.lead_aff_uid)
FROM impressions JOIN leads ON impressions.imp_date = leads.lead_date and
imp_aff_uid = leads.lead_aff_uid
WHERE imppressions.imp_date BETWEEN #createODBCdate(form_from)# AND
#createODBCdate(form_to)#
GROUP BY impressions.imp_date,impressions.imp_aff_uid
I also need to sort by a particular specified aff_UID, guess I can add that into the WHERE when done
the typo in the word IMPRESSIONS did not help! just noticed that, correct, but still an error
[Macromedia][SQLServer JDBC Driver][SQLServer]Column 'impressions.imp_counter' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
We both forgot to put that in the group by clause.
I added it into the group, but it doesn't work, it gives no results for the LEADS, even though there is a record in there that should show, and only lists one record in the IMPRESSIONS table, when there are two, one for the 09/01 and one for 09/02
SELECT
imp_date,
imp_aff_uid,
imp_counter,
WHERE impressions.imp_date BETWEEN #createODBCdate(form_from)# AND
GROUP BY impressions.imp_date,impressions.imp_aff_uid,impressions.imp_counter
CFDUMP showed this
SELECT imp_date, imp_aff_uid, imp_counter, count(leads.lead_aff_uid) FROM impressions JOIN leads ON impressions.imp_date = leads.lead_date and imp_aff_uid = leads.lead_aff_uid WHERE impressions.imp_date BETWEEN {d '2011-08-01'} AND {d '2011-09-30'} GROUP BY impressions.imp_date,impressions.imp_aff_uid,impressions.imp_counter
Hey Dan
Any idea why I'm getting the wrong results? I can't seem to get this query right
Mark
When I expect to get data and don't, I try to isolate the cause by either removing constraints one by one, or removing them all and putting them back one by one.
In this case, I'd start by taking away the where clause. If I got results, I'd put the dates back one at a time to see which one caused the problem.
If I didn't get results by taking away the where clause, I'd start looking at the two fields used in the join.
I'm at a bit of a loss with this, I pulled the whole WHERE statement out, and I also tried playing with teh GROUP varaibles but that just caused it to throw errors.
I double checked the data, and tweaked it to make sure I was not going mad. I have two records in IMPRESSIONS, 09/01 and 09/02 and two in LEADS, 09/03 and 09/04 , it displays no leads at all in this state, now if I change the dates in LEADS to match the dates in IMPRESSIONS, I get two records return from the IMPRESSIONS table.. very strange
Putting it back as it was a CFDUMP is giving this
SELECT imp_date, imp_aff_uid, imp_counter, count(leads.lead_aff_uid) FROM impressions JOIN leads ON impressions.imp_date = leads.lead_date and imp_aff_uid = leads.lead_aff_uid WHERE impressions.imp_date BETWEEN {d '2011-01-01'} AND {d '2011-09-08'} GROUP BY impressions.imp_date,impressions.imp_aff_uid,impressions.imp_counter
And this gives no records instead of the four
I played a little more after posting this and found that what is happening is that if there are no records in the IMPRESSIONS table which have the same date as data that should be displayed in the LEADS table, then the leads data will not display for that date, so if I have a record in LEADS for 09/01 and I then add a record in IMPRESSIONS for 09/01 both display, on one row, but if I take out the data in IMPRESSIONS, then the data in LEADS does not display either
Mark
Let me see if I understand your requirements, please correct the following statements if they are wrong:
1. You wish to query for a given date range defined by form_from and form_to variables.
2. You wish to include every row in the impressions table that matches the date range criteria.
3. You wish to include the count of matching rows from the leads table for each row from the impressions table based on matching aff_uid and date.
You might try something like the query below. This uses a subquery to calculate the count from the leads table based on the aff_uid and date from the impressions row. Note that I have included the date parameters in CFQUERYPARAM tags.
SELECT
I.imp_date
, I.imp_aff_uid
, I.imp_counter
SELECT COUNT(*)
FROM leads AS L
WHERE L.aff_uid = I.imp_aff_uid
AND L.lead_date = I.imp_date
) AS lead_total
FROM impressions AS I
WHERE I.imp_date BETWEEN <cfqueryparam value="#form_from#" cfsqltype="cf_sql_timestamp"> AND <cfqueryparam value="#form_to#" cfsqltype="cf_sql_timestamp">
ORDER BY I.imp_date, I.imp_aff_uid;
You might also consider posting your question to a database specific form.
Correct, that is what I am trying to do, although the aff_uid is actually lead_aff_uid.
I tried the query and unfortunately it did not work, I got two records from the IMPRESSIONS table, however the records in the LEADS table were not returned
Mark
Do the ID and date field values in the LEADS table exactly match the related values in the IMPRESSIONS table?
In order to assist you further it would be useful to have:
1. The creation scripts for your tables.
2. A sample of data for each table.
3. The desired resultsest based on the sample data.
4. The database server you are using: vendor and version.
Yes, the IMP_AFF_UID and LEAD_AFF_UID from IMPRESSIONS and LEAD table respectively are related back to the users UID
I created the tables manually, I guess I could create a script from the SQL management tool if needed?
this is all I have in the test
IMPRESSIONS table
imp_aff_uid,imp_date,imp_counter
525503,9/1/2011,100
525503,9/3/2011,200
LEADS table
lead_aff_uid,lead_date (also have some other unrelated data in here for this report)
525503,9/3/2011
525503,9/7/2011
525504,9/7/2011
525504,9/7/2011
So in theory I should get:
09/01/2011,100,0
09/03/2011,200,1
09/07/2011,0,3
Mark
Knowing the data types for each column and the database server (vendor and version) would be useful.
umm. I thought there used to be a place to attach files...
Here's a creation script for the two tables (indexes are not in place yet)
USE [__a_cb]
GO
/****** Object: Table [dbo].[impressions] Script Date: 09/12/2011 19:48:17 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE TABLE [dbo].[impressions](
[imp_uid] [int] IDENTITY(1,1) NOT NULL,
[imp_aff_uid] [int] NOT NULL,
[imp_date] [smalldatetime] NULL,
[imp_counter] [int] NULL CONSTRAINT [DF_impressions_imp_counter] DEFAULT ((0)),
CONSTRAINT [PK_impressions] PRIMARY KEY CLUSTERED
[imp_uid] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
) ON [PRIMARY]
GO
/****** Object: Table [dbo].[leads] Script Date: 09/12/2011 19:48:20 ******/
SET ANSI_NULLS ON
GO
GO
CREATE TABLE [dbo].[leads](
[lead_uid] [int] IDENTITY(1,1) NOT NULL,
[lead_aff_uid] [int] NULL,
[lead_aff_master_uid] [int] NULL,
[lead_offer_uid] [int] NULL,
[lead_aff_percentage] [tinyint] NULL,
[lead_aff_payment] [smallmoney] NULL,
[lead_advertiser_payment] [smallmoney] NULL,
[lead_date] [smalldatetime] NULL,
[lead_pcode_uid] [int] NULL,
CONSTRAINT [PK_leads] PRIMARY KEY CLUSTERED
[lead_uid] ASC
) ON [PRIMARY]
GO
So based on your sample result set I need to assume that not every record will have a row in the IMPRESSIONS table..
You wish to get a resultset containing 3 columns:
1. An uid from IMPRESSIONS (or LEADS if there is no match in the IMPRESSIONS table).
2. A date from IMPRESSIONS (or LEADS if there is no match in the IMPRESSIONS table).
3. The count of records in the LEADS table that math the uid and date.
Is this correct? It contradicts the assumptions I stated on Sept 9 where I assumed that all records in the results would have a record in the IMPRESSIONS table, to quote "You wish to include every row in the impressions table that matches the date range criteria."
sorry, that is correct, there isa possibilty that there would be a date missing in either of the tables, so on a particular date there might be a record for IMPRESSIONS, but not LEADS, or vice versa, there could also be no records on a particular date.
So somehow I have to combine the data and report it all based on the dates that are available with some date in one or both tables
Mark
Take the date portion out of the join. It becomes this:
FROM impressions JOIN leads ON imp_aff_uid = leads.lead_aff_uid
Then, in the where clause do something like this
where (impressions.date >= something and impressions.date < something)
or (leads.date >= something and leads.date < something)
tried it, but unfortunately get the same results as bob, just the two records from the IMPRESSIONS table. Here's what I used
SELECT
imp_date,
imp_aff_uid,
imp_counter,
WHERE impressions.imp_date BETWEEN #createODBCdate(form_from)# AND #createODBCdate
(form_to)# OR leads.lead_date BETWEEN #createODBCdate(form_from)# AND
Seems like what you need is a FULL OUTER JOIN. But I do not think they are supported in MySQL. If not, you could simulate it using a UNION.
The first query should grab all impressions, with or without matching leads. The second should retrieve only leads without matching impression records. In other words, dates not already included in the first query. Something like
SELECT i.imp_date, i.imp_counter, COUNT(l.lead_aff_uid) AS leadCount
FROM impressions i LEFT JOIN leads l
ON i.imp_aff_uid = l.lead_aff_uid
AND i.imp_date = l.lead_date
WHERE i.imp_date BETWEEN ...{your filters} ...
GROUP BY i.imp_date, i.imp_counter
UNION ALL
SELECT l.lead_date, 0 AS imp_counter, COUNT(l.lead_aff_uid) AS leadCount
FROM leads l LEFT JOIN impressions i
WHERE l.lead_date BETWEEN ...{your filters} ...
AND i.imp_aff_uid IS NULL
GROUP BY l.lead_date
The result should be:
>> 09/01/2011,100,0
>> 09/03/2011,200,1
>> 09/07/2011,0,3
However you would not get those totals as long you are including the "uid" column in the SELECT list.
Sorry, I should have pointed out, I'm not using MySQL. I am using MS SQL2005
Then take a look at the documentation on FULL OUTER JOIN's. They are certainly much simpler than the UNION I just posted
-Leigh
I'
m not sure I'd be able to disect and redo what you just did !
I'
No reason to redo it. It is a poor substitute anyway. The final query should be much simpler. You already know the results you need. You just need to read up on full outer joins for yourself.
